help a noob, external hard drive gone Raw
Greetings friends,
My External hard drive western digital my passport 4000 GB is not working anymore (thank god i got my pictures out last week but i still have more than 3 tera bytes of work stuff).
It worked fine yesterday, then it stopped working on my mac (not visible), and can"t mount it on disk utility (in recovery mode).
CHKDSK won't work on it.
Tried ubuntu but i'm a real noob and had a lot of error messages that i didn't understand.
The smart status test passed on the western digital lifeguard diagnostic. (the quick test, not the extended one because......250 hours)
I followed a solution i found on some page over the internet ( https://html5.litten.com/updated-how-to ... ecame-raw/ ) and that is how i got to use "test disk".
I followed the steps till the "p : list file step" i had an error message "can't open file system, filesystem seems damaged"
So i lunched a deep search but it is taking too long (1 % since yesterday).
can you give some advice on how to proceed. please.
Should i stop test disk's deep search and do something else ? should i use photorec to get the data back ? (the thing is most of my data are MRI and CT scans that need to stay in their respective folder to be useful).
(i have a new 8000 GB hard drive to replace the older one, i can use it to save what is on the old one)
Thank you for your help.
Re: help a noob, external hard drive gone Raw
Can you copy/paste the testdisk.log file content ?
Hi and thanks for the reply,
Actually i din't knew how to produce a log. should i just copy paste every message to every step or there is a step i'm missing ?
i lunched another deep scan after trying other stuff that didn't work. i'm at 2 % but it's gonna take like 20 days to complete.
i'll stop it when i 'll get home and try to publish the log if i find how to do it.
Thanks again.
Thanks again.
Hello again,
Here is the copy of the log file.
In the meantime a did a recovery attempt with disk drill. no file names and no folder organisation...... which means it is useless for me. i would've used photorec but i know it doesn't gove the file names.
do you recommend another software that could give me the file names ? and the folders ? stellar maybe ?
I'm seriously considering sending my hard drive to chronodisk in Paris, France or to stellar in brussels. what is your take on this ?
at this point, your advice is very precious
hope to hear from you soon. Thank you
Wed Oct 2 16:57:02 2019
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=8001529315328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=15518924800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=8001529315328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=15518924800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=85896566784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=53686370304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=70120479744
filewin32_getfilesize(\\.\F:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Fonction incorrecte.
filewin32_getfilesize(\\.\G:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Fonction incorrecte.
filewin32_getfilesize(\\.\H:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Fonction incorrecte.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=8001527218176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=4000750501888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=15517876224
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000LPVT-08G33T1, S/N:2020202057202d44585731323141353337333733, FW:02.01A02
Disk /dev/sdb - 4000 GB / 3725 GiB - CHS 486397 255 63, sector size=512 - WD My Passport 25E2, S/N:WXD1E666EM4S, FW:4004
Disk /dev/sdc - 8001 GB / 7452 GiB - CHS 972797 255 63, sector size=512 - WD Elements 25A3, S/N:7HKUG02N, FW:1021
Disk /dev/sdd - 15 GB / 14 GiB - CHS 1886 255 63, sector size=512 - Verbatim STORE N GO, S/N:1, FW:8.07
Disk /dev/sdb - 4000 GB / 3725 GiB - WD My Passport 25E2
Partition table type: EFI GPT
Analyse Disk /dev/sdb - 4000 GB / 3725 GiB - CHS 486397 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7813969919 (expected 7813969919)
hdr_lba_start=34
hdr_lba_end=7813969886
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 7813967871 7813965824 [My Passport]
NTFS at 0/32/33
filesystem size 7813965824
mft_lcn 0
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=4000750501888, sector_size=512
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS, blocksize=4096, 4000 GB / 3725 GiB
file_pread(5,2,buffer,3519002624(486397/33/37)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,1,buffer,3519002624(486397/33/37)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,2,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519002627(486397/33/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519002628(486397/33/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519002629(486397/33/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519002630(486397/33/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519002631(486397/33/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519002632(486397/33/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519002633(486397/33/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519002634(486397/33/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519002635(486397/33/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519002636(486397/33/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519002637(486397/33/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519002638(486397/33/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519002639(486397/33/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519002640(486397/33/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519002641(486397/33/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519002642(486397/33/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519002643(486397/33/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519002644(486397/33/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519002645(486397/33/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519002646(486397/33/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519002647(486397/33/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519002648(486397/33/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519002649(486397/33/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519002650(486397/33/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519002651(486397/34/1)) lseek err Invalid argument
