External backup disk crashed from 2 partitions to 1.
heinflhs
#1 Post by heinflhs »
Hi, I used an external WD elements 1.5TB for backup. I partitioned the drive into F: for my backup and G for movies that I downloaded. Probably the FAT sector was damaged and I did not notice that. When I looked up the drives I saw F but without files. Then I realised that I was in trouble. On this moment windows only sees the F drive, G is "gone".
The computers sees the drives like this:
disks F is empty.jpg (117.46 KiB) Viewed 3290 times
and half of the WD size is gone. Now I've tried several methods in Testdisk, however I failed to retrieve the G partition. When I'm able to retrieve it I might be able to recover at least a part of the movies. Unfortunately I have litle knowledge of this matter.
Maybe somebody has dealt with a same problem and could help me out?
Thank's
Hein
Re: External backup disk crashed from 2 partitions to 1.
It looks like your disk has been reformated. Can you post the content of the testdisk.log file after Analyze, Quick Search and Deeper Search ?
If your lost partition isn't found, you can use PhotoRec to recover your data, be careful to store the recovered files on another disk (do not select the source disk as destination), note that it will not recover the original filenames.
heinflhs
#3 Post by heinflhs »
testdisk 7.2 analyse WD Elements 1.5 TB.jpg (89.96 KiB) Viewed 3280 times
Hi, thank's for dealing with my problem.
When I try to perform a quick search this view appears.
heinflhs
#4 Post by heinflhs »
Tue Sep 10 08:15:30 2019
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=1500267937792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=1500267937792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=717728251904
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 860 EVO 500GB, S/N:34534258454e4d30323637343131205420202020, FW:RVT03B6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000528AS, S/N:563941505a425442202020202020202020202020, FW:HP35
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKX-60U6AA0, S/N:2020202057202d44435732433445455a465a4a46, FW:18.01H18
Disk /dev/sdd - 1500 GB / 1397 GiB - CHS 182397 255 63, sector size=512 - WD Elements 10B8, S/N:WXA1A741C2PX, FW:1012
Disk /dev/sdd - 1500 GB / 1397 GiB - WD Elements 10B8
Partition table type: EFI GPT
Analyse Disk /dev/sdd - 1500 GB / 1397 GiB - CHS 182397 255 63
Trying alternate GPT
NTFS at 0/32/33
heads/cylinder 64 (NTFS) != 255 (HD)
sect/track 32 (NTFS) != 63 (HD)
filesystem size 1528391680
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=782536540160, sector_size=512
NTFS at 0/32/33
mftmirr_lcn 2
MS Data 2048 1528393727 1528391680
NTFS, blocksize=4096, 782 GB / 728 GiB
NTFS at 95138/27/58
filesystem size 1401812992
mftmirr_lcn 2
MS Data 126580737 1528393728 1401812992
NTFS found using backup sector, blocksize=4096, 717 GB / 668 GiB
NTFS at 95138/27/58
mftmirr_lcn 2
MS Data 1528393728 2930206719 1401812992 [NieuwVolume]
NTFS, blocksize=4096, 717 GB / 668 GiB
file_pread(7,1,buffer,2930210816(182397/47/51)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,1,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,1,buffer,2930210818(182397/47/53)) lseek err Invalid argument
file_pread(7,1,buffer,2930210819(182397/47/54)) lseek err Invalid argument
file_pread(7,1,buffer,2930210820(182397/47/55)) lseek err Invalid argument
file_pread(7,1,buffer,2930210821(182397/47/56)) lseek err Invalid argument
file_pread(7,1,buffer,2930210822(182397/47/57)) lseek err Invalid argument
file_pread(7,1,buffer,2930210823(182397/47/58)) lseek err Invalid argument
file_pread(7,1,buffer,2930210824(182397/47/59)) lseek err Invalid argument
file_pread(7,1,buffer,2930210825(182397/47/60)) lseek err Invalid argument
