question for a champion
rythomax
#1 Post by rythomax »
hi all ,
my usb stick wont : format, resize, shrink, delete, nothink to do with this stick,
there is some images with testdisk :
i've test all windows 3party softwares: minitool, easyus, ....all, without result
in linux gparted, parted, fdisk, testdisk, all without result
in linux parted he told me that that a partition 1 overlap the partition 2 in the end
this is a high level degree of complexity, only the profesionnal can!
i'm ready to use linux or windows..
Re: question for a champion
If you want to recover some lost data, try PhotoRec.
As you failed to format this usb stick, get a new one! Use the warranty if possible.
