Help Cant find my external hard drive to copy files too Topic is solved
bloomy60
#1 Post by bloomy60 »
Hi guys
I have my old desktop hdd which testdisk is working fine on, I just got the "needs formating" errors after plugging it into my mac. I have found all my files on it and so far some of them have successfully downloaded onto my macbook hdd but the problem is I have 1tb of data to come off it and I cant find the directory for the external when I go to copy the files. I have pressed left etc to try find it but is only going to the files on my laptop hdd. I am currently running the program off the good external but that didnt help.
What am i doing wrong?
Re: Help Cant find my external hard drive to copy files too
You need to mount your external hdd.
On macos, partitions from external disk are usually mounted in /Volumes.
bloomy60
#3 Post by bloomy60 »
Ahh the /volumes! Thanks cgrenier!