file_pread(5,1,buffer,3519002652(486397/34/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519002653(486397/34/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519002654(486397/34/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519002655(486397/34/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519002656(486397/34/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519002657(486397/34/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519002658(486397/34/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519002659(486397/34/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519002660(486397/34/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519002661(486397/34/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519002662(486397/34/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519002663(486397/34/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519002664(486397/34/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519002665(486397/34/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519002666(486397/34/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519002667(486397/34/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519002668(486397/34/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519002669(486397/34/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519002670(486397/34/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519002671(486397/34/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519002672(486397/34/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519002673(486397/34/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519002674(486397/34/24)) lseek err Invalid argument
file_pread(5,1,buffer,3519002675(486397/34/25)) lseek err Invalid argument
file_pread(5,1,buffer,3519002676(486397/34/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519002677(486397/34/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519002678(486397/34/28)) lseek err Invalid argument
file_pread(5,1,buffer,3519002679(486397/34/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519002680(486397/34/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519002681(486397/34/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519002682(486397/34/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519002683(486397/34/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519002684(486397/34/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519002685(486397/34/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519002686(486397/34/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519002687(486397/34/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519002688(486397/34/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519002689(486397/34/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519002690(486397/34/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519002691(486397/34/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519002692(486397/34/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519002693(486397/34/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519002694(486397/34/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519002695(486397/34/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519002696(486397/34/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519002697(486397/34/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519002698(486397/34/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519002699(486397/34/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519002700(486397/34/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519002701(486397/34/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519002702(486397/34/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519002703(486397/34/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519002704(486397/34/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519002705(486397/34/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519002706(486397/34/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519002707(486397/34/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519002708(486397/34/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519002709(486397/34/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519002710(486397/34/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519002711(486397/34/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519002712(486397/34/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519002713(486397/34/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519002714(486397/35/1)) lseek err Invalid argument
file_pread(5,1,buffer,3519002715(486397/35/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519002716(486397/35/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519002717(486397/35/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519002718(486397/35/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519002719(486397/35/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519002720(486397/35/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519002721(486397/35/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519002722(486397/35/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519002723(486397/35/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519002724(486397/35/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519002725(486397/35/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519002726(486397/35/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519002727(486397/35/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519002728(486397/35/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519002729(486397/35/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519002730(486397/35/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519002731(486397/35/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519002732(486397/35/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519002733(486397/35/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519002734(486397/35/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519002735(486397/35/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519002736(486397/35/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519002737(486397/35/24)) lseek err Invalid argument
file_pread(5,1,buffer,3519002738(486397/35/25)) lseek err Invalid argument
file_pread(5,1,buffer,3519002739(486397/35/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519002740(486397/35/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519002741(486397/35/28)) lseek err Invalid argument
file_pread(5,1,buffer,3519002742(486397/35/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519002743(486397/35/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519002744(486397/35/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519002745(486397/35/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519002746(486397/35/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519002747(486397/35/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519002748(486397/35/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519002749(486397/35/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519002750(486397/35/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519002751(486397/35/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519002752(486397/35/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519002753(486397/35/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519002754(486397/35/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519002755(486397/35/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519002756(486397/35/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