External USB HDD
Fael
External USB HDD
#1 Post by Fael »
Hello, everyone.
I recently experienced the unfortunate failure of my external USB hard drive where I keep my daughter's photos and videos and I'm desperately trying to recover the files. I've tried using Testdisk to no avail. I've also Googled the log errors and some people have had success recovering their files (with the help of some wonderful forum members!).
However, I'm a complete newbie regarding disk recovery and I could not grasp why some members suggested their proposed solutions (e.g., increase cylinders number, change heads number). If I had understood what they were seeing, I would have already tried something on my disk but I'm too weary of trying because of the emotional attachment I have towards the information in it.
With all that said, I would be thoroughly grateful towards any helpful information anyone could provide me.
The Testdisk log is the following (I used the Analyse and the Deeper Search functions):
Sat Jul 14 09:07:50 2012
OS: Linux, kernel 2.6.32-23-generic (#37-Ubuntu SMP Fri Jun 11 08:03:28 UTC 2010) x86_64
Compiler: GCC 4.4
Compilation date: 2012-06-28T08:50:00
ext2fs lib: 1.41.12, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
/dev/sda: size 312581808 sectors
/dev/sda: user_max 312581808 sectors
/dev/sda: native_max 10591920 sectors
/dev/sda: dco 312581808 sectors
/dev/sdb: LBA, HPA, DCO support
/dev/sdb: size 156301488 sectors
/dev/sdb: user_max 156301488 sectors
/dev/sdb: native_max 156301488 sectors
/dev/sdb: dco 160086528 sectors
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - Hitachi HDS721616PLA380 IBM, S/N:PVFC44ZHRXNA8E, FW:P22OABCA
Disk /dev/sdb - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - Maxtor 4D080H4, S/N:D40C0D8E, FW:DAH017K0
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WD 5000AAV External, FW:1.65
Disk /dev/sdc - 500 GB / 465 GiB - WD 5000AAV External
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
test_FAT()
1 P FAT32 LBA 0 1 1 60799 254 63 976751937
sector_size 46074
cluster_size 252
reserved 52687
fats 168
dir_entries 37047
sectors 17978
media 63
fat_length 16094
secs_track 6759
heads 61505
hidden 2682593931
total_sect 1202497466
Invalid FAT boot sector
Ask the user for vista mode
search_vista_part: 0
test_FAT()
sector_size 46074
cluster_size 252
reserved 52687
fats 168
dir_entries 37047
sectors 17978
media 63
fat_length 16094
secs_track 6759
heads 61505
hidden 2682593931
search_vista_part: 1
test_FAT()
sector_size 46074
cluster_size 252
reserved 52687
fats 168
dir_entries 37047
sectors 17978
media 63
fat_length 16094
secs_track 6759
heads 61505
hidden 2682593931
BAD_RS LBA=536870975 63
FAT32 LBA 33418 171 33 94218 170 32 976751937
This partition ends after the disk limits. (start=536870975, size=976751937, end=1513622911, disk end=976773168)
The harddisk (500 GB / 465 GiB) seems too small! (< 774 GB / 721 GiB)
Fael
Re: External USB HDD
#2 Post by Fael »
Yesterday I tried doing what Fiona suggested in this thread:
Fiona wrote:Partition found by TestDisk is only XXX GB.
Probably wrong, because it's too small.
But in your partition table is a partition whicht fits.
Could you have a boot sector diagnose?
Confirm at Boot.
Please let us know, do you see your data or an error message.
Procedur would be like in this thread;
If you're able to watch your data, you could write your boot sector.
Still, the 500GB WD USB HD could not be mounted so I tried using Analyse -> Quick Search. This returned a positive result listing the original partition, which is a little bit odd because I still could not mount it (Ubuntu said: "Error mounting: mount: /dev/sdc1: can't read superblock"). I tried Deeper Search but it was too late and I went to sleep and left the computer running.
I'll update this thread tonight (GMT-5 time) with the results.
#3 Post by Fiona »
Have you been able to list your files?
Until yet it looks like that you have a partition in your partition table.
Only a partition in your partition table would look unformatted, what you shouldn't do.
Would it be possible to upload or copy and paste the content of your diks using testdisk and your diagnose.
Currently your partition table (Analyse) would be important and Quick Search.
If no partition will bee found, from Deeper Search also.
If a partition is found, please mark that partition and press p to list your files.
