So i tried following closely, step by the step the tutorial on the website, after making the partition into a logical partition and pressing write and then restarting, the computer won't boot and i get the following message (using Windows 7 )
- Initializing establishing link.
- Pxe-Moc Exiting Intel boot agent
I don't know if it's a problem with the config or a hardware problem with the hardrive.
Thanks in advance.
Compute fail to boot after restarting at the end of a testdisk recovery attempt
Re: Compute fail to boot after restarting at the end of a testdisk recovery attempt
For a computer to start, you usually need a bootable ("*") partition on your main harddisk.