519002757(486397/35/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519002758(486397/35/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519002759(486397/35/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519002760(486397/35/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519002761(486397/35/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519002762(486397/35/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519002763(486397/35/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519002764(486397/35/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519002765(486397/35/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519002766(486397/35/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519002767(486397/35/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519002768(486397/35/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519002769(486397/35/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519002770(486397/35/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519002771(486397/35/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519002772(486397/35/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519002773(486397/35/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519002774(486397/35/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519002775(486397/35/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519002776(486397/35/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519002777(486397/36/1)) lseek err Invalid argument
file_pread(5,1,buffer,3519002778(486397/36/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519002779(486397/36/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519002780(486397/36/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519002781(486397/36/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519002782(486397/36/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519002783(486397/36/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519002784(486397/36/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519002785(486397/36/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519002786(486397/36/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519002787(486397/36/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519002788(486397/36/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519002789(486397/36/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519002790(486397/36/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519002791(486397/36/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519002792(486397/36/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519002793(486397/36/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519002794(486397/36/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519002795(486397/36/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519002796(486397/36/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519002797(486397/36/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519002798(486397/36/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519002799(486397/36/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519002800(486397/36/24)) lseek err Invalid argument
file_pread(5,1,buffer,3519002801(486397/36/25)) lseek err Invalid argument
file_pread(5,1,buffer,3519002802(486397/36/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519002803(486397/36/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519002804(486397/36/28)) lseek err Invalid argument
file_pread(5,1,buffer,3519002805(486397/36/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519002806(486397/36/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519002807(486397/36/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519002808(486397/36/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519002809(486397/36/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519002810(486397/36/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519002811(486397/36/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519002812(486397/36/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519002813(486397/36/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519002814(486397/36/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519002815(486397/36/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519002816(486397/36/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519002817(486397/36/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519002818(486397/36/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519002819(486397/36/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519002820(486397/36/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519002821(486397/36/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519002822(486397/36/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519002823(486397/36/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519002824(486397/36/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519002825(486397/36/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519002826(486397/36/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519002827(486397/36/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519002828(486397/36/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519002829(486397/36/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519002830(486397/36/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519002831(486397/36/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519002832(486397/36/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519002833(486397/36/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519002834(486397/36/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519002835(486397/36/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519002836(486397/36/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519002837(486397/36/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519002838(486397/36/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519002839(486397/36/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519002840(486397/37/1)) lseek err Invalid argument
file_pread(5,1,buffer,3519002841(486397/37/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519002842(486397/37/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519002843(486397/37/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519002844(486397/37/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519002845(486397/37/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519002846(486397/37/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519002847(486397/37/8)) lseek err Invalid argument
file_pread
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
file_pread
then it continues the same way the file is too big to copy all of it. i'll just copy the end part