Fael
#4 Post by Fael »
I just ran a Quick Search and a partition was found. I selected "p" (show files) and I got this log:
Tue Jul 17 23:58:22 2012
Compiler: GCC 4.4
FAT32 at 0/1/1
Info: size boot_sector 976751937, partition 976751937
FAT1 : 32-119249
FAT2 : 119250-238467
start_rootdir : 12612292 root cluster : 193343
Data : 238468-976751875
sectors : 976751937
cluster_size : 64
no_of_cluster : 15258022 (2 - 15258023)
fat_length 119218 calculated 119204
FAT differs, FAT sectors=0-16/119218
FAT32 at 0/1/1
FAT1 : 32-119249
sectors : 976751937
cluster_size : 64
FAT32 at 0/1/1
FAT32, blocksize=32768, 500 GB / 465 GiB
* FAT32 LBA 0 1 1 60799 254 63 976751937
dir_partition inode=0
FAT: cluster=193343(0x2f33f), pos=12612355
FAT: cluster=193344(0x2f340), pos=12612419
FAT: cluster=193345(0x2f341), pos=12612483
FAT: cluster=193346(0x2f342), pos=12612547
FAT: cluster=193347(0x2f343), pos=12612611
FAT: cluster=193348(0x2f344), pos=12612675
FAT: cluster=193349(0x2f345), pos=12612739
FAT: cluster=193350(0x2f346), pos=12612803
FAT: cluster=193351(0x2f347), pos=12612867
FAT: cluster=193352(0x2f348), pos=12612931
FAT: cluster=193353(0x2f349), pos=12612995
FAT: cluster=193354(0x2f34a), pos=12613059
FAT: cluster=193355(0x2f34b), pos=12613123
FAT: cluster=193356(0x2f34c), pos=12613187
FAT: cluster=193357(0x2f34d), pos=12613251
FAT: cluster=193358(0x2f34e), pos=12613315
FAT: cluster=193359(0x2f34f), pos=12613379
FAT: cluster=193360(0x2f350), pos=12613443
FAT: cluster=193361(0x2f351), pos=12613507
FAT: cluster=193362(0x2f352), pos=12613571
FAT: cluster=193363(0x2f353), pos=12613635
FAT: cluster=193364(0x2f354), pos=12613699
FAT: cluster=193365(0x2f355), pos=12613763
FAT: cluster=193366(0x2f356), pos=12613827
FAT: cluster=193367(0x2f357), pos=12613891
FAT: cluster=193368(0x2f358), pos=12613955
FAT: cluster=193369(0x2f359), pos=12614019
FAT: cluster=193370(0x2f35a), pos=12614083
FAT: cluster=193371(0x2f35b), pos=12614147
FAT: cluster=193372(0x2f35c), pos=12614211
X 193344 -rwxr-xr-x 0 0 3906183 5-Jul-2009 12:41 _U6CB0~1.MP3
X 193464 -rwxr-xr-x 0 0 1230845 5-Jul-2009 12:40 Queen - Vultan's Theme.mp3
X 193502 -rwxr-xr-x 0 0 5564915 5-Jul-2009 13:15 Queen - Was It All Worthit.mp3
X 193672 -rwxr-xr-x 0 0 2943331 4-Jul-2009 15:33 Queen - We Are The Champions.mp3
X 193762 -rwxr-xr-x 0 0 2025489 4-Jul-2009 15:33 Queen - We Will Rock You.mp3
X 193824 -rwxr-xr-x 0 0 4894459 4-Jul-2009 15:25 Queen - White Man.mp3
X 193974 -rwxr-xr-x 0 0 4454949 4-Jul-2009 15:00 Queen - White Queen.mp3
X 194110 -rwxr-xr-x 0 0 3065786 4-Jul-2009 15:33 Queen - Who Needs You.mp3
X 194204 -rwxr-xr-x 0 0 5108251 5-Jul-2009 12:55 Queen - Who Wants To Live Forever.mp3
X 194360 -rwxr-xr-x 0 0 3362638 4-Jul-2009 15:25 Queen - You And I.mp3
X 194463 -rwxr-xr-x 0 0 5206304 5-Jul-2009 13:28 Queen - You Don't Fool Me.mp3
X 194622 -rwxr-xr-x 0 0 4501591 4-Jul-2009 15:25 Queen - You Take My Breath Away.mp3
X 194760 -rwxr-xr-x 0 0 2735198 4-Jul-2009 15:16 Queen - You're My Best Friend.mp3
X 194844 -rwxr-xr-x 0 0 5723326 18-Nov-2008 21:49 Radiohead - Airbag.mp3