file_pread(7,1,buffer,2930210826(182397/47/61)) lseek err Invalid argument
file_pread(7,1,buffer,2930210827(182397/47/62)) lseek err Invalid argument
file_pread(7,1,buffer,2930210828(182397/47/63)) lseek err Invalid argument
file_pread(7,1,buffer,2930210829(182397/48/1)) lseek err Invalid argument
file_pread(7,1,buffer,2930210830(182397/48/2)) lseek err Invalid argument
file_pread(7,1,buffer,2930210831(182397/48/3)) lseek err Invalid argument
file_pread(7,1,buffer,2930210832(182397/48/4)) lseek err Invalid argument
file_pread(7,1,buffer,2930210833(182397/48/5)) lseek err Invalid argument
file_pread(7,1,buffer,2930210834(182397/48/6)) lseek err Invalid argument
file_pread(7,1,buffer,2930210835(182397/48/7)) lseek err Invalid argument
file_pread(7,1,buffer,2930210836(182397/48/8)) lseek err Invalid argument
file_pread(7,1,buffer,2930210837(182397/48/9)) lseek err Invalid argument
file_pread(7,1,buffer,2930210838(182397/48/10)) lseek err Invalid argument
file_pread(7,1,buffer,2930210839(182397/48/11)) lseek err Invalid argument
file_pread(7,1,buffer,2930210840(182397/48/12)) lseek err Invalid argument
file_pread(7,1,buffer,2930210841(182397/48/13)) lseek err Invalid argument
file_pread(7,1,buffer,2930210842(182397/48/14)) lseek err Invalid argument
file_pread(7,1,buffer,2930210843(182397/48/15)) lseek err Invalid argument
file_pread(7,1,buffer,2930210844(182397/48/16)) lseek err Invalid argument
file_pread(7,1,buffer,2930210845(182397/48/17)) lseek err Invalid argument
file_pread(7,1,buffer,2930210846(182397/48/18)) lseek err Invalid argument
file_pread(7,1,buffer,2930210847(182397/48/19)) lseek err Invalid argument
file_pread(7,1,buffer,2930210848(182397/48/20)) lseek err Invalid argument
file_pread(7,1,buffer,2930210849(182397/48/21)) lseek err Invalid argument
file_pread(7,1,buffer,2930210850(182397/48/22)) lseek err Invalid argument
file_pread(7,1,buffer,2930210851(182397/48/23)) lseek err Invalid argument
file_pread(7,1,buffer,2930210852(182397/48/24)) lseek err Invalid argument
file_pread(7,1,buffer,2930210853(182397/48/25)) lseek err Invalid argument
file_pread(7,1,buffer,2930210854(182397/48/26)) lseek err Invalid argument
file_pread(7,1,buffer,2930210855(182397/48/27)) lseek err Invalid argument
file_pread(7,1,buffer,2930210856(182397/48/28)) lseek err Invalid argument
file_pread(7,1,buffer,2930210857(182397/48/29)) lseek err Invalid argument
file_pread(7,1,buffer,2930210858(182397/48/30)) lseek err Invalid argument
file_pread(7,1,buffer,2930210859(182397/48/31)) lseek err Invalid argument
file_pread(7,1,buffer,2930210860(182397/48/32)) lseek err Invalid argument
file_pread(7,1,buffer,2930210861(182397/48/33)) lseek err Invalid argument
file_pread(7,1,buffer,2930210862(182397/48/34)) lseek err Invalid argument
file_pread(7,1,buffer,2930210863(182397/48/35)) lseek err Invalid argument
file_pread(7,1,buffer,2930210864(182397/48/36)) lseek err Invalid argument
file_pread(7,1,buffer,2930210865(182397/48/37)) lseek err Invalid argument
file_pread(7,1,buffer,2930210866(182397/48/38)) lseek err Invalid argument
file_pread(7,1,buffer,2930210867(182397/48/39)) lseek err Invalid argument
file_pread(7,1,buffer,2930210868(182397/48/40)) lseek err Invalid argument
file_pread(7,1,buffer,2930210869(182397/48/41)) lseek err Invalid argument
file_pread(7,1,buffer,2930210870(182397/48/42)) lseek err Invalid argument
file_pread(7,1,buffer,2930210871(182397/48/43)) lseek err Invalid argument
file_pread(7,1,buffer,2930210872(182397/48/44)) lseek err Invalid argument
file_pread(7,1,buffer,2930210873(182397/48/45)) lseek err Invalid argument
file_pread(7,1,buffer,2930210874(182397/48/46)) lseek err Invalid argument