(5,1,buffer,3519004522(486397/63/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519004523(486397/63/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519004524(486397/63/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519004525(486397/63/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519004526(486397/63/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519004527(486397/63/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519004528(486397/63/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519004529(486397/63/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519004530(486397/63/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519004531(486397/63/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519004532(486397/63/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519004533(486397/63/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519004534(486397/63/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519004535(486397/63/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519004536(486397/63/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519004537(486397/63/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519004538(486397/63/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519002626(486397/33/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519004539(486397/63/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519004540(486397/63/63)) lseek err Invalid argument
file_pread(5,11,buffer,3519002618(486397/33/31)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,1,buffer,3519004541(486397/64/1)) lseek err Invalid argument
file_pread(5,5,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519004542(486397/64/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519004543(486397/64/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519004544(486397/64/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519004545(486397/64/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519004546(486397/64/6)) lseek err Invalid argument
file_pread(5,11,buffer,3519002624(486397/33/37)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,1,buffer,3519004547(486397/64/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519004548(486397/64/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519004549(486397/64/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519004550(486397/64/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519004551(486397/64/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519004552(486397/64/12)) lseek err Invalid argument
file_pread(5,11,buffer,3519002630(486397/33/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519004553(486397/64/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519004554(486397/64/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519004555(486397/64/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519004556(486397/64/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519004557(486397/64/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519004558(486397/64/18)) lseek err Invalid argument
file_pread(5,11,buffer,3519002636(486397/33/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519004559(486397/64/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519004560(486397/64/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519004561(486397/64/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519004562(486397/64/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519004563(486397/64/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519004564(486397/64/24)) lseek err Invalid argument
file_pread(5,11,buffer,3519002642(486397/33/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519004565(486397/64/25)) lseek err Invalid argument
file_pread(5,11,buffer,3519002643(486397/33/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519004566(486397/64/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519004567(486397/64/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519004568(486397/64/28)) lseek err Invalid argument
file_pread(5,1,buffer,3519004569(486397/64/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519004570(486397/64/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519004571(486397/64/31)) lseek err Invalid argument
file_pread(5,11,buffer,3519002649(486397/33/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519004572(486397/64/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519004573(486397/64/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519004574(486397/64/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519004575(486397/64/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519004576(486397/64/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519004577(486397/64/37)) lseek err Invalid argument
file_pread(5,11,buffer,3519002655(486397/34/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519004578(486397/64/38)) lseek err Invalid argument
file_pread(5,11,buffer,3519002656(486397/34/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519004579(486397/64/39)) lseek err Invalid argument
file_pread(5,11,buffer,3519002657(486397/34/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519004580(486397/64/40)) lseek err Invalid argument
file_pread(5,11,buffer,3519002658(486397/34/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519004581(486397/64/41)) lseek err Invalid argument
file_pread(5,11,buffer,3519002659(486397/34/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519004582(486397/64/42)) lseek err Invalid argument
file_pread(5,11,buffer,3519002660(486397/34/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519004583(486397/64/43)) lseek err Invalid argument
file_pread(5,11,buffer,3519002661(486397/34/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519004584(486397/64/44)) lseek err Invalid argument
file_pread(5,11,buffer,3519002662(486397/34/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519004585(486397/64/45)) lseek err Invalid argument
file_pread(5,11,buffer,3519002663(486397/34/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519004586(486397/64/46)) lseek err Invalid argument
file_pread(5,11,buffer,3519002664(486397/34/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519004587(486397/64/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519004588(486397/64/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519004589(486397/64/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519004590(486397/64/50)) lseek err Invalid argument
file_pread(5,8,buffer,3519002621(486397/33/34)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,11,buffer,3519002668(486397/34/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519004591(486397/64/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519004592(486397/64/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519004593(486397/64/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519004594(486397/64/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519004595(486397/64/55)) lseek err Invalid argument
file_pread(5,8,buffer,3519002626(486397/33/39)) lseek err Invalid argument
file_pread(5,11,buffer,3519002673(486397/34/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519004596(486397/64/56)) lseek err Invalid argument
file_pread(5,8,buffer,3519002627(486397/33/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519004597(486397/64/57)) lseek err Invalid argument
