HELP---PLEASE FOUND MY FILES!!!
DARKJOKER5
#1 Post by DARKJOKER5 »
after reading several posts here I stopped the disk "analize cylinders" run and ended up on a screen that showed my file folders, I was able to copy them but I cant figure out how to send them to the "destination" which is another hard drive that has enough space to hold them (files are 358gb). including pics I took with my phone of the screen...I may just be over looking it but it only seems to give me a list of places I can send thye copies to on my "C" drive??
If anyone knows or see's the simplest way to find the path I need DRIVE "E" please advise!
THANKS, DJ
Re: HELP---PLEASE FOUND MY FILES!!!
Use the left arrow keys until you get the list of drives and select E:
Another possibility is to move testdisk to the E: drive and start it from here.