file_pread(7,1,buffer,2930210875(182397/48/47)) lseek err Invalid argument
file_pread(7,1,buffer,2930210876(182397/48/48)) lseek err Invalid argument
file_pread(7,1,buffer,2930210877(182397/48/49)) lseek err Invalid argument
file_pread(7,1,buffer,2930210878(182397/48/50)) lseek err Invalid argument
file_pread(7,1,buffer,2930210879(182397/48/51)) lseek err Invalid argument
file_pread(7,1,buffer,2930210880(182397/48/52)) lseek err Invalid argument
file_pread(7,1,buffer,2930210881(182397/48/53)) lseek err Invalid argument
file_pread(7,1,buffer,2930210882(182397/48/54)) lseek err Invalid argument
file_pread(7,1,buffer,2930210883(182397/48/55)) lseek err Invalid argument
file_pread(7,1,buffer,2930210884(182397/48/56)) lseek err Invalid argument
file_pread(7,1,buffer,2930210885(182397/48/57)) lseek err Invalid argument
file_pread(7,1,buffer,2930210886(182397/48/58)) lseek err Invalid argument
file_pread(7,1,buffer,2930210887(182397/48/59)) lseek err Invalid argument
file_pread(7,1,buffer,2930210888(182397/48/60)) lseek err Invalid argument
file_pread(7,1,buffer,2930210889(182397/48/61)) lseek err Invalid argument
file_pread(7,1,buffer,2930210890(182397/48/62)) lseek err Invalid argument
file_pread(7,1,buffer,2930210891(182397/48/63)) lseek err Invalid argument
file_pread(7,1,buffer,2930210892(182397/49/1)) lseek err Invalid argument
file_pread(7,1,buffer,2930210893(182397/49/2)) lseek err Invalid argument
file_pread(7,1,buffer,2930210894(182397/49/3)) lseek err Invalid argument
file_pread(7,1,buffer,2930210895(182397/49/4)) lseek err Invalid argument
file_pread(7,1,buffer,2930210896(182397/49/5)) lseek err Invalid argument
file_pread(7,1,buffer,2930210897(182397/49/6)) lseek err Invalid argument
file_pread(7,1,buffer,2930210898(182397/49/7)) lseek err Invalid argument
file_pread(_pread(7,1,buffer,2930210837(182397/48/9)) lseek err Invalid argument
file_pread(7,1,buffer,2930210908(182397/49/17)) lseek err Invalid argument
file_pread(7,1,buffer,2930212821(182397/79/40)) lseek err Invalid argument
file_pread(7,1,buffer,2930210909(182397/49/18)) lseek err Invalid argument
file_pread(7,1,buffer,2930212822(182397/79/41)) lseek err Invalid argument
file_pread(7,1,buffer,2930210910(182397/49/19)) lseek err Invalid argument
file_pread(7,1,buffer,2930212823(182397/79/42)) lseek err Invalid argument
file_pread(7,8,buffer,2930210854(182397/48/26)) lseek err Invalid argument
file_pread(7,11,buffer,2930210901(182397/49/10)) lseek err Invalid argument
file_pread(7,1,buffer,2930212824(182397/79/43)) lseek err Invalid argument
file_pread(7,1,buffer,2930210912(182397/49/21)) lseek err Invalid argument
file_pread(7,1,buffer,2930212825(182397/79/44)) lseek err Invalid argument
file_pread(7,1,buffer,2930210913(182397/49/22)) lseek err Invalid argument
file_pread(7,1,buffer,2930212826(182397/79/45)) lseek err Invalid argument
file_pread(7,1,buffer,2930210914(182397/49/23)) lseek err Invalid argument
file_pread(7,1,buffer,2930212827(182397/79/46)) lseek err Invalid argument
file_pread(7,8,buffer,2930210858(182397/48/30)) lseek err Invalid argument
file_pread(7,11,buffer,2930210905(182397/49/14)) lseek err Invalid argument
file_pread(7,1,buffer,2930212828(182397/79/47)) lseek err Invalid argument
file_pread(7,1,buffer,2930210916(182397/49/25)) lseek err Invalid argument
file_pread(7,1,buffer,2930212829(182397/79/48)) lseek err Invalid argument
file_pread(7,1,buffer,2930210917(182397/49/26)) lseek err Invalid argument
file_pread(7,1,buffer,2930212830(182397/79/49)) lseek err Invalid argument
file_pread(7,1,buffer,2930210918(182397/49/27)) lseek err Invalid argument
file_pread(7,1,buffer,2930212831(182397/79/50)) lseek err Invalid argument
file_pread(7,8,buffer,2930210862(182397/48/34)) lseek err Invalid argument