file_pread(5,8,buffer,3519002628(486397/33/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519004598(486397/64/58)) lseek err Invalid argument
file_pread(5,8,buffer,3519002629(486397/33/42)) lseek err Invalid argument
file_pread(5,11,buffer,3519002676(486397/34/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519004599(486397/64/59)) lseek err Invalid argument
file_pread(5,8,buffer,3519002630(486397/33/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519004600(486397/64/60)) lseek err Invalid argument
file_pread(5,8,buffer,3519002631(486397/33/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519004601(486397/64/61)) lseek err Invalid argument
file_pread(5,8,buffer,3519002632(486397/33/45)) lseek err Invalid argument
file_pread(5,11,buffer,3519002679(486397/34/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519004602(486397/64/62)) lseek err Invalid argument
file_pread(5,8,buffer,3519002633(486397/33/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519004603(486397/64/63)) lseek err Invalid argument
file_pread(5,8,buffer,3519002634(486397/33/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519004604(486397/65/1)) lseek err Invalid argument
file_pread(5,8,buffer,3519002635(486397/33/48)) lseek err Invalid argument
file_pread(5,11,buffer,3519002682(486397/34/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519004605(486397/65/2)) lseek err Invalid argument
file_pread(5,8,buffer,3519002636(486397/33/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519004606(486397/65/3)) lseek err Invalid argument
file_pread(5,8,buffer,3519002637(486397/33/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519004607(486397/65/4)) lseek err Invalid argument
file_pread(5,8,buffer,3519002638(486397/33/51)) lseek err Invalid argument
file_pread(5,11,buffer,3519002685(486397/34/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519004608(486397/65/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519004609(486397/65/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519004610(486397/65/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519004611(486397/65/8)) lseek err Invalid argument
file_pread(5,8,buffer,3519002642(486397/33/55)) lseek err Invalid argument
file_pread(5,11,buffer,3519002689(486397/34/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519004612(486397/65/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519004613(486397/65/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519004614(486397/65/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519004615(486397/65/12)) lseek err Invalid argument
file_pread(5,8,buffer,3519002646(486397/33/59)) lseek err Invalid argument
file_pread(5,11,buffer,3519002693(486397/34/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519004616(486397/65/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519004617(486397/65/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519004618(486397/65/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519004619(486397/65/16)) lseek err Invalid argument
file_pread(5,8,buffer,3519002650(486397/33/63)) lseek err Invalid argument
file_pread(5,11,buffer,3519002697(486397/34/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519004620(486397/65/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519004621(486397/65/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519004622(486397/65/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519004623(486397/65/20)) lseek err Invalid argument
file_pread(5,8,buffer,3519002654(486397/34/4)) lseek err Invalid argument
file_pread(5,11,buffer,3519002701(486397/34/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519004624(486397/65/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519004625(486397/65/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519004626(486397/65/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519004627(486397/65/24)) lseek err Invalid argument
file_pread(5,8,buffer,3519002658(486397/34/8)) lseek err Invalid argument
file_pread(5,11,buffer,3519002705(486397/34/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519004628(486397/65/25)) lseek err Invalid argument
file_pread(5,1,buffer,3519004629(486397/65/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519004630(486397/65/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519004631(486397/65/28)) lseek err Invalid argument
file_pread(5,8,buffer,3519002662(486397/34/12)) lseek err Invalid argument
file_pread(5,11,buffer,3519002709(486397/34/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519004632(486397/65/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519004633(486397/65/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519004634(486397/65/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519004635(486397/65/32)) lseek err Invalid argument
file_pread(5,8,buffer,3519002666(486397/34/16)) lseek err Invalid argument
file_pread(5,11,buffer,3519002713(486397/34/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519004636(486397/65/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519004637(486397/65/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519004638(486397/65/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519004639(486397/65/36)) lseek err Invalid argument
file_pread(5,8,buffer,3519002670(486397/34/20)) lseek err Invalid argument
file_pread(5,11,buffer,3519002717(486397/35/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519004640(486397/65/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519004641(486397/65/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519004642(486397/65/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519004643(486397/65/40)) lseek err Invalid argument
file_pread(5,8,buffer,3519002674(486397/34/24)) lseek err Invalid argument
file_pread(5,11,buffer,3519002721(486397/35/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519004644(486397/65/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519004645(486397/65/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519004646(486397/65/43)) lseek err Invalid argument
file_pread(5,8,buffer,3519002677(486397/34/27)) lseek err Invalid argument
file_pread(5,11,buffer,3519002724(486397/35/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519004647(486397/65/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519004648(486397/65/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519004649(486397/65/46)) lseek err Invalid argument
file_pread(5,8,buffer,3519002680(486397/34/30)) lseek err Invalid argument
file_pread(5,11,buffer,3519002727(486397/35/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519004650(486397/65/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519004651(486397/65/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519004652(486397/65/49)) lseek err Invalid argument
file_pread(5,8,buffer,3519002683(486397/34/33)) lseek err Invalid argument
file_pread(5,11,buffer,3519002730(486397/35/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519004653(486397/65/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519004654(486397/65/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519004655(486397/65/52)) lseek err Invalid argument
