Update Mac - Catalina // zsh: bad CPU type in executable
zilli
#1 Post by zilli »
I updated my mac and now i'm getting this message in terminal:
zsh: bad CPU type in executable:
Does that mean that photorec is no longer supported? If so; will there be an update for macOS Catalina?
Thank you!
Re: Update Mac - Catalina // zsh: bad CPU type in executable
You need to install testdisk
- via brew, see https://docs.brew.sh/Installation
brew install testdisk
- or to compile it as explained in https://www.cgsecurity.org/testdisk.pdf
gururlx
#3 Post by gururlx »
Is there any solution??
I ve installed Homebrew on my iMac runnnig Catalina....but when I Start PhotoRec I also got the same error
please help....
