I have Seagate 1TB external hard disk which has two partitions one is empty
The first partition of the disk seems corrupted due to power failure while plugged in my desktop which has all of my personal data
With testdisk, I did find partitions but can't able to list files on the first partition
Added testdisk.log below
Please help me recover data it has most of my personal files some of them don't even have an online backup
Thanks in advance
Tue Aug 13 22:38:24 2019
OS: Linux, kernel 5.0.0-23-generic (#24~18.04.1-Ubuntu SMP Mon Jul 29 16:12:28 UTC 2019) x86_64
Compiler: GCC 7.2
ext2fs lib: 1.44.1, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Seagate BUP Slim BK, FW:0304
Disk /dev/mapper/nvme0n1p1_crypt - 102 GB / 95 GiB - 200189952 sectors, sector size=512
Disk /dev/mapper/nvme0n1p4_crypt - 406 GB / 378 GiB - 794329088 sectors, sector size=512
Disk /dev/dm-0 - 102 GB / 95 GiB - 200189952 sectors, sector size=512
Disk /dev/dm-1 - 406 GB / 378 GiB - 794329088 sectors, sector size=512
Disk /dev/sda - 1000 GB / 931 GiB - Seagate BUP Slim BK
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
Info: size boot_sector 1855868921, partition 1855868928
NTFS at 115522/159/30
1 * HPFS - NTFS 0 32 33 115522 159 29 1855868928
2 P HPFS - NTFS 115522 159 30 121601 57 56 97652736
Failed to open ntfs attribute: No such file or directory
Failed to load $MFT: No such file or directory
NTFS at 0/32/33
filesystem size 1855868921
mftmirr_lcn 2
HPFS - NTFS 0 32 33 115522 159 22 1855868921
NTFS, blocksize=4096, 950 GB / 884 GiB
filesystem size 97652736
mft_lcn 4
mftmirr_lcn 6103295
NTFS, blocksize=4096, 49 GB / 46 GiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1855868928 linear /dev/sda 2048" | dmsetup create test0
echo "0 97652736 linear /dev/sda 1855870976" | dmsetup create test1
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 23-Jun-2019 16:44 .
5 dr-xr-xr-x 0 0 0 23-Jun-2019 16:44 ..
36 dr-xr-xr-x 0 0 0 23-Jun-2019 16:44 System Volume Information
Not an exFAT boot sector.
Can't open filesystem filesystem seems damaged on External HDD
Re: Can't open filesystem filesystem seems damaged on External HDD
Try TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
If it doesn't work, try PhotoRec instead.
