Hi all,
A friend had her SD card fail in her Android phone. I'm trying to get as much as I can off it, but I've not really had luck so far and it's been something of a nightmare.
It's a 32gb SD card, which when plugged into windows doesn't get detected immediately. Instead, it causes Explorer to become quite slow, and when it eventually shows as a drive, it's in RAW format. Trying to open it causes explorer to crash.
I've tried both Photorec and Testdisk to see if I can get anything off it. Each time it takes about 5 minutes to locate the disk, and then going from each option to the next via "Proceed" etc is extremely slow. I'm assuming this is symptomatic of a corrupt SD card?
Has anyone got any ideas on the best way for me to get something off this, if at all possible?
I've got a .dd of the entire SD card that I'm running Photorec on at the moment, but if that doesn't work is there any other options?
Cheers
Chris
Corrupt (pretty sure) SD card recovery
Re: Corrupt (pretty sure) SD card recovery
It looks like a damaged SD card, software solution will not help in your case.
You should contact a data recovery company.
