Can't recover my lost partition - Write error
cherkasskiy
#1 Post by cherkasskiy »
Hello. I've recently got a problem with one of my partitions - I've lost it after unsuccessful operation of changing partitions' sizes with Acronis Disk Director Suite. My computer has shut down while executing this operation, looks like some bag happened. I had three partitions before - one primary bootable and two logical ones, now only two of them have left, including bootable. Fortunately information on this partition isn't important for me (it's old win xp partition), so I just want to recover it for formatting, but to save other two partitions intact. The dial is that Acronis sees the structure like it would be if everything went fine - partitions with successfully changed sizes, without any unmarked area, so I can't recover partition with Acronis! But explorer doesn't see it.
I tried to recover partition with TestDisk, it has showed it in the table in analysis but weren't able to write showed structure to disk - Write error occurred. Please, help me to recover my lost partition (it's the 51 GB one).
Here is my .log file:
Thu Aug  2 01:37:29 2012
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=320071851520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=320071851520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=236230009344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=83840246784
filewin32_getfilesize(\\.\F:) GetFileSize err Неверная функция.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Неверная функция.
filewin32_getfilesize(\\.\H:) GetFileSize err Неверная функция.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Неверная функция.
file_pread(4,1,buffer,625153409(38913/254/63)) lseek err Invalid argument
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200AAKS-00SBA0, S/N:2020202057202d4443575041305a363137393235, FW:12.01B01
Disk /dev/sda - 320 GB / 298 GiB - WDC WD3200AAKS-00SBA0
Analyse Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
NTFS at 0/1/1
Info: size boot_sector 56629057, partition 56629062
NTFS at 10193/1/1
get_geometry_from_list_part_aux head=255 nbr=10
 1 * HPFS - NTFS              0   1  1  3524 254 63   56629062
 2 E extended LBA          3525   0  1 38912 254 63  568508220
Invalid NTFS or EXFAT boot
 5 L HPFS - NTFS           3525   1  1 10192 254 63  107121357
   X extended             10193   0  1 38912 254 63  461386800
 6 L HPFS - NTFS          10193   1  1 38912 254 63  461386737
Ask the user for vista mode
search_vista_part: 0
NTFS at 0/1/1
filesystem size           56629057
sectors_per_cluster       8
mftmirr_lcn               6399890
clusters_per_mft_record   -10
     HPFS - NTFS              0   1  1  3524 254 58   56629057
     NTFS, 28 GB / 27 GiB
NTFS at 10193/1/1
filesystem size           461386737
mft_lcn                   3356832
mftmirr_lcn               24970026
     NTFS, 236 GB / 220 GiB
file_pread(4,8,buffer,625140432(38913/49/1)) lseek err Invalid argument
file_pread(4,1,buffer,625140432(38913/49/1)) lseek err Invalid argument
file_pread(4,8,buffer,625140560(38913/51/3)) lseek err Invalid argument
file_pread(4,8,buffer,625140688(38913/53/5)) lseek err Invalid argument
file_pread(4,8,buffer,625140816(38913/55/7)) lseek err Invalid argument
file_pread(4,8,buffer,625140944(38913/57/9)) lseek err Invalid argument
file_pread(4,8,buffer,625141072(38913/59/11)) lseek err Invalid argument
file_pread(4,8,buffer,625141200(38913/61/13)) lseek err Invalid argument
file_pread(4,8,buffer,625141328(38913/63/15)) lseek err Invalid argument
file_pread(4,8,buffer,625141456(38913/65/17)) lseek err Invalid argument
file_pread(4,8,buffer,625141584(38913/67/19)) lseek err Invalid argument
file_pread(4,8,buffer,625141712(38913/69/21)) lseek err Invalid argument
file_pread(4,8,buffer,625141840(38913/71/23)) lseek err Invalid argument
file_pread(4,8,buffer,625141968(38913/73/25)) lseek err Invalid argument
file_pread(4,8,buffer,625142096(38913/75/27)) lseek err Invalid argument
file_pread(4,8,buffer,625142224(38913/77/29)) lseek err Invalid argument
file_pread(4,8,buffer,625142352(38913/79/31)) lseek err Invalid argument
file_pread(4,8,buffer,625142480(38913/81/33)) lseek err Invalid argument
file_pread(4,8,buffer,625142608(38913/83/35)) lseek err Invalid argument
file_pread(4,8,buffer,625142736(38913/85/37)) lseek err Invalid argument
file_pread(4,8,buffer,625142864(38913/87/39)) lseek err Invalid argument
file_pread(4,8,buffer,625142992(38913/89/41)) lseek err Invalid argument
file_pread(4,8,buffer,625143120(38913/91/43)) lseek err Invalid argument
file_pread(4,8,buffer,625143248(38913/93/45)) lseek err Invalid argument
file_pread(4,8,buffer,625143376(38913/95/47)) lseek err Invalid argument
file_pread(4,8,buffer,625143504(38913/97/49)) lseek err Invalid argument
file_pread(4,8,buffer,625143632(38913/99/51)) lseek err Invalid argument
file_pread(4,8,buffer,625143760(38913/101/53)) lseek err Invalid argument
file_pread(4,8,buffer,625143888(38913/103/55)) lseek err Invalid argument
file_pread(4,8,buffer,625144016(38913/105/57)) lseek err Invalid argument
file_pread(4,8,buffer,625144144(38913/107/59)) lseek err Invalid argument
file_pread(4,8,buffer,625144272(38913/109/61)) lseek err Invalid argument
file_pread(4,8,buffer,625144400(38913/111/63)) lseek err Invalid argument
file_pread(4,8,buffer,625144528(38913/114/2)) lseek err Invalid argument
file_pread(4,8,buffer,625144656(38913/116/4)) lseek err Invalid argument
file_pread(4,8,buffer,625144784(38913/118/6)) lseek err Invalid argument
file_pread(4,8,buffer,625144912(38913/120/8)) lseek err Invalid argument
file_pread(4,8,buffer,625145040(38913/122/10)) lseek err Invalid argument
file_pread(4,8,buffer,625145168(38913/124/12)) lseek err Invalid argument
file_pread(4,8,buffer,625145296(38913/126/14)) lseek err Invalid argument
file_pread(4,8,buffer,625145424(38913/128/16)) lseek err Invalid argument
file_pread(4,8,buffer,625145552(38913/130/18)) lseek err Invalid argument
file_pread(4,8,buffer,625145680(38913/132/20)) lseek err Invalid argument
write!
write_all_log_i386: CHS: 3525/0/1,lba=56629125
file_pwrite(4,1,buffer,56629125(3525/0/1)) write err Permission denied
write_all_log_i386: CHS: 10193/0/1,lba=163750545
Partition: Write error
UPD: Problem is solved, somehow after this actions with TestDrive explorer and Acronis see unformatted partition, I have just formatted it and everything is fine, thanks to TestDrive.
