TestDisk analyse is too slow
hamoud
#1 Post by hamoud »
I'm trying to recover a partition for a corrupted hard drive using TestDisk. I chose (EFI GPT) table type as it was suggested by TestDisk. However, the disk analyse is too slow or even stuck. It's been over 24 hours and it shows 02% (3496/121600) and been like this for a while now.
Does this mean there are bad sectors? Should I choose different table type? Any help would be appreciated.
Wed Sep 18 16:13:14 2019
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999176536064
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00RKKA0, S/N:WD-WMC1S0691519, FW:80.00A80
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM 014-1EJ164-SSHD, S/N:77735CF3, FW:HPRE
Disk /dev/sdb - 1000 GB / 931 GiB - ST1000LM 014-1EJ164-SSHD
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525167 (expected 1953525167)
hdr_lba_start=34
hdr_lba_end=1953525134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34      32767      32734 [Microsoft reserved partition]
     MS Data                     2048       2048          1
     ReFS, 512 B
LVM magic value at 2056/225/27
LVM magic value at 2661/158/15
LVM magic value at 2678/10/18
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
   P MS Data                     2048       2048          1
     ReFS, 512 B
 1 P MS Data                     2048       2048          1
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Re: TestDisk analyse is too slow
Try to clone the disk using ddrescue to a new empty disk as described in https://www.cgsecurity.org/testdisk.pdf
Once it's done, remove the original disk and try testdisk on the clone.
hamoud
#3 Post by hamoud »
I did clone the disk using ddrescue and run testdisk on the clone. However, the result after analyzing the disk shows multiple deleted partitions but all of them are corrupted (no filesystem).
Did you verify that by trying to list files for each of the partitions found?
hamoud
#5 Post by hamoud »
Yes, listing each one returns the same message: “no filesystem”
#6 Post by recuperation »
I would not have expected that all file systems fail simultaneously.
Now there is only Photorec left over or any third party software.
Apart from that, to have an idea of the number of broken sectors you can run smartmontools or Crystaldiskinfo.
You can look into the ddrescue logfile to see where exactly ddrescue failed to read data.
hamoud
#7 Post by hamoud »
Thanks, I appreciate your help. I’m trying photoRec right now, but the filenames and structure is so important. The data is useless without the filesystem.
#8 Post by recuperation »
The only remaining option now is to use commercial software then.
#9 Post by recuperation »
