Have 3TB drive go RAW
grumbleskin
#1 Post by grumbleskin »
I have a 3TB drive go RAW after a electrical flux. I don't actually believe the drive is damaged.
I am trying to get back my partition. I think I have good Boot Sectors that are matching but TestDisk won't let me doing anything with it. My MFT is botched I think.
I am currently allowing TestDisk do a search for a partition. Not sure if that is the right thing to do.
Here is my logfile. Could I please get someone more experienced than me to take a look and tell me what I should be doing. Thanks in advance for any help offered.
It is currently running, looking for a partition and is at 34%. It has found an:
MS Data 2048 5860358136 5860356089
Unknown 188009956 28612728716578275 28612728528568320
check_FAT: Bad number of sectors per cluster ~?M-|d~ZM-,M-4)(^XzHPM-xM-{~Z~Pn1oM-1~Ci*d^V~]~L^Q [^Z
Mac HFS 1203275020 1205241098 1966079 [Q^O~]0pM-+M-|],M-C~AH˒8M-3]
Mac HFS 1201308945 1203275023 1966079 [Q^O~]0pM-+M-|],M-C~AH˒8M-3]
oddly enough I have never run anything Mac in my life. Should be a GPT - NTFS Drive.
Tue Nov 12 20:43:12 2019
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdi)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdj)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdk)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdl)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdm)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdn)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive10)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive11)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive12)=2000313909248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive13)=3000504418304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249381781504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=250058113024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=250058113024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=3000502321152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=3000501272576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=2000311812096
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=3000485543936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=3000591450112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=3000502321152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=500105740288
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - CT250MX500SSD1, S/N:1933E219C36C, FW:M3CR023
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - CT250MX500SSD1, S/N:193022FFB1D5, FW:M3CR023
Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - CT250MX500SSD1, S/N:1933E219C317, FW:M3CR023
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00D8PB0, S/N:WD-WMC4N0D8ZY6X, FW:80.00A80
Disk /dev/sde - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00SPEB0, S/N:WD-WCC4E73FYU7N, FW:80.00A80
Disk /dev/sdf - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKX-001CA0, S/N:WD-WMAYUD893560, FW:15.01H15
Disk /dev/sdg - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512 - HPT VD0-0, FW:4.00
Disk /dev/sdh - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512 - HPT VD0-1, FW:4.00
Disk /dev/sdi - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512 - HPT VD0-2, FW:4.00
Disk /dev/sdj - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512 - HPT VD0-3, FW:4.00
Disk /dev/sdk - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512 - HPT VD0-4, FW:4.00
Disk /dev/sdl - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512 - HPT VD0-5, FW:4.00
Disk /dev/sdm - 2000 GB / 1862 GiB - CHS 243190 255 63, sector size=512 - HPT VD0-6, FW:4.00
Disk /dev/sdn - 3000 GB / 2794 GiB - CHS 364790 255 63, sector size=512 - HPT VD0-7, FW:4.00
Disk /dev/sde - 3000 GB / 2794 GiB - WDC WD30EZRX-00SPEB0
Partition table type: EFI GPT
Analyse Disk /dev/sde - 3000 GB / 2794 GiB - CHS 364801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 2048 5860358143 5860356096 [Basic data partition]
NTFS at 0/32/33
filesystem size 5860356089
mft_lcn 22359
mftmirr_lcn 22358
NTFS part_offset=1048576, part_size=3000502317568, sector_size=512
NTFS at 0/32/33
mft_lcn 22359
mftmirr_lcn 22358
NTFS at 364790/107/53
mft_lcn 22359
mftmirr_lcn 22358
MS Data 2055 5860358143 5860356089
NTFS found using backup sector, blocksize=4096, 3000 GB / 2794 GiB
mft_lcn 22359
mftmirr_lcn 22358
file_pread(8,2,buffer,5860537021(364801/142/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860537021(364801/142/11)) lseek err Invalid argument
NTFS: Can't read MFT
MS Data 5860358143 11720714231 5860356089
This partition ends after the disk limits. (start=5860358143, size=5860356089, end=11720714231, disk end=5860533168)
file_pread(8,1,buffer,5860533168(364801/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(8,1,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533170(364801/81/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533171(364801/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533172(364801/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533173(364801/81/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533174(364801/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533175(364801/81/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533176(364801/81/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533177(364801/81/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533178(364801/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533179(364801/81/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533180(364801/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533181(364801/81/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533182(364801/81/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533183(364801/81/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533184(364801/81/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533185(364801/81/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533186(364801/81/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533187(364801/81/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533188(364801/81/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533189(364801/81/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533190(364801/81/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533191(364801/81/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533192(364801/81/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533193(364801/81/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533194(364801/81/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533195(364801/81/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533196(364801/81/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533197(364801/81/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533198(364801/81/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533199(364801/81/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533200(364801/81/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533201(364801/81/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533202(364801/81/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533203(364801/81/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533204(364801/81/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533205(364801/81/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533206(364801/81/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533207(364801/81/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533208(364801/81/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533209(364801/81/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533210(364801/81/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533211(364801/81/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533212(364801/81/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533213(364801/81/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533214(364801/81/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533215(364801/81/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533216(364801/81/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533217(364801/81/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533218(364801/81/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533219(364801/81/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533220(364801/81/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533221(364801/81/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533222(364801/81/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533223(364801/81/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533224(364801/81/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533225(364801/81/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533226(364801/81/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533227(364801/81/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533228(364801/81/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533229(364801/81/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533230(364801/81/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533231(364801/82/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533232(364801/82/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533233(364801/82/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533234(364801/82/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533235(364801/82/