segmentation fault on start
SHaran
#1 Post by SHaran »
The older version works...testdisk 7.0-3+b3
But not the newer versions. They fail on program startup...
 # testdisk-7.1/photorec_static
segmentation fault  testdisk-7.1/photorec_static
 # testdisk-7.2-WIP/photorec_static
segmentation fault  testdisk-7.2-WIP/photorec_static
# uname -a
Linux lenovo 4.19.0-1-grml-amd64 #1 SMP Debian 4.19.8-1+grml.1 (2018-12-11) x86_64 GNU/Linux
Re: segmentation fault on start
A kernel dependency must be unmeet. If you need latest version, try to compile testdisk.
Read https://www.cgsecurity.org/testdisk.pdf there is a chapter about compilation.
