Misused Testdisk please help Deleted volume in windows 10 pro installation
Piolon
#1 Post by Piolon »
This is the first time I make this mistake and today I made it a second time - I posted that on a separate question -.
I was installing Windows 10 pro and accidentally deleted a volume that i dont recall if it was xFAT or NTFS... but most probably xFAT,
to allegedly install windows in it. because it was the same size of the drive I use to reinstall windows.
Once I noticed that, I quit the installation, turned off the machine without even formatting the disk, and unplugged the drive.
Upon reading/hovering over a bunch of sites after googling, I ended up naturally in Testdisk, and then I when remembered I had used
testdisk to recover other hd on another ocassion a long time ago. I think it was an SD card.
I then plugged the HD which was unallocated and rushed to create or write on top a new partition table
by selecting the change the type and not using the backup. At that time I had not read enough and misused this tool. My bad.
I could then see the drive but it seemed empty. It had assigned a letter to it.
Yet runnig photorec it can see all the data and lost of files. Ran it for hours and piled uo not only a lot of trash but also renamed files.
I read somewhere that that was the way it did it. I stopped it, and left it there. Also deleted the recoverd files as they took a bunch of space.
Now today that I have time to fix it, if I go to analyze, I now that I have read a little more about it - because I made the same mistake again, this time I did it on a spanned drive that I forgot to unplug - that the other thread I just posted -
It shows the following error:
No Backup BOOT when I try to load from backup with L after analyzing
Also it shows this It says
Status OK
ntfs_boot_sector: Cant read backup boot sector
Status: Bad
Sectors are not identical.
A valid NTFS must be present ....
I also have a log of a session when I messed it up
you can see there I was trying to see which drive was at the beginning that was messed up.
At that moment everything was plugged in. Then when I figured it
out I I think wrote an MBR new type on top and did not try to access the backup..
Mon Jul 8 00:35:43 2019
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=960197124096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=960197124096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=960197124096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdi)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdj)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdk)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdl)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdm)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdn)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdo)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdp)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=960197124096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=960197124096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=960197124096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=6001175126016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive10)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive11)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive12)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive13)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive14)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive15)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=210092687360
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=269482983424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=319478038528
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=480099786752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=524288000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=960192929792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=6001039245312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=6001039245312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=6001039245312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=480099786752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=480099786752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=480099958784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=480108545024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=480108545024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=7921410768896
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200AAJS-22VWA0, S/N:WD-WCARW4727600, FW:12.01B02
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20PURZ-85GU6Y0, S/N:WD-WCC4M7AYUNPK, FW:80.00A80
Disk /dev/sdc - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - ADATA SP550, S/N:2G2620044862, FW:P0330AA
Disk /dev/sdd - 960 GB / 894 GiB - CHS 116737 255 63, sector size=512 - ADATA SP550, S/N:2G0420056610, FW:O1126A
Disk /dev/sde - 960 GB / 894 GiB - CHS 116737 255 63, sector size=512 - ADATA SP550, S/N:2G2220084666, FW:O1126A
Disk /dev/sdf - 960 GB / 894 GiB - CHS 116737 255 63, sector size=512 - ADATA SP550, S/N:2G1820078347, FW:O1126A
Disk /dev/sdg - 6001 GB / 5589 GiB - CHS 729601 255 63, sector size=512 - ST6000DM001-1YW11C, S/N:ZA10F0MG, FW:DN02
Disk /dev/sdh - 6001 GB / 5589 GiB - CHS 729601 255 63, sector size=512 - ST6000DM001-1YW11C, S/N:ZA109L91, FW:DN02
Disk /dev/sdi - 6001 GB / 5589 GiB - CHS 729601 255 63, sector size=512 - ST6000DM001-1YW11C, S/N:ZA10B4LM, FW:DN02
Disk /dev/sdj - 6001 GB / 5589 GiB - CHS 729601 255 63, sector size=512 - ST6000DM001-1YW11C, S/N:ZA10BKG7, FW:DN02
Disk /dev/sdk - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDXPS480G, S/N:00A123456884, FW:0107
Disk /dev/sdl - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDXPS480G, S/N:00A1234567C8, FW:0107
Disk /dev/sdm - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDXPS480G, S/N:00A1234567C8, FW:0107
Disk /dev/sdn - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDXPS480G, S/N:00A123456884, FW:0107
Disk /dev/sdo - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDXPS480G, S/N:00A1234568D3, FW:0107
Disk /dev/sdp - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDXPS480G, S/N:00A1234568D3, FW:0107
Drive W: - 7921 GB / 7377 GiB - CHS 963056 255 63, sector size=512
Disk /dev/sdm - 480 GB / 447 GiB - SanDisk SDSSDXPS480G
Analyse Disk /dev/sdm - 480 GB / 447 GiB - CHS 58369 255 63
NTFS at 0/130/3
2 P HPFS - NTFS 0 130 3 58369 80 63 937694896 [FIX3]
NTFS at 0/130/3
filesystem size 937694896
mftmirr_lcn 2
NTFS, blocksize=4096, 480 GB / 447 GiB
file_pread(16,16,buffer,937703088(58369/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(16,1,buffer,937703088(58369/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(16,8,buffer,937703096(58369/81/9)) lseek err Invalid argument
file_pread(16,3,buffer,937703104(58369/81/17)) lseek err Invalid argument
file_pread(16,3,buffer,937703151(58369/82/1)) lseek err Invalid argument
file_pread(16,8,buffer,937703167(58369/82/17)) lseek err Invalid argument
file_pread(16,11,buffer,937703214(58369/83/1)) lseek err Invalid argument
file_pread(16,2,buffer,937705136(58369/113/33)) lseek err Invalid argument
* HPFS - NTFS 0 130 3 58369 86 21 937695232 [FIX3]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 7-Jul-2019 21:38 .
