List Dissapeared after Scan
Where does the list of recovered drives go after the scan that took over 24 hours? It found partitions listed in green, was trying to figure out which one I needed to recover and then it disappears while trying to navigate and look at options. Now its scanning again and going just as slow. Why is it doing the same thing again? I should be able to go back to the list it ALREADY found and select the one I want to recover.
Re: List Dissapeared after Scan
As I am answering your post after 24h, TestDisk have probably displayed a list of partitions again.
You have probably selected Deeper Scan after Quick Scan...
