it says petition: write error
and when i go in to deep search it says
Warning: Incorrect number of heads/cylinder 1 (NTFS) != 255 (HD)
Warning: Incorrect number of sectors per track 1 (NTFS) != 63 (HD)
HPFS - NTFS 0 4 5 45599 165 6 732558080 [My Book]
Invalid FAT boot sector
0 D FAT32 LBA 225025 201 30 401564 82 20 2836091529
new 3tb HDD I deleted partition having errors recoving Topic is solved
Re: new 3tb HDD I deleted partition having errors recoving
If you get I/O errors, CRC problems or the disk have bad sectors, you should clone the disk to a new empty one using GNU ddrescue as explained in http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
but how can it be damaged x.x i just got it 2 days ago ad all i did was delete the partition accadently when i ment to delete another partition of a differnt drivecgrenier wrote:If you get I/O errors, CRC problems or the disk have bad sectors, you should clone the disk to a new empty one using GNU ddrescue as explained in http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
btw i have a
3TB WD My Book Essential usb 3.0 External Hardrive
Formatted NTFS for xp/vista/7
P/N: WDBACW0030HBK-01
Model: WDBACW0030HBK-NESN
*note* it is a backup drive only, it is not for a OS
