Recovering a ntfs partition after format to fat32
aaa801
#1 Post by aaa801 »
Hi, i acidently formatted a ntfs drive to fat32, the drive hasnt been written to since this,
There any way to get back the original partition and files?
Re: Recovering a ntfs partition after format to fat32
Might be this procedure;
http://www.cgsecurity.org/wiki/Data_Rec ... _partition
Your partition should be still in the partition table, because you didn't delete it?
In the menu Advanced, you can change your FAT32 drive to NTFS.
Easily check the menu Type and confirm with enter.
Confirm with enter to proceed.
Now at the right your cursor should be blinking.
Type the partition ID 07 for NTFS
Now you would be able to use the menu "Boot".
aaa801
#3 Post by aaa801 »
I tryed that and did the rebuild BS
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
1 P HPFS - NTFS 0 0 3 243201 80 63 3907029166 [UNTITLED]
Status: Bad
Status: Bad
Sectors are not identical.
>[ Quit ] [Rebuild BS] [ Dump ]
Return to Advanced menu
briton674532
#4 Post by briton674532 »
Hi....
I read your problem and i want to suggest you to use the best partition recovery software as i too had used this software when i was in the same problem. With the help of this tool, you can recover NTFS partition data after MBR corruption. So, don't panic and download this tool to check the recovery results on the site given below. :roll:
http://www.bestpartitionrecovery.com/re ... fter-mbr-c
orruption.html