file_pread(7,11,buffer,2930210909(182397/49/18)) lseek err Invalid argument
file_pread(7,1,buffer,2930212832(182397/79/51)) lseek err Invalid argument
file_pread(7,1,buffer,2930210920(182397/49/29)) lseek err Invalid argument
file_pread(7,1,buffer,2930212833(182397/79/52)) lseek err Invalid argument
file_pread(7,1,buffer,2930210921(182397/49/30)) lseek err Invalid argument
file_pread(7,1,buffer,2930212834(182397/79/53)) lseek err Invalid argument
file_pread(7,1,buffer,2930210922(182397/49/31)) lseek err Invalid argument
file_pread(7,1,buffer,2930212835(182397/79/54)) lseek err Invalid argument
file_pread(7,8,buffer,2930210866(182397/48/38)) lseek err Invalid argument
file_pread(7,11,buffer,2930210913(182397/49/22)) lseek err Invalid argument
file_pread(7,1,buffer,2930212836(182397/79/55)) lseek err Invalid argument
file_pread(7,1,buffer,2930210924(182397/49/33)) lseek err Invalid argument
file_pread(7,1,buffer,2930212837(182397/79/56)) lseek err Invalid argument
file_pread(7,1,buffer,2930210925(182397/49/34)) lseek err Invalid argument
file_pread(7,1,buffer,2930212838(182397/79/57)) lseek err Invalid argument
file_pread(7,8,buffer,2930210869(182397/48/41)) lseek err Invalid argument
file_pread(7,11,buffer,2930210916(182397/49/25)) lseek err Invalid argument
file_pread(7,1,buffer,2930212839(182397/79/58)) lseek err Invalid argument
file_pread(7,1,buffer,2930210927(182397/49/36)) lseek err Invalid argument
file_pread(7,1,buffer,2930212840(182397/79/59)) lseek err Invalid argument
file_pread(7,1,buffer,2930210928(182397/49/37)) lseek err Invalid argument
file_pread(7,1,buffer,2930212841(182397/79/60)) lseek err Invalid argument
file_pread(7,8,buffer,2930210872(182397/48/44)) lseek err Invalid argument
file_pread(7,11,buffer,2930210919(182397/49/28)) lseek err Invalid argument
file_pread(7,1,buffer,2930212842(182397/79/61)) lseek err Invalid argument
file_pread(7,1,buffer,2930210930(182397/49/39)) lseek err Invalid argument
file_pread(7,1,buffer,2930212843(182397/79/62)) lseek err Invalid argument
file_pread(7,1,buffer,2930210931(182397/49/40)) lseek err Invalid argument
file_pread(7,1,buffer,2930212844(182397/79/63)) lseek err Invalid argument
file_pread(7,8,buffer,2930210875(182397/48/47)) lseek err Invalid argument
file_pread(7,11,buffer,2930210922(182397/49/31)) lseek err Invalid argument
file_pread(7,1,buffer,2930212845(182397/80/1)) lseek err Invalid argument
file_pread(7,1,buffer,2930210933(182397/49/42)) lseek err Invalid argument
file_pread(7,1,buffer,2930212846(182397/80/2)) lseek err Invalid argument
file_pread(7,1,buffer,2930210934(182397/49/43)) lseek err Invalid argument
file_pread(7,1,buffer,2930212847(182397/80/3)) lseek err Invalid argument
file_pread(7,8,buffer,2930210878(182397/48/50)) lseek err Invalid argument
file_pread(7,11,buffer,2930210925(182397/49/34)) lseek err Invalid argument
file_pread(7,1,buffer,2930212848(182397/80/4)) lseek err Invalid argument
file_pread(7,1,buffer,2930210936(182397/49/45)) lseek err Invalid argument
file_pread(7,1,buffer,2930212849(182397/80/5)) lseek err Invalid argument
file_pread(7,1,buffer,2930210937(182397/49/46)) lseek err Invalid argument
file_pread(7,1,buffer,2930212850(182397/80/6)) lseek err Invalid argument
file_pread(7,14,buffer,2930210804(182397/47/39)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,3,buffer,2930210818(182397/47/53)) lseek err Invalid argument
file_pread(7,3,buffer,2930210865(182397/48/37)) lseek err Invalid argument
file_pread(7,8,buffer,2930210881(182397/48/53)) lseek err Invalid argument
file_pread(7,11,buffer,2930210928(182397/49/37)) lseek err Invalid argument
file_pread(7,2,buffer,2930212850(182397/80/6)) lseek err Invalid argument
