Macos 64 bit Application
mmccur5619
#1 Post by mmccur5619 »
Will TestDisk & PhotoRec have a 64 bit Version for Mac? Thank You!
Re: 64 bit Application
Not for the moment but it can be compiled on a recent Mac computer as described in https://www.cgsecurity.org/testdisk.pdf
mmccur5619
Re: Macos 64 bit Application
#3 Post by mmccur5619 »
Thank You for your reply!
AlexLowery
#4 Post by AlexLowery »
Will it works on macbook pro retina late 2013?
#5 Post by cgrenier »
32-bit application should work but you may have problems with macOS High Sierra 10.13.4 or later: https://support.apple.com/en-us/HT208436
