Hi, i try to rescue some .3ds Files:
(3DS Max FileFilename extension .3ds
Internet media type application/x-3ds, image/x-3ds
Magic number 4D 4D (hex), MM (ASCII)
Developed by Autodesk Inc.
Type of format 3D file formats (From Wikipedia)
I saw that 3ds max files are under the supported file types . But i don´t get one. I do not want to rescue .max files i want to rescue .3ds files. So i tried to make a custom signature with a photorec.sig (Signature-File) but i failed every time
and fidentify_win.exe will not recognize my file.
3ds 0 "3D Studio File", 0x4D4D, "3D-Object"
3ds 0 "3D Studio File, 4D4D, "3D-Object
and so on ....
What i do wrong?
TockTock
File-Signature .3ds vs. .max
Re: File-Signature .3ds vs. .max
Can you share some file samples ? I will check the signature.
I am happy to send you this .3ds example file for your inspection (yuhuu):
https://www.dropbox.com/s/6jtlujyvxmxc2 ... 9.3ds?dl=0
and
https://www.dropbox.com/s/p28rcfxx8mao1 ... 9.3ds?dl=0
Source: http://www.archibase.net
Greetings
TockTock
and
Greetings
TockTock
Sorry for the late answer. I have uploaded a new 7.2-WIP that recover 3ds files. Can you try it ?