file_pread(5,8,buffer,3519002686(486397/34/36)) lseek err Invalid argument
file_pread(5,11,buffer,3519002733(486397/35/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519004656(486397/65/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519004657(486397/65/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519004658(486397/65/55)) lseek err Invalid argument
file_pread(5,14,buffer,3519002612(486397/33/25)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,3,buffer,3519002626(486397/33/39)) lseek err Invalid argument
file_pread(5,3,buffer,3519002673(486397/34/23)) lseek err Invalid argument
file_pread(5,8,buffer,3519002689(486397/34/39)) lseek err Invalid argument
file_pread(5,11,buffer,3519002736(486397/35/23)) lseek err Invalid argument
file_pread(5,2,buffer,3519004658(486397/65/55)) lseek err Invalid argument
file_pread(5,14,buffer,3519002613(486397/33/26)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,3,buffer,3519002627(486397/33/40)) lseek err Invalid argument
file_pread(5,3,buffer,3519002674(486397/34/24)) lseek err Invalid argument
file_pread(5,8,buffer,3519002690(486397/34/40)) lseek err Invalid argument
file_pread(5,11,buffer,3519002737(486397/35/24)) lseek err Invalid argument
file_pread(5,2,buffer,3519004659(486397/65/56)) lseek err Invalid argument
file_pread(5,14,buffer,3519002614(486397/33/27)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,3,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,3,buffer,3519002628(486397/33/41)) lseek err Invalid argument
file_pread(5,3,buffer,3519002675(486397/34/25)) lseek err Invalid argument
file_pread(5,8,buffer,3519002691(486397/34/41)) lseek err Invalid argument
file_pread(5,11,buffer,3519002738(486397/35/25)) lseek err Invalid argument
file_pread(5,2,buffer,3519004660(486397/65/57)) lseek err Invalid argument
file_pread(5,14,buffer,3519002615(486397/33/28)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,4,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,3,buffer,3519002629(486397/33/42)) lseek err Invalid argument
file_pread(5,3,buffer,3519002676(486397/34/26)) lseek err Invalid argument
file_pread(5,8,buffer,3519002692(486397/34/42)) lseek err Invalid argument
file_pread(5,11,buffer,3519002739(486397/35/26)) lseek err Invalid argument
file_pread(5,2,buffer,3519004661(486397/65/58)) lseek err Invalid argument
file_pread(5,14,buffer,3519002616(486397/33/29)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,3,buffer,3519002630(486397/33/43)) lseek err Invalid argument
file_pread(5,3,buffer,3519002677(486397/34/27)) lseek err Invalid argument
file_pread(5,8,buffer,3519002693(486397/34/43)) lseek err Invalid argument
file_pread(5,11,buffer,3519002740(486397/35/27)) lseek err Invalid argument
file_pread(5,2,buffer,3519004662(486397/65/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519004664(486397/65/61)) lseek err Invalid argument
file_pread(5,14,buffer,3519002618(486397/33/31)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,7,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,3,buffer,3519002632(486397/33/45)) lseek err Invalid argument
file_pread(5,3,buffer,3519002679(486397/34/29)) lseek err Invalid argument
file_pread(5,8,buffer,3519002695(486397/34/45)) lseek err Invalid argument
file_pread(5,11,buffer,3519002742(486397/35/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519004665(486397/65/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519004666(486397/65/63)) lseek err Invalid argument
file_pread(5,14,buffer,3519002620(486397/33/33)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,8,buffer,3519002702(486397/34/52)) lseek err Invalid argument
file_pread(5,11,buffer,3519002749(486397/35/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519004672(486397/66/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519004673(486397/66/7)) lseek err Invalid argument
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 486397/1/4
mft_lcn 0
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 4000 GB / 3725 GiB
NTFS at 486397/1/4
mft_lcn 0
mftmirr_lcn 2
MS Data 7813967871 15627933694 7813965824
This partition ends after the disk limits. (start=7813967871, size=7813965824, end=15627933694, disk end=7813969920)
file_pread(5,2,buffer,3519002623(486397/33/36)) ReadFile Le lecteur ne trouve pas le secteur demandé.
file_pread(5,2,buffer,3519002683(486397/34/33)) lseek err Invalid argument
file_pread(5,2,buffer,3519002687(486397/34/37)) lseek err Invalid argument
file_pread(5,2,buffer,3519002746(486397/35/33)) lseek err Invalid argument
The harddisk (4000 GB / 3725 GiB) seems too small! (< 8001 GB / 7451 GiB)
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
Status: OK
Status: OK
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn 0
ntfs_find_mft: mftmirr_lcn 2
ntfs_find_mft: mft_record_size 1024 bytes
mft_lcn 0
mftmirr_lcn 2
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
Status: OK
Status: OK
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
file_pread
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 486397/1/4
mft_lcn 0
mftmirr_lcn 2
NTFS at 486397/1/4
mft_lcn 0
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
Status: OK
Status: OK
rebuild_NTFS_BS
mft at 16
mft_lcn 0
mftmirr_lcn 2
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
Status: OK
Status: OK
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 0
mftmirr_lcn 2
file_pread
file_pread(5,3,buffer,3519002636(486397/33/49)) lseek err Invalid argument
file_pread(5,3,buffer,3519002683(486397/34/33)) lseek err Invalid argument
file_pread(5,8,buffer,3519002699(486397/34/49)) lseek err Invalid argument
file_pread(5,11,buffer,3519002746(486397/35/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519004669(486397/66/3)) lseek err Invalid argument
file_pread(5,12,buffer,3519002625(486397/33/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519004670(486397/66/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519004671(486397/66/5)) lseek err Invalid argument
file_pread(5,2,buffer,3519002637(486397/33/50)) lseek err Invalid argument
New options :
Dump : No
Align partition: Yes
Expert mode : No
New options :
Dump : No
Expert mode : No
i lunched the deep search for like one hour and stopped. i don't know if it is really needed.
thank again for your help.
Companies tested by a reputated German computer magazine:ZONAVIRUS wrote: 02 Oct 2019, 19:47 I'm seriously considering sending my hard drive to chronodisk in Paris, France or to stellar in brussels. what is your take on this ?
viewtopic.php?f=10&t=8596&p=27912&hilit=ontrack#p27912
Please do not forget to report the price and your experience with the company that you engage in this forum.
Thanks; i will do that, i'm still waiting for stellar to do its job. i'll decide afterwards.recuperation wrote: 02 Oct 2019, 20:39Companies tested by a reputated German computer magazine:ZONAVIRUS wrote: 02 Oct 2019, 19:47 I'm seriously considering sending my hard drive to chronodisk in Paris, France or to stellar in brussels. what is your take on this ?
Can you give me an idea of the damage based on the Log i posted ? thanks.
