My Pen drive doesn't open but is detected! Topic is solved
Vickybond
#1 Post by Vickybond »
I brought a KINGSTON 16GB Data traveler, but I soon realized that it was a fake one. I used the pen drive rarely. All of a sudden the pen drive did not respond and did not open. When I insert the pen drive it is detected(status LED goes on) and the drivers are installed. But when I try to open the properties of the Pen drive It doesn't show the file system and nor the size of the disk, but it is detected as well as the drive is healthy in the Disk Management. The pen drive asks for formatting but fails to format even with the popup menu format as well as the Disk Management format. Please help me gain my pen drive back.
Waiting in anticipation :?
Re: My Pen drive doesn't open but is detected!
Did you check the size?
If you'd like to recover data from it's not advisable to reformat it.
Can you check the size of your pen drive in your disk management console?
If your pen drive is listed correctly in your disk management console, you can diagnose the boot sector.
Might be this procedure;
Confirm at Boot.
Infos will follow.
Vickybond
#3 Post by Vickybond »
How can I send the screenshot attachment to you!!????
wargo
#4 Post by wargo »
Click "Post reply" and "Upload attachment" tab under submit buttons.
Vickybond
#5 Post by Vickybond »
I want to sent a docx file to show the screenshots and the file!! I am not able to send the screenshots.,.