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533236(364801/82/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533237(364801/82/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533238(364801/82/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533239(364801/82/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533240(364801/82/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533241(364801/82/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533242(364801/82/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533243(364801/82/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533244(364801/82/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533245(364801/82/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533246(364801/82/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533247(364801/82/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533248(364801/82/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533249(364801/82/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533250(364801/82/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533251(364801/82/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533252(364801/82/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533253(364801/82/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533254(364801/82/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533255(364801/82/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533256(364801/82/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533257(364801/82/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533258(364801/82/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533259(364801/82/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533260(364801/82/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533261(364801/82/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533262(364801/82/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533263(364801/82/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533264(364801/82/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533265(364801/82/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533266(364801/82/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533267(364801/82/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533268(364801/82/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533269(364801/82/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533270(364801/82/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533271(364801/82/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533272(364801/82/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533273(364801/82/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533274(364801/82/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533275(364801/82/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533276(364801/82/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533277(364801/82/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533278(364801/82/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533279(364801/82/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533280(364801/82/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533281(364801/82/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533282(364801/82/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533283(364801/82/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533284(364801/82/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533285(364801/82/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533286(364801/82/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533287(364801/82/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533288(364801/82/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533289(364801/82/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533290(364801/82/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533291(364801/82/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533292(364801/82/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533293(364801/82/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533294(364801/83/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533295(364801/83/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533296(364801/83/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533297(364801/83/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533298(364801/83/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533299(364801/83/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533300(364801/83/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533301(364801/83/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533302(364801/83/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533303(364801/83/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533304(364801/83/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533305(364801/83/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533306(364801/83/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533307(364801/83/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533308(364801/83/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533309(364801/83/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533310(364801/83/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533311(364801/83/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533312(364801/83/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533313(364801/83/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533314(364801/83/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533315(364801/83/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533316(364801/83/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533317(364801/83/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533318(364801/83/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533319(364801/83/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533320(364801/83/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533321(364801/83/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533322(364801/83/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533323(364801/83/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533324(364801/83/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533325(364801/83/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533326(364801/83/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533327(364801/83/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533328(364801/83/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533329(364801/83/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533330(364801/83/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533331(364801/83/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533332(364801/83/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533333(364801/83/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533334(364801/83/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533335(364801/83/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533336(364801/83/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533337(364801/83/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533338(364801/83/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533339(364801/83/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533340(364801/83/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533341(364801/83/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533342(364801/83/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533343(364801/83/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533344(364801/83/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533345(364801/83/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533346(364801/83/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533347(364801/83/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533348(364801/83/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533349(364801/83/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533350(364801/83/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533351(364801/83/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533352(364801/83/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533353(364801/83/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533354(364801/83/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533355(364801/83/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533356(364801/83/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533357(364801/84/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533358(364801/84/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533359(364801/84/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533360(364801/84/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533361(364801/84/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533362(364801/84/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533363(364801/84/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533364(364801/84/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533365(364801/84/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533366(364801/84/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533367(364801/84/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533368(364801/84/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533369(364801/84/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