file_pread(7,14,buffer,2930210805(182397/47/40)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,2,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,3,buffer,2930210819(182397/47/54)) lseek err Invalid argument
file_pread(7,3,buffer,2930210866(182397/48/38)) lseek err Invalid argument
file_pread(7,8,buffer,2930210882(182397/48/54)) lseek err Invalid argument
file_pread(7,11,buffer,2930210929(182397/49/38)) lseek err Invalid argument
file_pread(7,2,buffer,2930212851(182397/80/7)) lseek err Invalid argument
file_pread(7,14,buffer,2930210806(182397/47/41)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,3,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,3,buffer,2930210820(182397/47/55)) lseek err Invalid argument
file_pread(7,3,buffer,2930210867(182397/48/39)) lseek err Invalid argument
file_pread(7,8,buffer,2930210883(182397/48/55)) lseek err Invalid argument
file_pread(7,11,buffer,2930210930(182397/49/39)) lseek err Invalid argument
file_pread(7,2,buffer,2930212852(182397/80/8)) lseek err Invalid argument
file_pread(7,14,buffer,2930210807(182397/47/42)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,4,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,3,buffer,2930210821(182397/47/56)) lseek err Invalid argument
file_pread(7,3,buffer,2930210868(182397/48/40)) lseek err Invalid argument
file_pread(7,8,buffer,2930210884(182397/48/56)) lseek err Invalid argument
file_pread(7,11,buffer,2930210931(182397/49/40)) lseek err Invalid argument
file_pread(7,2,buffer,2930212853(182397/80/9)) lseek err Invalid argument
file_pread(7,14,buffer,2930210808(182397/47/43)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,5,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,3,buffer,2930210822(182397/47/57)) lseek err Invalid argument
file_pread(7,3,buffer,2930210869(182397/48/41)) lseek err Invalid argument
file_pread(7,8,buffer,2930210885(182397/48/57)) lseek err Invalid argument
file_pread(7,11,buffer,2930210932(182397/49/41)) lseek err Invalid argument
file_pread(7,2,buffer,2930212854(182397/80/10)) lseek err Invalid argument
file_pread(7,1,buffer,2930210943(182397/49/52)) lseek err Invalid argument
file_pread(7,1,buffer,2930212856(182397/80/12)) lseek err Invalid argument
file_pread(7,14,buffer,2930210810(182397/47/45)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,7,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,3,buffer,2930210824(182397/47/59)) lseek err Invalid argument
file_pread(7,3,buffer,2930210871(182397/48/43)) lseek err Invalid argument
file_pread(7,8,buffer,2930210887(182397/48/59)) lseek err Invalid argument
file_pread(7,11,buffer,2930210934(182397/49/43)) lseek err Invalid argument
file_pread(7,1,buffer,2930212857(182397/80/13)) lseek err Invalid argument
file_pread(7,1,buffer,2930210945(182397/49/54)) lseek err Invalid argument
file_pread(7,1,buffer,2930212858(182397/80/14)) lseek err Invalid argument
file_pread(7,14,buffer,2930210812(182397/47/47)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,8,buffer,2930210818(182397/47/53)) lseek err Invalid argument
file_pread(7,3,buffer,2930210826(182397/47/61)) lseek err Invalid argument
file_pread(7,3,buffer,2930210873(182397/48/45)) lseek err Invalid argument
file_pread(7,8,buffer,2930210889(182397/48/61)) lseek err Invalid argument
file_pread(7,11,buffer,2930210936(182397/49/45)) lseek err Invalid argument
file_pread(7,1,buffer,2930212859(182397/80/15)) lseek err Invalid argument
file_pread(7,10,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,1,buffer,2930210947(182397/49/56)) lseek err Invalid argument
file_pread(7,1,buffer,2930212860(182397/80/16)) lseek err Invalid argument
file_pread(7,14,buffer,2930210814(182397/47/49)) ReadFile Het station kan de aangevraagde sector niet vinden.