5 dr-xr-xr-x 0 0 0 7-Jul-2019 21:38 ..
37 dr-xr-xr-x 0 0 0 7-Jul-2019 13:13 $RECYCLE.BIN
40 dr-xr-xr-x 0 0 0 12-May-2017 11:11 DAY 11
31964 dr-xr-xr-x 0 0 0 21-May-2017 02:21 DAY0b
32819 dr-xr-xr-x 0 0 0 22-May-2017 12:44 DAY0z
45346 dr-xr-xr-x 0 0 0 23-Nov-2018 10:15 PATCHED ASSEMBLY 5
45350 dr-xr-xr-x 0 0 0 25-Jun-2019 12:04 System Volume Information
31848 dr-xr-xr-x 0 0 0 5-Jun-2017 11:49 day 12a
45333 dr-xr-xr-x 0 0 0 23-Nov-2018 10:02 fall 16
45354 dr-xr-xr-x 0 0 0 25-Jun-2019 14:59 found.000
45347 -r--r--r-- 0 0 29035893 20-Nov-2018 08:29 THEFIXER pilot VIZCAYAFILMS 2018 NO trailers.prproj
1 * HPFS - NTFS 0 130 3 58369 86 21 937695232 [FIX3]
Disk /dev/sdn - 480 GB / 447 GiB - SanDisk SDSSDXPS480G
Analyse Disk /dev/sdn - 480 GB / 447 GiB - CHS 58369 255 63
NTFS at 0/32/33
Info: size boot_sector 937697280, partition 937712002
1 P HPFS - NTFS 0 32 33 58369 254 63 937712002 [Data 3]
NTFS at 0/32/33
filesystem size 937697280
mftmirr_lcn 2
HPFS - NTFS 0 32 33 58369 21 20 937697280 [Data 3]
file_pread(17,2,buffer,937703423(58369/86/21)) lseek err Invalid argument
file_pread(17,1,buffer,937703423(58369/86/21)) lseek err Invalid argument
file_pread(17,2,buffer,937703424(58369/86/22)) lseek err Invalid argument
file_pread(17,8,buffer,937703168(58369/82/18)) lseek err Invalid argument
file_pread(17,1,buffer,937703168(58369/82/18)) lseek err Invalid argument
file_pread(17,8,buffer,937703296(58369/84/20)) lseek err Invalid argument
file_pread(17,6,buffer,937703426(58369/86/24)) lseek err Invalid argument
file_pread(17,8,buffer,937703432(58369/86/30)) lseek err Invalid argument
file_pread(17,3,buffer,937703440(58369/86/38)) lseek err Invalid argument
file_pread(17,3,buffer,937703487(58369/87/22)) lseek err Invalid argument
file_pread(17,8,buffer,937703503(58369/87/38)) lseek err Invalid argument
file_pread(17,11,buffer,937703550(58369/88/22)) lseek err Invalid argument
file_pread(17,2,buffer,937705472(58369/118/54)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 58369 21 20 937697280 [Data 3]
38 dr-xr-xr-x 0 0 0 7-Jul-2019 21:13 $RECYCLE.BIN
46 dr-xr-xr-x 0 0 0 12-Jun-2017 10:55 SFX SCORES
36 dr-xr-xr-x 0 0 0 20-Nov-2016 13:43 System Volume Information
434 dr-xr-xr-x 0 0 0 12-May-2017 11:27 TITLES
14533 dr-xr-xr-x 0 0 0 18-May-2017 20:29 animations
24211 dr-xr-xr-x 0 0 0 23-Nov-2018 10:42 fall 16 catchup 3
14558 dr-xr-xr-x 0 0 0 23-May-2017 00:59 indiegogo new
14563 dr-xr-xr-x 0 0 0 5-Jun-2017 12:14 movie 8
432 dr-xr-xr-x 0 0 0 23-May-2017 20:34 vfx
436 dr-xr-xr-x 0 0 0 23-May-2017 01:03 xmls
27609 -r--r--r-- 0 0 29035893 20-Nov-2018 08:29 THEFIXER pilot VIZCAYAFILMS 2018 NO trailers.prproj
1 * HPFS - NTFS 0 32 33 58369 21 20 937697280 [Data 3]
Disk /dev/sdp - 480 GB / 447 GiB - SanDisk SDSSDXPS480G
Analyse Disk /dev/sdp - 480 GB / 447 GiB - CHS 58369 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 58369 254 63 937712002 [Data 5]
NTFS at 0/32/33
mftmirr_lcn 2
HPFS - NTFS 0 32 33 58369 21 20 937697280 [Data 5]
file_pread(19,2,buffer,937703423(58369/86/21)) lseek err Invalid argument
