Testdisk fails to find Reserved partition 6TB External, hangs at 13%
Fitzroya
#1 Post by Fitzroya »
After a file manager crash, my Seagate 6TB Backup Plus drive lost its MS Reserved partition. Windows can't access it and Disk Management says it is not initialized. Linux can read the Primary MS Data partition and files. Linux Gparted shows the first partition as Unallocated, 129mb, first sector 0 last 264191. Testdisk detects EFI/GPT partiion. Finds MS Data Primary starting 264192 and says structure OK. Continuing search, the program hangs at 13% after many repetitive entries. I need to make this disk readable in Windows and am unsure what to do next (Load Backup, or something else?) Brief Log text below, a much longer one from the 13% hang attached as .zip.
Sun Sep 15 13:55:37 2019
OS: Linux, kernel 4.15.0-54-generic (#58-Ubuntu SMP Mon Jun 24 10:55:24 UTC 2019) x86_64
Compiler: GCC 7.2
ext2fs lib: 1.44.1, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sdc: LBA, LBA48 support
/dev/sdc: size 976773168 sectors
/dev/sdc: user_max 976773168 sectors
Disk /dev/sda - 6001 GB / 5589 GiB - CHS 729601 255 63, sector size=512 - Seagate Backup+ Hub BK, FW:D781
Disk /dev/sdb - 1999 GB / 1862 GiB - CHS 243151 255 63, sector size=512 - LSI 9750-4i DISK, FW:5.12
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - CT500MX500SSD1, S/N:1913E1F51601, FW:M3CR023
Disk /dev/sda - 6001 GB / 5589 GiB - Seagate Backup+ Hub BK
Partition table type: EFI GPT
Analyse Disk /dev/sda - 6001 GB / 5589 GiB - CHS 729601 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=11721045166 (expected 11721045166)
hdr_lba_start=34
hdr_lba_end=11721045133
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 264192 11721043967 11720779776
NTFS at 16/113/34
filesystem size 11720779776
mftmirr_lcn 2
NTFS part_offset=135266304, part_size=6001039245312, sector_size=512
NTFS at 16/113/34
mftmirr_lcn 2
NTFS, blocksize=4096, 6001 GB / 5588 GiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 11720779776 linear /dev/sda 264192" | dmsetup create test0
testdisk_6tb_long.log.zip
(24.06 KiB) Downloaded 426 times
Re: Testdisk fails to find Reserved partition 6TB External, hangs at 13%
The log shows a lot of read errors. They are probably due to bad sectors or a damaged head.
You can try to clone the disk to a new empty one using ddrescue as described in https://www.cgsecurity.org/testdisk.pdf
If it doesn't work or if it's too complex, you should contact a data recovery company.
