I'm trying to recover veeam data from a formatted partition.
In the PhotoRec specifications, the .vbm type is indicated as supported, but when I try to find it in the list of file types it does not appear.
Only the vib type is present.
How do I enable searching for vbm files?
Would it also be possible to search for vrb and vbk files?
Thank you
Recover veeam data
Re: Recover veeam data
vbm are recovered by default by PhotoRec, they are part of the "tx?" file family.
I have no vrb or vbk file samples, so I don't know if they have magic values/constants that can be used to identify and recover these types of files.