X 195019 -rwxr-xr-x 0 0 4659621 18-Nov-2008 21:49 Radiohead - Amnesiacthe Morning Bell.mp3
X 195162 -rwxr-xr-x 0 0 5739522 18-Nov-2008 21:49 Radiohead - Climbing Up The Walls.mp3
X 195338 -rwxr-xr-x 0 0 9147187 18-Nov-2008 21:49 Radiohead - Dollars And Cents.mp3
X 195618 -rwxr-xr-x 0 0 4648126 18-Nov-2008 21:49 Radiohead - Electioneering.mp3
X 195760 -rwxr-xr-x 0 0 5331489 18-Nov-2008 21:49 Radiohead - Exit Music (For A Film).mp3
X 195923 -rwxr-xr-x 0 0 2382265 18-Nov-2008 21:49 Radiohead - Fitter Happier.mp3
X 195996 -rwxr-xr-x 0 0 3880896 18-Nov-2008 21:49 Radiohead - Hunting Bears.mp3
X 196115 -rwxr-xr-x 0 0 9367868 18-Nov-2008 21:49 Radiohead - I Might Be Wrong.mp3
X 196401 -rwxr-xr-x 0 0 5267750 18-Nov-2008 21:49 Radiohead - Karma Police.mp3
X 196562 -rwxr-xr-x 0 0 8158284 18-Nov-2008 21:49 Radiohead - Knives Out.mp3
X 196811 -rwxr-xr-x 0 0 6020599 18-Nov-2008 21:49 Radiohead - Let Down.mp3
X 196995 -rwxr-xr-x 0 0 6590290 18-Nov-2008 21:49 Radiohead - Life In A Glass House.mp3
X 197197 -rwxr-xr-x 0 0 5694482 18-Nov-2008 21:49 Radiohead - Like Spinning Plates.mp3
X 197371 -rwxr-xr-x 0 0 5228044 18-Nov-2008 21:49 Radiohead - Lucky.mp3
X 197531 -rwxr-xr-x 0 0 4606330 18-Nov-2008 21:49 Radiohead - No Surprises.mp3
X 197672 -rwxr-xr-x 0 0 5735298 18-Nov-2008 21:49 Radiohead - Packt Like Sardines In A Crushd Tin Box.mp3
X 197848 -rwxr-xr-x 0 0 7705497 18-Nov-2008 21:49 Radiohead - Paranoid Android.mp3
X 198084 -rwxr-xr-x 0 0 5921770 18-Nov-2008 21:49 Radiohead - Pulk Pull Revolving Doors.mp3
X 198265 -rwxr-xr-x 0 0 9330295 18-Nov-2008 21:49 Radiohead - Pyramid Song.mp3
X 198550 -rwxr-xr-x 0 0 5389481 18-Nov-2008 21:49 Radiohead - Subterranean Homesick Alien.mp3
X 198715 -rwxr-xr-x 0 0 6526330 18-Nov-2008 21:49 Radiohead - The Tourist.mp3
X 198915 -rwxr-xr-x 0 0 6114480 18-Nov-2008 21:49 Radiohead - You And Whose Army.mp3
X 199102 -rwxr-xr-x 0 0 5042239 25-Jan-2009 15:13 Rihanna - Break It Off.mp3
X 199256 -rwxr-xr-x 0 0 9579758 6-Feb-2009 12:30 Rihanna - Disturbia (Instrumental).mp3
X 199549 -rwxr-xr-x 0 0 9549920 2-Nov-2008 10:49 Rihanna - Disturbia.mp3
X 199841 -rwxr-xr-x 0 0 5343232 25-Jan-2009 15:13 Rihanna - Good Girl Gone Bad.mp3
X 200005 -rwxr-xr-x 0 0 4475379 25-Jan-2009 15:13 Rihanna - Hate That I Love You.mp3
X 200142 -rwxr-xr-x 0 0 5859520 25-Jan-2009 15:13 Rihanna - Live Your Life.MP3
X 200321 -rwxr-xr-x 0 0 6944768 25-Jan-2009 15:13 Rihanna - Please Don't Stop The Music.mp3
X 200533 -rwxr-xr-x 0 0 3981635 25-Jan-2009 15:13 Rihanna - Pon De Replay.mp3
X 200655 -rwxr-xr-x 0 0 7215104 25-Jan-2009 15:13 Rihanna - Rehab.mp3
X 200876 -rwxr-xr-x 0 0 5421286 25-Jan-2009 15:13 Rihanna - Shut Up And Drive.mp3
X 201042 -rwxr-xr-x 0 0 6461293 25-Jan-2009 15:13 Rihanna - Take A Bow.mp3
X 201240 -rwxr-xr-x 0 0 9717977 28-Oct-2008 11:29 Samuel Jackson Five - Britney Spears 4 President.mp3
X 201537 -rwxr-xr-x 0 0 4489088 25-Oct-2008 12:14 Samuel Jackson Five - Charlie Foxtrot Queen.mp3
X 201674 -rwxr-xr-x 0 0 4081105 28-Oct-2008 11:29 Samuel Jackson Five - Clubbers Dream.mp3
