Having ntfs library
mesajflaviu
Having ntfs library
#1 Post by mesajflaviu »
Hi. I have read inside config.h.in file a row:
/* Define to 1 if you have the ntfs library (-lntfs). */
#undef HAVE_LIBNTFS
and inside source code, in ntfs_udl.cpp file an ifdefine:
#ifdef HAVE_LIBNTFS
#include <ntfs/bootsect.h>
#include <ntfs/mft.h>
#include <ntfs/attrib.h>
#include <ntfs/layout.h>
#include <ntfs/inode.h>
#include <ntfs/device.h>
#include <ntfs/debug.h>
#include <ntfs/ntfstime.h>
#ifdef HAVE_NTFS_VERSION_H
#include <ntfs/version.h>
#endif
#endif
and I haven't found any ntfs folder inside source code ...my question is, what ntfs library or folder should I have in order to have that ntfs library available ? Thank you.
mesajflaviu
Re: Having ntfs library
#2 Post by mesajflaviu »
After un-numbered searches on google, I fall into question: what "ntfs library" should be included into testdisk app ? I have found a few, but none of them seem to have all files from this list:
#ifdef HAVE_LIBNTFS
#endif
#endif
Sorry for keep asking question here, the source code is huge and I met a lot of new things here ... Could you help me ?
#3 Post by recuperation »
After reading about the #IFDEF directive in the internet I recommend you checking if HAVE_LIBNTFS is defined at all.
Maybe it is simply not needed to compile the most recent version.
I would try to compile the EXE-file to see I am able to replicate the original EXE file.
As you are still hiding the location of of your source code I think about hiding my voice.
mesajflaviu
#4 Post by mesajflaviu »
Kindly thank you @recuperation for your interest ! I am glad to talk with you.
I have checked, HAVE_LIBNTFS is not defined at all. But without this HAVE_LIBNTFS, the function ntfs_undelete_part from ntfs_udl.cpp is not called at all.
The same situation was with __CYGWIN__, without define this, I were not compiled a lot of functional code. That is why I had need to define __CYGWIN__ in order to have needed code. I guess it will be the same for HAVE_LIBNTFS ... but in this case, I need ntfs library. See a little code from testdisk-7.1 code, from github, file: ntfs_inc.h
#if defined(HAVE_LIBNTFS) || defined(HAVE_LIBNTFS3G)
struct ntfs_dir_struct {
	file_info_t* dir_list;
	ntfs_volume* vol;
	my_data_t *my_data;
	dir_data_t* dir_data;
	unsigned long int inode;
#ifdef HAVE_ICONV
	iconv_t cd;
#endif
#endif
from this code I understand that without HAVE_LIBNTFS defined I would not have ntfs_dir_struct, and so ntfs_volume*, and so on ...
But these defined values are somehow defined in config.h.in file (from testdisk-7.1 project, taken from github.)
#undef HAVE_LIBNTFS
And please do not hide your voice, I am not hide anything ! I have downloaded source code from github, testdisk-7.1, and inside src folder, I have found all source code from where I am trying to figure out how to read deleted files from HDD as source code mechanism. I also read documentation from https://www.ntfs.com/index.html, but there is no source code ... What else should I show or reveal ? I am not hiding anything ! Please tell me what I should show.
mesajflaviu
#5 Post by mesajflaviu »
I have not used cygwin by now, as far I read (I might be wrong), cygwin doesn't has a GUI with I could made debugging. So, I made debugging statically :), with my eyes :D that is why I put here questions ...
#6 Post by recuperation »
mesajflaviu wrote: 30 Sep 2019, 19:38 I have downloaded source code from github, testdisk-7.1, and inside src folder, I have found all source code from where I am trying to figure out how to read deleted files from HDD as source code mechanism. I also read documentation from https://www.ntfs.com/index.html, but there is no source code ... What else should I show or reveal ? I am not hiding anything ! Please tell me what I should show.
Perfect. Now others and I what you are exactly referring to. There is nothing now that is left to disclose.
Initially you spoke about EXFAT, but now you are mentioning NTFS.com?
Microsoft did not publicly disclose the source code for NTFS. Linux people have reverse engineered parts of NTFS. You can find this code with them.
mesajflaviu
#7 Post by mesajflaviu »
After I studied about exFAT, now I have read about NTFS, and I have found some functions from source code, for instance, ntfs_undelete_part function, from ntfs_udl.c file, or or dir_partition_ntfs_init function, from ntfs_dir.c. These functions uses some struct data:
dir_partition_t dir_partition_ntfs_init(disk_t *disk_car, const partition_t *partition, dir_data_t *dir_data, const int verbose, const int expert)
	struct ntfs_device *dev;
	my_data_t *my_data = NULL;
	ntfs_volume *vol = NULL;
which are part of NTFS library, but this library I didn't identified (yet) on internet ...
mesajflaviu
#8 Post by mesajflaviu »
I have read inside https://www.cgsecurity.org/testdisk.pdf:
NTFS library - Optional, used by TestDisk to list files from NTFS partition
where can I find this NTFS library ? And can I use it for windows OS ?
#9 Post by recuperation »
I don't know.
mesajflaviu
#10 Post by mesajflaviu »
Thank you @recuperation.
