Can't see complete DIR.
itchykill
#1 Post by itchykill »
I apologize in advance if this is a dumb question, but how do I navigate to see the rest of the DIR? I can see the 'Previous' and 'Next' in the window but I can't find any keys that allow me to actually go 'Next'. I need to get into a special dir that I know exists, but how?
It stops at a dir called "found000" but there are several folders left in the dir. I need the complete list of the dir.
Thanks.
By the way, this is a Cloud drive that is managed with Stablebit Clouddrive and is connected to Google Drive provider.
Re: Can't see complete DIR.
Try the "Down" arrow key. Can you go after the found.000 ?
Did you check if found.000 contains the missing directories ?
Planitzer
#3 Post by Planitzer »
Hello
I have merged two partitions now this new large partition is empty. How can I restore the folder structure of both partitions?
Kind regards
I do not speak English
mfg Planitzer
