Sorry if this has been asked, I searched but didn't find a post that seemed to match my problem.
Thanks for taking the time to read my post.
So, I was using this external Iomega HDD and after a while the USB port failed.
I removed the HDD from the enclosure and stuck it in my PC, but now the partition is gone and Windows is showing unallocated space. The same thing happens when I use a SATA-USB adapter.
I've tried using TestDisk and following the instructions here. but when I get to step 8 and press P to list files TestDisk tells me "Can't open filesystem. Filesystem seems damaged." I don't know how to continue with TestDisk.
PhotoRec can recover the files, so I know the data is still there. However, without the filenames/directory structure intact a lot of the files are useless. (For example, this partition contains my Launchbox DB with tens of thousands of small files.) Also, there doesn't appear to be any way to choose which files are recovered, and I don't have enough space to save everything. (There's almost 1TB of data on this drive, and I have about 35GB free space.)
I still have the PCB that it was connected to in the external drive case, but like I said, the USB port is broken and it fell off when I removed the drive from it's enclosure. I'm going to try to solder the USB cable directly to the PCB where the USB port was, but I doubt I will be successful.
Any suggestions on how I can recover the partition? Thanks.
SlickStretch
Re: Can't open filesystem. Filesystem seems damaged.
Whn running testdisk, try Deeper Search. Check all partitions listed, if you can see your files, switch this partition to P(rimary), on next screen, choose Write, confirm, Quit
If it doesn't work, please copy and paste the testdisk.log file content.
SlickStretch
Sorry for the delay. I was waiting for an email notofication that I had a reply, but it never came...
Anyway, I followed your instructions. After the Deeper Scan it then showed the correct name of the partition, but I still get "Filesystem may be damaged" when I try to list files.
Here's the log:
Here's the log:
Wed Jun 12 04:18:23 2019
TestDisk 7.1-WIP, Data Recovery Utility, May 2019
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=200049647616
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=32473088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=200049647616
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=32473088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=63445139456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=120031543296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=0
Warning: can't get size for \\.\M:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=32430592
Disk /dev/sda - 64 GB / 59 GiB - CHS 7783 255 63, sector size=512 - M4-CT064M4SSD2, S/N:0000000012040903A52F, FW:0309
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MK1059GSM, S/N:X18DFVHRS, FW:GU001U
Disk /dev/sdc - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - ST3120213AS, S/N:5LSGLBGD, FW:3.AHL
Disk /dev/sdd - 200 GB / 186 GiB - CHS 24321 255 63, sector size=512 - Maxtor 6L200M0, S/N:L42XXPEG, FW:BACE1GA0
Disk /dev/sdh - 32 MB / 30 MiB - CHS 3 255 63, sector size=512 - Generic- MS/MS-Pro, S/N:058F63646473, FW:1.03
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA MK1059GSM
BAD_RS LBA=1 0
1 P EFI GPT 0 0 2 15200 41 63 244190645
Bad relative sector.
NTFS at 0/32/33
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
filesystem size 244138752
sectors_per_cluster 1
mft_lcn 54537727
mftmirr_lcn 54520146
clusters_per_mft_record 1
HPFS - NTFS 0 32 33 121575 153 50 1953110016
NTFS, blocksize=4096, 999 GB / 931 GiB
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(5,14,buffer,1953525762(121601/90/28)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 121575 153 50 1953110016
1 * HPFS - NTFS 0 32 33 121575 153 50 1953110016
NTFS at 0/32/33
mft_lcn 54537727
NTFS at 25/159/7
mft_lcn 54537727
HPFS - NTFS 25 159 7 121601 25 24 1953110016 [Iomega1T]
LVM magic value at 38061/47/3
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
NTFS Volume is dirty.
dir_partition inode=5
ntfs_dir: ntfs_inode_open failed
Choose EFI GPT instead of Intel.
Try to list the files from each partition found by TestDisk.
SlickStretch
Ok, I tried EFI GPT and got the same error.
The log file exceeds the post character limit, so I posted it on Pastebin here: https://pastebin.com/Tj3hCpyY
Thanks for taking the time to help me.
