Photorec stuck on one sector and one file
egen
#1 Post by egen »
Hi
Photorec stuck on one sector and recover one .mp3 file again and again after few hours i have over 500000 same mp3 files so I quit recovery process. Then i try to switch off MP3 files from recovery. But on same sector is another "cycled" file M3U. What shoud I do now? Is there way to skip this sector? Or some switch in options to skip this behavior?
My setting is paranoid yes (brute force no)
Thank for any answer.
Re: Photorec stuck on one sector and one file
Can you double check that you are not saving the recovered files on the source ?
