1TB WD not seen in Win 10 - but yes in Test Disk 7.1
ozstar
#1 Post by ozstar »
Was okay this morning but now Win 10 1903 doesn't see the disk which has 2 partitions.
Disk Mgmt say it is unallocated.
I used Testdisk 7.1 and this was the result
TestDisk 7.1, Data Recovery Utility, July 2019 Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63 Current partition structure Partition Start End Size in sectors Partition sector doesn't have the endmark 0xAA55
Quick Search
>* HPFS - NTFS 0 32 33 51485 240 19 827119616 [WEBMAIN-PROGRAMS]
P HPFS - NTFS 51485 240 20 121600 247 55 1126397952 [WEBMAIN-GRAPHICS]
Continue
1 * HPFS - NTFS 0 32 33 51485 240 19 827119616 [WEBMAIN-PROGRAMS]
2 P HPFS - NTFS 51485 240 20 121600 247 55 1126397952 [WEBMAIN-GRAPHICS]
When I use P to list the files on both partitions I get this
Where to from here? Deeper Search or Write (Hopefully not over our files)?
Thank you
Re: 1TB WD not seen in Win 10 - but yes in Test Disk 7.1
ozstar wrote: 22 Oct 2019, 05:35 Where to from here? Deeper Search or Write (Hopefully not over our files)?
Run "deeper search" if you are missing further partitions.
Otherwise use Photorec to recover content.
Are you using Windows 10 in a dual boot configuration?
ozstar
#3 Post by ozstar »
Many thanks for your help.
No it isn't a dual boot.
I did try a Deeper Search but I know there are no more partitions.
So I guess I will try Photorec.
What do I click to do this as I have never used it before.
Thanks again.
ozstar
[SOLVED] 1TB WD not seen in Win 10 - but yes in Test Disk 7.1
#5 Post by ozstar »
Many thanks. Chose 'Write' in TestDisk.
Now all good after a reboot.
Great program. A saviour for sure.
Donated.