X 201799 -rwxr-xr-x 0 0 6351701 28-Oct-2008 11:29 Samuel Jackson Five - Counting Sheep.mp3
X 201993 -rwxr-xr-x 0 0 5965696 25-Oct-2008 12:14 Samuel Jackson Five - Easily Misunderstood.mp3
X 202176 -rwxr-xr-x 0 0 6993984 28-Oct-2008 11:29 Samuel Jackson Five - Honest Abe.mp3
X 202390 -rwxr-xr-x 0 0 7563136 25-Oct-2008 12:14 Samuel Jackson Five - If You Show Off The Milk, Who's G.mp3
X 202621 -rwxr-xr-x 0 0 8779969 28-Oct-2008 11:29 Samuel Jackson Five - Locust Lowtalker.mp3
X 202889 -rwxr-xr-x 0 0 10978803 25-Oct-2008 12:14 Samuel Jackson Five - Michael Collins Autograph.mp3
X 203225 -rwxr-xr-x 0 0 6021334 25-Oct-2008 12:14 Samuel Jackson Five - No Name.mp3
X 203409 -rwxr-xr-x 0 0 11296640 25-Oct-2008 12:14 Samuel Jackson Five - Person Most Likely To Enjoy The T.mp3
X 203754 -rwxr-xr-x 0 0 9433889 28-Oct-2008 11:29 Samuel Jackson Five - Postmans Joke.mp3
X 204042 -rwxr-xr-x 0 0 2624680 25-Oct-2008 12:14 Samuel Jackson Five - Psycho Derelict.mp3
X 204123 -rwxr-xr-x 0 0 3924614 28-Oct-2008 11:29 Samuel Jackson Five - Same Same But Different.mp3
X 204243 -rwxr-xr-x 0 0 6904832 28-Oct-2008 11:29 Samuel Jackson Five - Sing Slow, Walk Fast.mp3
X 204454 -rwxr-xr-x 0 0 10162048 25-Oct-2008 12:14 Samuel Jackson Five - Skinflick Dress Rehearsal.mp3
X 204765 -rwxr-xr-x 0 0 7417626 25-Oct-2008 12:14 Samuel Jackson Five - Song For Sarah.mp3
X 204992 -rwxr-xr-x 0 0 3369491 25-Oct-2008 12:14 Samuel Jackson Five - Switch Ambulance Trip.mp3
X 205095 -rwxr-xr-x 0 0 10599333 25-Oct-2008 12:14 Samuel Jackson Five - Unimog.mp3
X 205419 -rwxr-xr-x 0 0 3856256 11-Jun-2008 13:28 Sarah Brightman - Deliver Me.mp3
X 205537 -rwxr-xr-x 0 0 4297166 21-Jul-2008 13:44 Saratoga - A Sangre Y Fuego.mp3
X 205669 -rwxr-xr-x 0 0 5247093 21-Jul-2008 13:44 Saratoga - Parte De Mi.mp3
X 205830 -rwxr-xr-x 0 0 4510803 14-Aug-2008 21:25 Savage Garden - Crash And Burn.mp3
X 205968 -rwxr-xr-x 0 0 8932453 14-Aug-2008 21:25 Savage Garden - The Animal Song.mp3
X 206241 -rwxr-xr-x 0 0 5827852 18-Feb-2009 13:51 Seal - Dreaming In Metaphors.m4a
X 206419 -rwxr-xr-x 0 0 1556590 11-Jul-2008 13:32 Shakira - 1968.mp3
X 206467 -rwxr-xr-x 0 0 4748141 10-Jul-2008 14:06 Shakira - Animal City.mp3
X 206612 -rwxr-xr-x 0 0 3981688 11-Jul-2008 13:32 Shakira - Brujería.mp3
X 206734 -rwxr-xr-x 0 0 2864028 11-Jul-2008 13:32 Shakira - Cazador De Amor.mp3
X 206822 -rwxr-xr-x 0 0 4404642 10-Jul-2008 14:06 Shakira - Ciega, Sordomuda.mp3
X 206957 -rwxr-xr-x 0 0 4356097 11-Jul-2008 13:32 Shakira - Controlas Mi Destino.mp3
X 207090 -rwxr-xr-x 0 0 4651593 10-Jul-2008 14:06 Shakira - Costume Makes The Clown.mp3
X 207232 -rwxr-xr-x 0 0 3572051 11-Jul-2008 13:32 Shakira - Cuentas Conmigo.mp3
X 207342 -rwxr-xr-x 0 0 4164343 10-Jul-2008 14:06 Shakira - Despedida.mp3
X 207470 -rwxr-xr-x 0 0 6246541 10-Jul-2008 14:13 Shakira - Don't Bother.mp3
X 207661 -rwxr-xr-x 0 0 5851321 10-Jul-2008 14:06 Shakira - Dreams For Plans.mp3
X 207840 -rwxr-xr-x 0 0 6445056 10-Jul-2008 14:06 Shakira - Día Especial.mp3
X 208037 -rwxr-xr-x 0 0 3761643 10-Jul-2008 14:06 Shakira - Dónde Estas Corazón.mp3