file_pread(19,1,buffer,937703423(58369/86/21)) lseek err Invalid argument
file_pread(19,2,buffer,937703424(58369/86/22)) lseek err Invalid argument
file_pread(19,8,buffer,937703168(58369/82/18)) lseek err Invalid argument
file_pread(19,1,buffer,937703168(58369/82/18)) lseek err Invalid argument
file_pread(19,8,buffer,937703296(58369/84/20)) lseek err Invalid argument
file_pread(19,6,buffer,937703426(58369/86/24)) lseek err Invalid argument
file_pread(19,8,buffer,937703432(58369/86/30)) lseek err Invalid argument
file_pread(19,3,buffer,937703440(58369/86/38)) lseek err Invalid argument
file_pread(19,3,buffer,937703487(58369/87/22)) lseek err Invalid argument
file_pread(19,8,buffer,937703503(58369/87/38)) lseek err Invalid argument
file_pread(19,11,buffer,937703550(58369/88/22)) lseek err Invalid argument
file_pread(19,2,buffer,937705472(58369/118/54)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 58369 21 20 937697280 [Data 5]
1 * HPFS - NTFS 0 32 33 58369 21 20 937697280 [Data 5]
Disk /dev/sdo - 480 GB / 447 GiB - SanDisk SDSSDXPS480G
Analyse Disk /dev/sdo - 480 GB / 447 GiB - CHS 58369 255 63
NTFS at 0/130/3
NTFS at 0/130/3
filesystem size 937695232
mftmirr_lcn 2
file_pread(18,8,buffer,937703424(58369/86/22)) lseek err Invalid argument
file_pread(18,1,buffer,937703424(58369/86/22)) lseek err Invalid argument
file_pread(18,1,buffer,937703425(58369/86/23)) lseek err Invalid argument
file_pread(18,14,buffer,937703426(58369/86/24)) lseek err Invalid argument
file_pread(18,3,buffer,937703440(58369/86/38)) lseek err Invalid argument
file_pread(18,3,buffer,937703487(58369/87/22)) lseek err Invalid argument
file_pread(18,8,buffer,937703503(58369/87/38)) lseek err Invalid argument
file_pread(18,11,buffer,937703550(58369/88/22)) lseek err Invalid argument
file_pread(18,2,buffer,937705472(58369/118/54)) lseek err Invalid argument
5 dr-xr-xr-x 0 0 0 5-Jul-2019 16:58 .
5 dr-xr-xr-x 0 0 0 5-Jul-2019 16:58 ..
39 dr-xr-xr-x 0 0 0 5-Jul-2019 02:08 $RECYCLE.BIN
36 dr-xr-xr-x 0 0 0 5-Jul-2019 02:08 System Volume Information
write!
NTFS at 0/130/3
Backup partition structure
partition_save
NTFS at 0/130/3
mftmirr_lcn 2
interface_load
Disk /dev/sdo - 480 GB / 447 GiB - CHS 58369 255 63 Mon Jul 8 00:37:55 2019
Change partition type:
L HPFS - NTFS 0 130 3 58369 86 21 937695232
interface_load
NTFS at 0/130/3
interface_load
i have todays log too with 7.2 if -
WHAT SHOULD I DO TO REBUILD THIS MBR? IM LOST
Dont want to touch it again since I already messed it up twice, once when I deleted the volume and the second when I decided to re do the mbr
with a new type without knowing anything.... not that I know anything now.... :mrgreen:
Thank you for your awesome tool!
cheers,
piolon
Re: Misused Testdisk please help Deleted volume in windows 10 pro installation
It looks like the partition on /dev/sdo has been reformated (or deleted and recreated).
The only workaround I know is using PhotoRec to recover the data from this disk but the files won't have their original filenames.