file_pread(7,3,buffer,2930210828(182397/47/63)) lseek err Invalid argument
file_pread(7,3,buffer,2930210875(182397/48/47)) lseek err Invalid argument
file_pread(7,8,buffer,2930210891(182397/48/63)) lseek err Invalid argument
file_pread(7,11,buffer,2930210938(182397/49/47)) lseek err Invalid argument
file_pread(7,1,buffer,2930212861(182397/80/17)) lseek err Invalid argument
file_pread(7,12,buffer,2930210817(182397/47/52)) lseek err Invalid argument
file_pread(7,1,buffer,2930210899(182397/49/8)) lseek err Invalid argument
file_pread(7,1,buffer,2930210949(182397/49/58)) lseek err Invalid argument
file_pread(7,1,buffer,2930212862(182397/80/18)) lseek err Invalid argument
file_pread(7,1,buffer,2930210900(182397/49/9)) lseek err Invalid argument
file_pread(7,1,buffer,2930210950(182397/49/59)) lseek err Invalid argument
file_pread(7,1,buffer,2930212863(182397/80/19)) lseek err Invalid argument
NTFS at 182397/47/50
filesystem size 2930208768
mftmirr_lcn 183138047
MS Data 2048 2930210815 2930208768
NTFS found using backup sector, blocksize=4096, 1500 GB / 1397 GiB
file_pread(7,2,buffer,2930210829(182397/48/1)) lseek err Invalid argument
file_pread(7,8,buffer,2930210894(182397/49/3)) lseek err Invalid argument
file_pread(7,11,buffer,2930210941(182397/49/50)) lseek err Invalid argument
file_pread(7,1,buffer,2930212864(182397/80/20)) lseek err Invalid argument
file_pread(7,8,buffer,2930210824(182397/47/59)) lseek err Invalid argument
file_pread(7,1,buffer,2930210902(182397/49/11)) lseek err Invalid argument
file_pread(7,1,buffer,2930210952(182397/49/61)) lseek err Invalid argument
file_pread(7,1,buffer,2930212865(182397/80/21)) lseek err Invalid argument
1 P MS Data 2048 1528393727 1528391680
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 95138/27/58
mftmirr_lcn 2
NTFS at 95138/27/58
mftmirr_lcn 2
file_pread(7,2,buffer,2930210815(182397/47/50)) ReadFile Het station kan de aangevraagde sector niet vinden.
The file had to be partly deleted causo of size. So I deleted info in the middle.
heinflhs
#5 Post by heinflhs »
I cannot copy and paste file here. After tunnin deep scan the folllowing message appears:
Disk/dev/ssd-1500GB/1397 GiB - CHS 182379 255 63
The harddisk <1500 GB/1397gib> seems too small! <<4156GB/3871 GiB>
>FAT 16<32M 130992 172 45 185365 92 38 873497199
FAT 16 >32M 324688 245 42 505382 137 32 2902842287
[continue]
447 GB/416Gib
heinflhs
#6 Post by heinflhs »
cgrenier wrote: 12 Sep 2019, 10:44 It looks like your disk has been reformated. Can you post the content of the testdisk.log file after Analyze, Quick Search and Deeper Search ?
Something went wrong in the beginning. I dis not format the disk deliberately. After that I tried unformat end probably damaged a lot. Problem is that I'm a layman in this computer field.