X 208152 -rwxr-xr-x 0 0 3139436 10-Jul-2008 14:06 Shakira - Dónde Están Los Ladrones.mp3
X 208248 -rwxr-xr-x 0 0 5814272 10-Jul-2008 14:06 Shakira - En Tus Pupilas.mp3
X 208426 -rwxr-xr-x 0 0 4715185 11-Jul-2008 13:32 Shakira - Eres.mp3
X 208570 -rwxr-xr-x 0 0 5064704 10-Jul-2008 14:06 Shakira - Escondite Inglés.mp3
X 208725 -rwxr-xr-x 0 0 3437886 11-Jul-2008 13:32 Shakira - Esta Noche Voy Contigo.mp3
X 208830 -rwxr-xr-x 0 0 4028015 11-Jul-2008 13:32 Shakira - Este Amor Es Lo Más Bello Del Mundo.mp3
X 208953 -rwxr-xr-x 0 0 4457722 11-Jul-2008 13:32 Shakira - Eterno Amor.mp3
X 209090 -rwxr-xr-x 0 0 3822425 10-Jul-2008 14:06 Shakira - Eyes Like Yours.mp3
X 209207 -rwxr-xr-x 0 0 3718223 10-Jul-2008 14:06 Shakira - Fool.mp3
X 209321 -rwxr-xr-x 0 0 2883672 11-Jul-2008 13:32 Shakira - Gafas Oscuras.mp3
X 209410 -rwxr-xr-x 0 0 5054839 10-Jul-2008 14:06 Shakira - Hay Amores.mp3
X 209565 -rwxr-xr-x 0 0 4028777 10-Jul-2008 14:06 Shakira - Hey You.mp3
X 209688 -rwxr-xr-x 0 0 4326453 10-Jul-2008 14:06 Shakira - How Do You Do.mp3
X 209821 -rwxr-xr-x 0 0 3104193 10-Jul-2008 14:06 Shakira - Inevitable.mp3
X 209916 -rwxr-xr-x 0 0 7702967 10-Jul-2008 14:06 Shakira - La Tortura (Shaketon Remix).mp3
X 210152 -rwxr-xr-x 0 0 5355520 10-Jul-2008 14:06 Shakira - Las De La Intuición.mp3
X 210316 -rwxr-xr-x 0 0 2977713 11-Jul-2008 13:32 Shakira - Lejos De Tu Amor (Remix).mp3
X 210407 -rwxr-xr-x 0 0 2788378 11-Jul-2008 13:32 Shakira - Lejos De Tu Amor.mp3
X 210493 -rwxr-xr-x 0 0 5791744 10-Jul-2008 14:06 Shakira - Lo Imprescindible.mp3
X 210670 -rwxr-xr-x 0 0 4547696 11-Jul-2008 13:32 Shakira - Magia.mp3
X 210809 -rwxr-xr-x 0 0 3461988 10-Jul-2008 14:06 Shakira - Moscas En La Casa.mp3
X 210915 -rwxr-xr-x 0 0 3279480 11-Jul-2008 13:32 Shakira - Necesito De Ti.mp3
X 211016 -rwxr-xr-x 0 0 3742593 10-Jul-2008 14:06 Shakira - Objection (Afro-Punk Version).mp3
X 211131 -rwxr-xr-x 0 0 3327872 10-Jul-2008 14:06 Shakira - Objection.mp3
X 211233 -rwxr-xr-x 0 0 4202496 10-Jul-2008 14:06 Shakira - Obtener Un Sí.mp3
X 211362 -rwxr-xr-x 0 0 4360064 10-Jul-2008 14:06 Shakira - Octavo Día.mp3
X 211496 -rwxr-xr-x 0 0 4365279 11-Jul-2008 13:32 Shakira - Peligro.mp3
X 211630 -rwxr-xr-x 0 0 2353015 10-Jul-2008 14:06 Shakira - Pienso En Ti.mp3
X 211702 -rwxr-xr-x 0 0 3984593 10-Jul-2008 14:06 Shakira - Poem To A Horse.mp3
X 211824 -rwxr-xr-x 0 0 3725040 10-Jul-2008 14:06 Shakira - Que Vuelvas.mp3
X 211938 -rwxr-xr-x 0 0 3274828 11-Jul-2008 13:32 Shakira - Quince Años.mp3
X 212038 -rwxr-xr-x 0 0 4072364 10-Jul-2008 14:06 Shakira - Ready For The Good Times.mp3
X 212163 -rwxr-xr-x 0 0 5296556 10-Jul-2008 14:06 Shakira - Rules.mp3
X 212325 -rwxr-xr-x 0 0 3528714 10-Jul-2008 14:06 Shakira - Se Quiere, Se Mata.mp3
X 212433 -rwxr-xr-x 0 0 3463816 10-Jul-2008 14:06 Shakira - Sombra De Ti.mp3
X 212539 -rwxr-xr-x 0 0 6348779 10-Jul-2008 14:06 Shakira - Something.mp3
X 212733 -rwxr-xr-x 0 0 3322529 11-Jul-2008 13:32 Shakira - Sueños.mp3
X 212835 -rwxr-xr-x 0 0 3558693 10-Jul-2008 14:06 Shakira - Te Aviso, Te Anuncio.mp3
X 212944 -rwxr-xr-x 0 0 2998812 10-Jul-2008 14:06 Shakira - Te Dejo Madrid.MP3
