exfat_header->signature Topic is solved
mesajflaviu
#1 Post by mesajflaviu »
Wanting to understand this code, I met something interesting:
int search_exFAT_backup(unsigned char* buffer, disk_t* disk, partition_t* partition)
	if (disk->pread(disk, buffer, DEFAULT_SECTOR_SIZE, partition->part_offset) != DEFAULT_SECTOR_SIZE)
		return -1;
		const struct exfat_super_block* exfat_header = (const struct exfat_super_block *)buffer;
		/* EXFAT recovery using backup sector */
		int a = exfat_header->signature;
		int b = le16(exfat_header->signature);
		int c = 0xAA55;
		int d = le16(exfat_header->signature) == 0xAA55;
// the condition from below is never TRUE at all ... why exfat_header->signature is swaping byte ? (lower/high byte) ?
		if (le16(exfat_header->signature) == 0xAA55 &&
			recover_exFAT(disk, exfat_header, partition) == 0)
			/* part_offset has already been updated if found using backup sector */
			return 1;
	return 0;
Result:
a = 43605; (in hexa: 0xAA55)
b = 21930; (in hexa: 0x55AA)
c = 43605;
d = 0;
of course, the condition from below is not TRUE:
if (le16(exfat_header->signature) == 0xAA55)
why is swaping exfat_header->signature lower byte with high byte ?
Thank you for any explaination !
Re: exfat_header->signature
just an idea (I am not able to program in C and did not look at the rest of the code):
The software runs on different platforms where the byte order may differ. See:
https://en.wikipedia.org/wiki/Endianness
mesajflaviu
#3 Post by mesajflaviu »
Hello. Yes, I think that could be the reason why that value is swapped ... but I wonder whether is ok to modify that condition in order to made that condition TRUE ?
As I said above:
It is the processor platform that should make that condition become true - I guess.
mesajflaviu
#5 Post by mesajflaviu »
@recuperation: I owe you. Thank you. I'll try to write to Grenier this part of code, when I modified by my hunch, seem to work that part of code, but I am thinking where these situation could come up later ?
#6 Post by recuperation »
recuperation wrote: 24 Sep 2019, 10:34 As I said above:
#7 Post by cgrenier »
On a little endian plateform (ie. Intel), le16() is defined as
#define le16(x)  (x)
It has no effect.
mesajflaviu
#8 Post by mesajflaviu »
Thank you, I have understood.
