Scripted Run [Whole Disk]
hobocrunch
#1 Post by hobocrunch »
When I run photorec manually through the UI, I can choose [Whole Disk] instead of a partition.
I use the following
photorec /d /root/Documents/Recovery/dev/sdc /cmd /dev/sdc options,keep_corrupted_file,paranoid,fileopt,everything,enable,search
Using the command line I cannot find any combination that will select [Whole DIsk], it always chooses the default partition.
I've used
wholespace
and also tried
partition_none
Re: Scripted Run [Whole Disk]
It should work if you choose "partition_none".
As each filesystem may have a different blocksize or partition alignment, you may get better results if you search lost data partition by partition