X 213036 -rwxr-xr-x 0 0 3314528 10-Jul-2008 14:06 Shakira - Te Espero Sentada.mp3
X 213138 -rwxr-xr-x 0 0 4206964 10-Jul-2008 14:06 Shakira - The Day And The Time.mp3
X 213267 -rwxr-xr-x 0 0 5313578 10-Jul-2008 14:06 Shakira - The One.mp3
X 213430 -rwxr-xr-x 0 0 3386296 10-Jul-2008 14:06 Shakira - Timor.mp3
X 213534 -rwxr-xr-x 0 0 4574283 11-Jul-2008 13:32 Shakira - Tu Serás La Historia De Mi Vida.mp3
X 213674 -rwxr-xr-x 0 0 3918994 10-Jul-2008 14:06 Shakira - Un Poco De Amor.mp3
X 213794 -rwxr-xr-x 0 0 6873088 10-Jul-2008 14:06 Shakira - Vuelve.mp3
X 214004 -rwxr-xr-x 0 0 5701778 10-Jul-2008 14:06 Shakira - Whenever, Wherever (Sahara Mix).mp3
X 214179 -rwxr-xr-x 0 0 6244224 10-Jul-2008 14:06 Shakira - Whenever, Wherever.mp3
X 214370 -rwxr-xr-x 0 0 5148128 10-Jul-2008 14:06 Shakira - Your Embrace.mp3
X 214528 -rwxr-xr-x 0 0 4618152 11-Jul-2008 13:32 Shakira - Último Momento.mp3
X 214669 -rwxr-xr-x 0 0 3771068 14-Sep-2008 14:42 Silvestre Revueltas - Alcancias I (Allegro).mp3
X 214785 -rwxr-xr-x 0 0 4099016 14-Sep-2008 14:41 Silvestre Revueltas - Alcancias II (Andantino).mp3
X 214911 -rwxr-xr-x 0 0 4559828 14-Sep-2008 14:41 Silvestre Revueltas - Alcancias III (Allegro Vivo).mp3
X 215051 -rwxr-xr-x 0 0 13271653 14-Sep-2008 14:41 Silvestre Revueltas - Homenaja a Federico Garcia Lorca.mp3
X 215457 -rwxr-xr-x 0 0 7229020 14-Sep-2008 14:41 Silvestre Revueltas - La Noche de los Mayas I - La noche de los Mayas.mp3
X 215678 -rwxr-xr-x 0 0 6082768 14-Sep-2008 14:41 Silvestre Revueltas - La Noche de los Mayas II - La noche de Jaranas.mp3
X 215864 -rwxr-xr-x 0 0 8087927 14-Sep-2008 14:41 Silvestre Revueltas - La Noche de los Mayas III - La Noche de Yucatán.mp3
X 216111 -rwxr-xr-x 0 0 9250899 14-Sep-2008 14:41 Silvestre Revueltas - La Noche de los Mayas IV - La Noche de Encantamiento.mp3
X 216394 -rwxr-xr-x 0 0 6376894 14-Sep-2008 14:41 Silvestre Revueltas - Ocho X Radio.mp3
X 216589 -rwxr-xr-x 0 0 9287469 14-Sep-2008 14:41 Silvestre Revueltas - Planos.mp3
X 216873 -rwxr-xr-x 0 0 7337155 14-Sep-2008 14:41 Silvestre Revueltas - Sensemaya.mp3
X 217097 -rwxr-xr-x 0 0 4463163 14-Sep-2008 14:41 Silvestre Revueltas - Toccata.mp3
X 217234 -rwxr-xr-x 0 0 5968646 13-Jun-2009 13:02 Siouxsie and The Banshees - Arabian Knights.mp3
X 217417 -rwxr-xr-x 0 0 7113012 13-Jun-2009 13:02 Siouxsie and The Banshees - Halloween.mp3
X 217635 -rwxr-xr-x 0 0 8451316 13-Jun-2009 13:02 Siouxsie and The Banshees - Head Cut.mp3
X 217893 -rwxr-xr-x 0 0 8144540 13-Jun-2009 13:02 Siouxsie and The Banshees - Into The Light.mp3
X 218142 -rwxr-xr-x 0 0 10745911 13-Jun-2009 13:02 Siouxsie and The Banshees - Monitor.mp3
X 218470 -rwxr-xr-x 0 0 11713909 13-Jun-2009 13:02 Siouxsie and The Banshees - Night Shift.mp3
X 218828 -rwxr-xr-x 0 0 7009364 13-Jun-2009 13:02 Siouxsie and The Banshees - Sin In My Heart.mp3
X 219042 -rwxr-xr-x 0 0 6369882 13-Jun-2009 13:02 Siouxsie and The Banshees - Spellbound.mp3
X 219237 -rwxr-xr-x 0 0 13550422 13-Jun-2009 13:02 Siouxsie and The Banshees - Voodoo Dolly.mp3
X 219651 -rwxr-xr-x 0 0 3957414 18-Feb-2009 13:41 Soundgarden - Spoonman.mp3
