USB partition and files recovery
h4ni
#1 Post by h4ni »
Hello!
My usb flash drive suddenly change to RAW and i can't access files. I've tried the scan but it doesn't find partition.
What can I do next, is there a solution to access the files on the drive?
Re: USB partition and files recovery
Is your disk really 8 GB ?
Try PhotoRec. Does it recover your files ?
h4ni
#3 Post by h4ni »
cgrenier wrote: 15 Jun 2019, 10:40 Is your disk really 8 GB ?
Yes, the disk is 8gb drive.
I've run the Photorec. I get message that 1 file is recoverd, but I can't open that 7z file. Usb has hundreds of files (pdfs)
