I have a 3TB drive. I had a ext4 partition covering the whole drive.
I then accidentally deleted the partition (mixed up drive) and installed a CEPH OSD (which I think makes a Linux LVM on that disk?)
There was nearly nothing written onto the disk other then the partition info (I think somethin like 64Kb) before I realized and deleted the CEPH OSD and unmounted.
I tried using Testdisk to recover the partition however it does not find it.
Using PhotoRec I can recover many files. Is there a possibillity to recover the ext4 partition though?
Thank you
Daniel
Recover ext4 partition deleted & overwritten
Re: Recover ext4 partition deleted & overwritten
TestDisk should be able to find the partition using Deeper Search (TestDisk, Analyse, Quick Search, Stop, Deeper Search...) using the ext4 backup superblock.
it finds lots of partitions (?) that cannot be recovered:
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63
The harddisk (3000 GB / 2794 GiB) seems too small! (< 5642 GB / 5254 GiB)
> MS Data 63703038 5924233213 5860530176
MS Data 89917438 5950447613 5860530176
MS Data 163842046 6024372221 5860530176 MS Data 191105022 6051635197 5860530176
MS Data 573310974 6433841149 5860530176
MS Data 629409790 6489939965 5860530176
MS Data 819202046 6679732221 5860530176
MS Data 1719928830 7580459005 5860530176
MS Data 2143554616 8004084791 5860530176
MS Data 2143646424 8004176599 5860530176
[ Continue ]
ext4 blocksize=4096 Large_file Sparse_SB Recover, 3000 GB / 2794 GiB
>P MS Data 24296 58740455 58716160
P Mac HFS 1342017428 1342148516 131089
P MS Data 2475863980 2482764109 6900130 [BsF^CM-2M-3 @M-+M-|c ^R
P MS Data 2962917105 2969689758 6772654 [N~[aQM-5P~V|1~L^^~K
P Mac HFS 3052294036 3052425124 131089