X 219772 -rwxr-xr-x 0 0 6528896 1-Aug-2008 00:00 Stars - Liar.mp3
X 219972 -rwxr-xr-x 0 0 2200012 2-Nov-2008 10:49 Sublime - Santeria.mp3
X 220040 -rwxr-xr-x 0 0 5421568 1-Aug-2008 00:00 Switchblade Symphony - Clown.mp3
X 220206 -rwxr-xr-x 0 0 4803617 15-Jun-2008 13:15 Tenacious D - The Metal.mp3
X 220353 -rwxr-xr-x 0 0 10521893 15-Jun-2008 13:15 The Beatles - Fly On The Wall.mp3
X 220675 -rwxr-xr-x 0 0 4050144 1-Aug-2008 00:00 The Doors - Ghost Song.mp3
X 220799 -rwxr-xr-x 0 0 1527429 1-Aug-2008 00:00 The Doors - Horse Latitudes.mp3
X 220846 -rwxr-xr-x 0 0 2833261 14-Aug-2008 21:25 The Doors - Spanish Caravan.mp3
X 220933 -rwxr-xr-x 0 0 4143697 17-Nov-2008 12:49 The Engine Room - A Perfect Lie.mp3
X 221060 -rwxr-xr-x 0 0 5354812 28-Oct-2008 11:29 The Flaming Lips - The W.A.N.D..mp3
X 221224 -rwxr-xr-x 0 0 8246766 28-Oct-2008 11:29 The Flaming Lips - Yeah Yeah Yeah Song.mp3
X 221476 -rwxr-xr-x 0 0 3101010 14-Aug-2008 21:25 The Icicle Works - Wild Mountain Thyme.mp3
X 221571 -rwxr-xr-x 0 0 5926850 1-Aug-2008 00:00 The Killers - Read My Mind.mp3
X 221752 -rwxr-xr-x 0 0 1986587 1-Aug-2008 00:00 The Kinks - Wicked Annabella.mp3
X 221813 -rwxr-xr-x 0 0 3658627 8-Jun-2008 18:58 The Kooks - Always Where I Need To Be.mp3
X 221925 -rwxr-xr-x 0 0 4688363 8-Jun-2008 18:58 The Kooks - Shine On.mp3
X 222069 -rwxr-xr-x 0 0 3612609 21-Jul-2008 13:44 The Rolling Stones - Paint It Black.mp3
X 222180 -rwxr-xr-x 0 0 5264064 15-Jun-2008 13:15 The Strokes - Reptilia.mp3
X 222341 -rwxr-xr-x 0 0 7251447 14-Aug-2008 21:25 Thievery Corporation - Focus On.mp3
X 222563 -rwxr-xr-x 0 0 4601836 14-Aug-2008 21:25 Thievery Corporation - Lebanese Blonde.mp3
X 222704 -rwxr-xr-x 0 0 12308577 17-Nov-2008 12:49 Third Ear Band - Area Three.mp3
X 223080 -rwxr-xr-x 0 0 8002979 17-Nov-2008 12:49 Third Ear Band - Dragon Lines.mp3
X 223325 -rwxr-xr-x 0 0 5517536 17-Nov-2008 12:49 Third Ear Band - Druid One.mp3
X 223494 -rwxr-xr-x 0 0 12844268 17-Nov-2008 12:49 Third Ear Band - Egyptian Book Of Dead.mp3
X 223886 -rwxr-xr-x 0 0 15164962 17-Nov-2008 12:49 Third Ear Band - Ghetto Raga.mp3
X 224349 -rwxr-xr-x 0 0 4047008 17-Nov-2008 12:49 Third Ear Band - Lark Rise.mp3
X 224473 -rwxr-xr-x 0 0 9389405 17-Nov-2008 12:49 Third Ear Band - Mosaic.mp3
X 224760 -rwxr-xr-x 0 0 5075171 17-Nov-2008 12:49 Third Ear Band - Stone Circle.mp3
X 224915 -rwxr-xr-x 0 0 3534847 18-Feb-2009 13:41 This Mortal Coil - A Single Wish.mp3
X 225023 -rwxr-xr-x 0 0 4191878 18-Feb-2009 13:41 This Mortal Coil - Another Day.mp3
X 225151 -rwxr-xr-x 0 0 5569263 18-Feb-2009 13:41 This Mortal Coil - Barramundi.mp3
X 225321 -rwxr-xr-x 0 0 5482118 18-Feb-2009 13:41 This Mortal Coil - Dreams Made Flesh.mp3
X 225489 -rwxr-xr-x 0 0 5520989 18-Feb-2009 13:41 This Mortal Coil - Fond Affections.mp3
X 225658 -rwxr-xr-x 0 0 6337890 18-Feb-2009 13:41 This Mortal Coil - Fyt.mp3
X 225852 -rwxr-xr-x 0 0 5225700 18-Feb-2009 13:41 This Mortal Coil - Holocaust.mp3
X 226012 -rwxr-xr-x 0 0 5029975 18-Feb-2009 13:41 This Mortal Coil - Kangaroo.mp3
X 226166 -rwxr-xr-x 0 0 5380554 18-Feb-2009 13:41 This Mortal Coil - Not Me.mp3
