Selecting List crashes TestDisk
gridflash
#1 Post by gridflash »
Okay
I have a 1T WD drive with 4 partitions. One of the partitions won't mount. EaseUS Data Recovery can see all the files but windows won't mount it.
When I try to check the file system we get this message: "Unable to determine volume version and state. CHKDSK aborted."
So I run TestDisk. It sees the NTFS partition and the number of sectors correctly but the partition structure has an * in front of it.
I run Advanced, Boot. Says Boot is okay and backup is okay Sectors are Identical.
So I select RebuildBS.
When that finishes it says Extrapolated boot sector and current sector are different.
So I select List. Testdisk crashes.
Now what :?:
Re: Selecting List crashes TestDisk
You can always try PhotoRec to recover your data but it won't recover the original filenames.
Using a commercial data recovery utility may be the only way to get your data with the filenames...
gridflash
#3 Post by gridflash »
Well, since EaseUS Data Recovery can see all the files I can certainly do that. But I was hoping I could repair the boot sector.
I still don't understand why choosing 'List' crashed TestDisk both times I tried it.
Since the Extrapolated boot sector is different than the current boot sector would trying to 'Write' the Extrapolated boot sector let chkdsk read the partition?
gridflash wrote: 11 Jun 2019, 17:33 I still don't understand why choosing 'List' crashed TestDisk both times I tried it.
Is there any software at all where you understand why the software crashes?
Nobody stops you from investing some time and running a different version of testdisk or run it from a different operation system.
You could clone the drive in question with ddrescue to exclude unreadable sectors p.e..
And finally if the crash prevails you could post an article with a detailed description of all necessary circumstances.
"Testdisk crashes when trying to list files" sounds interesting but does not provide any additional information to track down a possible error unfortunately.
recuperation wrote: 11 Jun 2019, 19:06
gridflash wrote: 11 Jun 2019, 17:33 Since the Extrapolated boot sector is different than the current boot sector would trying to 'Write' the Extrapolated boot sector let chkdsk read the partition?
This question cannot be answered.
A valid boot sector is just a necessary condition to mount a file system but not a sufficient one.
Imagine your car has been involved in an car accident and you ask the mechanic: Will it run again after pumping up the tires?
#5 Post by recuperation »
