[HELP] WD My Passport 2TB suddenly RAW
steevee
#1 Post by steevee »
I have Western Digital 2TB (External HDD without Any OS'es Inside/Just Regular Files), but suddenly RAW (not NTFS anymore :cry: )
I can't view any files/structures with TestDisk.
When I choosed Intel (Intel/PC Partition) on the Partition Table list and Start to Analyse, It's shown
Warning: Bad Ending Head (CHS and LBA don't match)
No Partition is Bootable
Try to Locate Partition
But, When I choosed EFI GPT Partition on the Partition Table list and Start to Analyse, It's shown
check_FAT: can't read FAT Boot Sector
No FAT, NTFS, ext2, JFS, Reiser, cramfs, or XFS marker
Please someone Help Me
Re: [HELP] WD My Passport 2TB suddenly RAW
Run TestDisk, select /dev/sdb, EFI GPT, Advanced, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and restart your computer.
If it doesn't work, try PhotoRec.
Good luck
steevee
#3 Post by steevee »
cgrenier wrote: 19 Aug 2019, 06:41 Run TestDisk, select /dev/sdb, EFI GPT, Advanced, Boot, RebuildBS, List.
Good luck
There's no Boot (RebuildBS) options
I tried PhotoRec_Win.exe and seem like this
Force the type using the "Type" menu to MS Data and NTFS.
The time displayed by PhotoRec seems too high. Does your disk make some unusual noise ?
steevee
#5 Post by steevee »
cgrenier wrote: 19 Aug 2019, 19:37 Force the type using the "Type" menu to MS Data and NTFS.
No Noise
#6 Post by recuperation »
Slow reading speeds often indicate read errors.
Please check the SMART parameters (health) of your drive with smartmontools or Crystaldiskinfo.
Post your smartmontools logfile here.
steevee
#7 Post by steevee »
recuperation wrote: 20 Aug 2019, 17:19 Slow reading speeds often indicate read errors.
C:\Program Files\smartmontools\bin>smartctl.exe -i /dev/sdc
smartctl 7.0 2018-12-30 r4883 [x86_64-w64-mingw32-2008r2-sp1] (sf-7.0-1)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     WDC WD20SDZW-11JJ8S1
Serial Number:    WD-WXW1AA8JL5EP
LU WWN Device Id: 5 0014ee 210a568d6
Firmware Version: 01.01A01
User Capacity:    2,000,365,379,584 bytes [2.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Aug 21 09:35:55 2019 SEAST
SMART support is: Enabled
C:\Program Files\smartmontools\bin>smartctl.exe -H /dev/sdc
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
Failed Attributes:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   001   001   051    Pre-fail  Always   FAILI
NG_NOW 123464
C:\Program Files\smartmontools\bin>smartctl.exe -t short /dev/sdc
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line
mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mod
e" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Wed Aug 21 09:38:58 2019
Use smartctl -X to abort test.
C:\Program Files\smartmontools\bin>smartctl.exe -l selftest /dev/sdc
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA
_of_first_error
# 1  Short offline       Completed without error       00%      1822         -
# 2  Short offline       Completed: unknown failure    90%       283         -
C:\Program Files\smartmontools\bin>smartctl.exe -t long /dev/sdc
Sending command: "Execute SMART Extended self-test routine immediately in off-li
ne mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line
mode" successful.
Testing has begun.
Please wait 266 minutes for test to complete.
Test will complete after Wed Aug 21 14:07:40 2019
#8 Post by recuperation »
Please stop running the extended test because the only tolerable activity is to duplicate the drive.
Use the -a parameter to just read the current state of parameters without testing.
I read this message for the first time.
Do not use Testdisk or Photorec on this drive.
You have to decide if you risk further degradation by running ddrescue to create a copy of the readable sectors or if you contact professional companies like Kroll or Attingo for help.
Good luck!
