*.kexjat recovery
toiletrunner
*.kexjat recovery
#1 Post by toiletrunner »
I have lost files with kexjat extension.
Those are files encrypted by GrandCrab ransomware.
Can I recover them with photorec?
I have few files left that I haven't lost.
Re: *.kexjat recovery
You can always try PhotoRec to recover your lost files but recent cryptolocker usually use a "secure" deletion method that prevent recovery.
Be careful to store the recovered files on a partition different than the source.
toiletrunner
#3 Post by toiletrunner »
Cryptolocker had encripted my files and puted kexjat extension. In panic I have deleted them and formated hard drive. can I search for files with only thet extension and ignore others. Thing is, that drive that i want to recover is 1TB, but I only have 70GB available for recovered files on the other hard drive.
You can use TestDisk, Advanced, Undelete to recover the files you have deleted.
To try to recover the files deleted by the cryptolocker, use PhotoRec.