X 226331 -rwxr-xr-x 0 0 5061443 18-Feb-2009 13:41 This Mortal Coil - Song To The Siren.mp3
X 226486 -rwxr-xr-x 0 0 5981162 18-Feb-2009 13:41 This Mortal Coil - The Last Ray.mp3
X 226669 -rwxr-xr-x 0 0 6477697 18-Feb-2009 13:41 This Mortal Coil - Waves Become Wings.mp3
X 226867 -rwxr-xr-x 0 0 2658153 17-Nov-2008 12:49 Tom McRae - You Cut Her Hair.mp3
X 226949 -rwxr-xr-x 0 0 3290188 15-Jun-2008 13:15 Weezer - My Name Is Jonas.mp3
X 227050 -rwxr-xr-x 0 0 3898016 28-Oct-2008 11:29 Wisin Y Yandel - Bailando Sexy.mp3
X 227169 -rwxr-xr-x 0 0 4261144 28-Oct-2008 11:29 Wisin Y Yandel - Sexy Movimiento.mp3
227300 drwxr-xr-x 0 0 0 10-Aug-2009 22:39 iTunes
228399 drwxr-xr-x 0 0 0 10-Aug-2009 22:41 Fonoteca Vieja
X1245124 drwxr-xr-x 0 0 0 23-Aug-2009 17:34 Genesis - Discography.www.lokotorrents.com
X 0 -rwxr-xr-x 0 0 0 25-Aug-2009 14:06 Arzachel - Metempsychosis.mp3.reapeaks
X1312934 -rwxr-xr-x 0 0 152964 25-Aug-2009 14:06 Arzachel - Metempsychosis.mp3.reapindex
X1312939 -rwxr-xr-x 0 0 2485242 25-Aug-2009 14:07 Arzachel - Metempsychosis.mp3.reapeaks
1572866 drwxr-xr-x 0 0 0 25-Jul-2011 22:41 3
1 * FAT32 LBA 0 1 1 60799 254 63 976751937
The files shown are indeed some of my music files. However, I'm starting to freak out because I can't see any of my pictures or any other important files, for that matter.
How should I proceed?
#5 Post by Fiona »
Your music files are only copied to your disk.
That's why there is no directory.
But there are two folder/directories where your photos are supposed to be in?
They'are;
I'd suggest to copy your files first
At the bottom of the screen are all the commands.
Standard directory is your testdisk folder.
If you want to change ist, you can mark that two dots and press enter, you'll get one directory up.
To enter any folder, just check it and use your right arrow key on your keyboard.
Fael
#6 Post by Fael »
Fiona wrote:Your music files are only copied to your disk.
They'are;
Alright, I've copied all the available files. However, this was all music! There are no pictures, software, nor other files I care about on that list. Plus I still cannot mount it. :cry:
Is there anything I can do to recover the other files? Or at least to make my USB drive usable again?
Thanks for helping me out, Fiona!
Fael
#7 Post by Fael »
I just noticed that the partition found by Testdisk has a FAT32 file system. However, the original file system was NTFS. Is there anyway I can repair my disk?
#8 Post by Fiona »
You can have a Diagnose from your current partition changing it to NTFS.
But before it would be advisable to run Deeper Search.
As far as I've seen in your logs, you ran only Quick Search.
This can take a while, because the backup of the boot sector is located at the end of the partition and probably your disk.
Please run Deeper Search first.
Fael
#9 Post by Fael »
I've run Deeper Search multiple times (but didn't record any logs from those searches) and it didn't find any other partition. It only finds the one FAT32 partition. Again, thanks for helping me out!
