Deleting accidental GPT partition and writing restored Intel partition table
kmlmkm
#1 Post by kmlmkm »
I'm using Debian Stable.
I was using the root account to wipe some drives and was using sgdisk to copy over the GPT partition table from
/dev/sdc
to
/dev/sdd
The command was
sgdisk -R /dev/sdd /dev/sdc
and then
sgdisk -G /dev/sdd
. My primary hard disk is sda and I have another hard disk, sdb. sgdisk told me that I should probably do something something because kernel something and then that i should look into partprobe and kpartx. So I in my blind stupor just entered partprobe and pressed enter and it showed that I had something like 9xxxxxxxx ish space and that it should be done something to and then I just C-c'ed it because I was spooked. And then the entire system just exited X and threw me back on the tty and then I turned it off from the UPS and then turned it on again, and there's nothing there, just an oversized underline cursor on the left of my screen.
It turns out that the partition that was to be written to /dev/sdd is now written on /dev/sda.
I found my old partition (Intel-type) through testdisk and wrote it to the disk and after a reboot, testdisk still identifies it as gpt, and not intel. I tried writing it again, and it gave me the same result.
gpt table, still on the disk:
https://i.imgur.com/cw8DZn3.jpg
the required table, from the Intel submenu:
https://i.imgur.com/6ZajNbG.jpg
Any ideas? There's no delete option on the gpt submenu, but there is one on the intel submenu. I would like to make my disk bootable again. A cursory inspection shows that no data is lost.
I also tried flashing the testdisk MBR, but no dice, it gave me no result on any of the four numbers.
Re: Deleting accidental GPT partition and writing restored Intel partition table
Run TestDisk, select /dev/sdc, PC Intel or EFI GPT, select the partition table type you want,
Analyze, Quick Search.
If all your partitions are listed, choose Write, confirm, Quit, restart your computer.
If you have problems, please copy and paste the testdisk.log file content.
kmlmkm
#3 Post by kmlmkm »
Thanks for the reply!
I'm using an external bootable flash drive with Arch Linux at the moment. It is /dev/sdc. /dev/sdb is a secondary, storage drive and /dev/sda is the drive which needs to be fixed.
~$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 931.5G  0 disk
├─sda1   8:1    0 915.8G  0 part
└─sda2   8:2    0  15.8G  0 part
sdb      8:16   0   1.8T  0 disk
└─sdb1   8:17   0   1.8T  0 part
sdc      8:32   1   7.5G  0 disk
├─sdc1   8:33   1    10M  0 part
├─sdc2   8:34   1   500M  0 part /boot
└─sdc3   8:35   1   6.9G  0 part /
testdisk.log:
~$ cat testdisk.log
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
/dev/sda: native_max 1953525168 sectors
Using locale 'en_US.UTF-8'.
Thu Sep 26 16:54:11 2019
Command line: TestDisk /log /dev/sda
OS: Linux, kernel 5.2.5-arch1-1-ARCH (#1 SMP PREEMPT Wed Jul 31 08:30:34 UTC 2019) x86_64
Compiler: GCC 8.2
Compilation date: 2018-10-03T23:07:17
ext2fs lib: 1.45.3, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: none, curses lib: ncurses 6.1
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00WN4A0, S/N:WD-WMC6Y0J29XFR, FW:01.01A01
Disk /dev/sda - 1000 GB / 931 GiB - WDC WD10EZEX-00WN4A0
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
 1 * Linux                    0  32 33 119544 174 54 1920483328
 2 P Linux Swap           119544 207 24 121601  57 56   33036288
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 983 GB / 915 GiB
     Linux Swap           119544 207 24 121601  57 40   33036272
     SWAP2 version 1, pagesize=4096, 16 GB / 15 GiB
write!
I followed your steps and I only saw the testdisk MBR (1234F:), which I wrote earlier. Pressing any of the four numbers had no effect. No boot.
