The following partition can't be recovered
tirafesi
#1 Post by tirafesi »
I deleted a disk partition by mistake. How do I fix this?
Here's what I did, using the disk management tool in windows 10:
  • Disk had 2 partitions, A (~250Gb) and B (~650Gb).
  • I deleted partition A.
  • In order to use this new unallocated space, I right-clicked on partition B and chose expand volume.
  • The disk became dynamic (this had never happened to me before when handling partitions, so no idea why it happened here), having the same 2 partitions as before, but they now behaved as one.
  • This is not what I wanted, so I right-clicked on partition A and chose *delete volume* once again.
  • To my surprise, both partitions got deleted, and now the entire size of the disk shows as unallocated space.
Is there a way to recover partition B?
I tried using TestDisk, but it says The following partition can't be recovered about partition B, and only lets me recover partition A. Here is the log file from it.
Please help!
Re: The following partition can't be recovered
After Quick Search, try Deeper Search.
Use the arrow keys to switch the partition B from D(eleted) to P(rimary).
On the next screen, if the partitions A and B are correctly listed, choose Write, confirm, Quit and restart your computer.
tirafesi
#3 Post by tirafesi »
cgrenier wrote: 22 Oct 2019, 20:21 After Quick Search, try Deeper Search.
Hey, sorry about the delay responding.
I did what you told me, but now partition B shows up thrice. What should I do?
The only partition I'm interested in restoring is [Outros], but since it shows 3 of the same name I don't know which one to choose.
Here is the log:
Sat Oct 26 11:07:33 2019
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=424998977536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000200994816
Disk /dev/sda - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - TOSHIBA-TR200, S/N:291B620UK3QS, FW:SBFA12.6
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA DT01ACA100, S/N:259KG0BNS, FW:MS2OA750
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZRX-00D8PB0, S/N:WD-WCC4M2996861, FW:80.00A80
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA DT01ACA100
NTFS at 0/32/33
filesystem size           1024000
sectors_per_cluster       8
mft_lcn                   42666
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33    63 221 30    1024000 [Sistema Reservado]
     NTFS, blocksize=4096, 524 MB / 500 MiB
NTFS at 63/221/31
filesystem size           509269683
mftmirr_lcn               2
     HPFS - NTFS             63 221 31 31764 112 15  509269683
     NTFS, blocksize=4096, 260 GB / 242 GiB
NTFS at 31764/117/34
filesystem size           1701888
mft_lcn                   70912
mftmirr_lcn               2
     HPFS - NTFS          31764 117 34 31870 101 39    1701888
     NTFS, blocksize=4096, 871 MB / 831 MiB
NTFS at 31870/134/9
filesystem size           1953515520
mftmirr_lcn               2
     HPFS - NTFS          31870 134  9 153471  61 62 1953515520 [Outros]
This partition ends after the disk limits. (start=512000000, size=1953515520, end=2465515519, disk end=1953525168)
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 1262 GB / 1175 GiB)
   * HPFS - NTFS              0  32 33    63 221 30    1024000 [Sistema Reservado]
   P HPFS - NTFS             63 221 31 31764 117 33  509270016
   P HPFS - NTFS          31764 117 34 31870 101 39    1701888
 1 * HPFS - NTFS              0  32 33    63 221 30    1024000 [Sistema Reservado]
 2 P HPFS - NTFS             63 221 31 31764 117 33  509270016
 3 P HPFS - NTFS          31764 117 34 31870 101 39    1701888
NTFS at 0/32/33
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 12/223/19
filesystem size           204800
mft_lcn                   8533
mftmirr_lcn               2
     HPFS - NTFS              0  32 33    12 223 19     204800
NTFS at 12/223/20
filesystem size           511793152
mftmirr_lcn               2
     HPFS - NTFS             12 223 20 31870 134  8  511793152
     NTFS, blocksize=4096, 262 GB / 244 GiB
NTFS at 63/221/30
mft_lcn                   42666
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 524 MB / 500 MiB
NTFS at 63/221/31
mftmirr_lcn               2
recover_EXT2: s_block_group_nr=0/199, s_mnt_count=175/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 6553088
recover_EXT2: part_size 52424704
Filesystem created: Sun Mar  3 19:14:10 2019
Last mount time:    Wed Oct  2 15:19:20 2019
     Linux                29443 230 36 32707  48 45   52424704
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 26 GB / 24 GiB
     Linux                29450 135 62 32713 209  8   52424704
     Linux                29451 238 36 32715  56 45   52424704
mft_lcn                   70912
mftmirr_lcn               2
NTFS at 31870/101/39
mftmirr_lcn               2
NTFS part_offset=262142950912, part_size=1000199946240, sector_size=512
NTFS at 31870/134/8
filesystem size           510973952
mftmirr_lcn               2
     HPFS - NTFS             63 221 31 31870 134  8  510973952
     NTFS found using backup sector, blocksize=4096, 261 GB / 243 GiB
NTFS at 31870/134/9
mftmirr_lcn               2
NTFS at 115073/226/33
filesystem size           1336662016
mftmirr_lcn               2
     HPFS - NTFS          31870 134  9 115073 226 33 1336662016 [Outros]
     NTFS found using backup sector, blocksize=4096, 684 GB / 637 GiB
NTFS at 116379/77/50
filesystem size           1357633536
mftmirr_lcn               2
     HPFS - NTFS          31870 134  9 116379  77 50 1357633536 [Outros]
     NTFS found using backup sector, blocksize=4096, 695 GB / 647 GiB
NTFS at 121600/247/55
filesystem size           1441519616
mftmirr_lcn               2
     HPFS - NTFS          31870 134  9 121600 247 55 1441519616 [Outros]
     NTFS found using backup sector, blocksize=4096, 738 GB / 687 GiB
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
NTFS at 63/221/30
mft_lcn                   42666
mftmirr_lcn               2
NTFS at 31870/134/8
mftmirr_lcn               2
NTFS at 31870/134/8
mftmirr_lcn               2
NTFS at 31870/134/8
mftmirr_lcn               2
     HPFS - NTFS             63 221 30   127 155 27    1024000
     HPFS - NTFS          31870 134  8 63677  46 48  510973952
     NTFS, blocksize=4096, 261 GB / 243 GiB
Use the "p" key to examine the content of each partition.
Decide which partition seems to be the right one!
tirafesi
#5 Post by tirafesi »
recuperation wrote: 26 Oct 2019, 15:11 Use the "p" key to examine the content of each partition.
Thank you! Was able to restore the partition and all the data seems to be ok :D
