I have a 32GB SanDisk microSD that I've been using in my phone. For a couple days it would randomly show up as "removed". I could reset my phone and it would come back. Now it doesn't come back. So I placed it in an adapter and mounted on my Win10 laptop and tried to read it with testdisk. I believe it should be formatted as HPFS-NTFS. In testdisk, it showed a couple of curious things:
1) No partition found
2) Partition sector doesn't have the endmark 0xAA55
3) Cylinder setting that is clearly wrong (C=3)
I don't know where to go from here. I tried PhotoRec too, but didn't see an obvious way to go there. Of course Windows only suggests reformatting...
I welcome any suggestions. Thanks in advance.
Testlog below:
Sun Sep 29 20:39:20 2019
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=32096256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=32096256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=965127729664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=32925286400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=32096256
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM024 HN-M101MBB, S/N:S31LJ9BG917058, FW:2BA30001
Disk /dev/sdc - 32 MB / 30 MiB - CHS 3 255 63, sector size=512 - Kingston Reader MicSD/M2, FW:0200
Disk /dev/sdc - 32 MB / 30 MiB - Kingston Reader MicSD/M2
Analyse Disk /dev/sdc - 32 MB / 30 MiB - CHS 3 255 63
file_pread(5,2,buffer,63487(3/242/47)) lseek err Invalid argument
file_pread(5,1,buffer,63487(3/242/47)) lseek err Invalid argument
file_pread(5,2,buffer,63488(3/242/48)) lseek err Invalid argument
file_pread(5,14,buffer,63490(3/242/50)) lseek err Invalid argument
file_pread(5,3,buffer,63504(3/243/1)) lseek err Invalid argument
file_pread(5,3,buffer,63551(3/243/48)) lseek err Invalid argument
file_pread(5,8,buffer,63567(3/244/1)) lseek err Invalid argument
file_pread(5,11,buffer,63614(3/244/48)) lseek err Invalid argument
file_pread(5,2,buffer,65536(4/20/17)) lseek err Invalid argument
Store new MBR code
SanDisk MicroSD with no partition
Re: SanDisk MicroSD with no partition
Your 32 GB memory card is reported as 32 MB!
The capacity is wrong. You should contact a data recovery company as software solutions like testdisk and photorec can't help in this case.
Thanks. I was worried about that. I tried changing the geometry so that the cylinder value matches what a normal 32G card uses - and that didn't help. So I suspect the card is not operating right.
