Unable to see all partitions in Windows Explorer
Sway06
#1 Post by Sway06 »
Hello!
Thanks for a great software!
I am currently not able to see all partitions in Windows Explorer. Only one partitio (10 MB) appears.
Could you please review the logs and let me know if I did anything wrong? What can I try to do next?
Many thanks in advance for your help!
testdisk.zip
(14.18 KiB) Downloaded 399 times
Re: Unable to see all partitions in Windows Explorer
The main partition of this disk is an HFSX filesystem, a filesystem used on macos.
Windows is unable to list files from HFSX partition.
Sway06
#3 Post by Sway06 »
Are you saying that the HFSX partition and the files included in it can only be visible on Mac? Is it possible to change the partition type so the partition and files will be accessible on Windows? Thank you.
