Need help to recover a 128GB microSDXC
robinthebest
#1 Post by robinthebest »
Tried using both photorec and testdisk to recover files, both unable to recover anyfiles.
Unable to rebuild boot sector, am i doing something wrong?
If i wanted to start from the get go, which log should i post first?
Re: Need help to recover a 128GB microSDXC
TestDisk generates a log file named testdisk.log, please copy and paste its content.
Is PhotoRec/TestDisk reporting the correct disk capacity ? If it's not the case, you should contact a data recovery company as the flash controller or the memory chip is probably damaged.
robinthebest
#3 Post by robinthebest »
cgrenier wrote: 28 Oct 2019, 06:51 TestDisk generates a log file named testdisk.log, please copy and paste its content.
should i do an analyze and post the log?
it is reporting the correct disk capacity
Even "thebest" might consider providing an error description. :idea:
Look what others users wrote and you will quickly get an idea what is useful or not.
Another good start is the manual:
Cross-read the documentation
to find information that applies to you.
robinthebest
#5 Post by robinthebest »
recuperation wrote: 28 Oct 2019, 17:37 Even "thebest" might consider providing an error description. :idea:
I'm sorry I didnt have the time to do a follow up before and i just did it today,
below are what i found from log, i did a quick search and deeper search and couldn't found anything, I also tried photorec but it didnt find any files either, Windows is telling I had to format the disk before using it
Mon Mar 2 23:51:44 2020
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=127865454592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=127865454592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249413238784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=127865454592
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO 250GB, S/N:S21MNXAGB16591X, FW:EMT02B6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-08WN4A0, S/N:WD-WCC6Y5VFFL5D, FW:02.01A02
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM006-2DM164, S/N:Z560TCR1, FW:CC26
Disk /dev/sdd - 127 GB / 119 GiB - CHS 15545 255 63, sector size=512 - Mass Storage Device, S/N:121220160204, FW:1.00
Disk /dev/sdd - 127 GB / 119 GiB - Mass Storage Device
Analyse Disk /dev/sdd - 127 GB / 119 GiB - CHS 15545 255 63
file_pread(7,1,buffer,249737217(15545/107/52)) lseek err Invalid argument
file_pread(7,14,buffer,249737218(15545/107/53)) lseek err Invalid argument
file_pread(7,3,buffer,249737232(15545/108/4)) lseek err Invalid argument
file_pread(7,3,buffer,249737279(15545/108/51)) lseek err Invalid argument
file_pread(7,8,buffer,249737295(15545/109/4)) lseek err Invalid argument
file_pread(7,11,buffer,249737342(15545/109/51)) lseek err Invalid argument
file_pread(7,2,buffer,249739264(15545/140/20)) lseek err Invalid argument
#6 Post by recuperation »
I would either use a hex editor to look the drive's sectors just to see if that produces read errors or not.
If you duplicate the drive with ddrescue you can check the logfile during and after recovery to see where a sector is not accessible.
You did not say what you expected to see on your drive.
robinthebest
#7 Post by robinthebest »
recuperation wrote: 02 Mar 2020, 18:19 I would either use a hex editor to look the drive's sectors just to see if that produces read errors or not.
I will try to duplicate the drive with DDR, but i don't get the hex editor part, how do I do it?
I had a lot of photos in this SD card, so basically i wanted to recover them, at least recover some of it
#8 Post by recuperation »
robinthebest wrote: 03 Mar 2020, 17:24
Has your drive been encrypted?
You open the drive with a hex editor like HxD p.e.. You scroll through the sectors awaiting a "read error" message box.
Simultaneously you look at the content. Maybe you only see zeros.
robinthebest
#9 Post by robinthebest »
recuperation wrote: 03 Mar 2020, 20:18
No, it has not been encrypted.
And strangely, after i had right click on the drive in explorer with open as portable device, i can click into the drive again, although after I click into the folder the explorer completely froze, so what should i do in this case? should i just use photorec or i should try repairing it by using testdisk first?
robinthebest
#10 Post by robinthebest »
i can only read the sd through photorec/testdisk for a short amount of time after i entered windows, after a while it told me i have to format it before using it again, i have to reboot my pc to let both app to read the sd again, what can i do?