533370(364801/84/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533371(364801/84/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533372(364801/84/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533373(364801/84/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533374(364801/84/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533375(364801/84/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533376(364801/84/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533377(364801/84/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533378(364801/84/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533379(364801/84/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533380(364801/84/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533381(364801/84/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533382(364801/84/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533383(364801/84/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533384(364801/84/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533385(364801/84/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533386(364801/84/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533387(364801/84/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533388(364801/84/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533389(364801/84/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533390(364801/84/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533391(364801/84/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533392(364801/84/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533393(364801/84/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533394(364801/84/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533395(364801/84/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533396(364801/84/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533397(364801/84/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533398(364801/84/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533399(364801/84/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533400(364801/84/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533401(364801/84/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533402(364801/84/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533403(364801/84/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533404(364801/84/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533405(364801/84/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533406(364801/84/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533407(364801/84/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533408(364801/84/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533409(364801/84/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533410(364801/84/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533411(364801/84/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533412(364801/84/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533413(364801/84/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533414(364801/84/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533415(364801/84/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533416(364801/84/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533417(364801/84/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533418(364801/84/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533419(364801/84/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533420(364801/85/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533421(364801/85/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533422(364801/85/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533423(364801/85/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533424(364801/85/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533425(364801/85/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533426(364801/85/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533427(364801/85/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533428(364801/85/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533429(364801/85/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533430(364801/85/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533431(364801/85/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533432(364801/85/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533433(364801/85/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533434(364801/85/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533435(364801/85/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533436(364801/85/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533437(364801/85/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533438(364801/85/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533439(364801/85/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533440(364801/85/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533441(364801/85/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533442(364801/85/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533443(364801/85/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533444(364801/85/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533445(364801/85/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533446(364801/85/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533447(364801/85/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533448(364801/85/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533449(364801/85/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533450(364801/85/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533451(364801/85/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533452(364801/85/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533453(364801/85/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533454(364801/85/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533455(364801/85/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533456(364801/85/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533457(364801/85/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533458(364801/85/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533459(364801/85/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533460(364801/85/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533461(364801/85/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533462(364801/85/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533463(364801/85/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533464(364801/85/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533465(364801/85/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533466(364801/85/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533467(364801/85/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533468(364801/85/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533469(364801/85/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533470(364801/85/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533471(364801/85/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533472(364801/85/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533473(364801/85/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533474(364801/85/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533475(364801/85/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533476(364801/85/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533477(364801/85/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533478(364801/85/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533479(364801/85/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533480(364801/85/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533481(364801/85/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533482(364801/85/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533483(364801/86/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533484(364801/86/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533485(364801/86/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533486(364801/86/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533487(364801/86/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533488(364801/86/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533489(364801/86/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533490(364801/86/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533491(364801/86/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533492(364801/86/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533493(364801/86/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533494(364801/86/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533495(364801/86/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533496(364801/86/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533497(364801/86/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533498(364801/86/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533499(364801/86/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533500(364801/86/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533501(364801/86/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533502(364801/86/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533503(364801/86/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533504(364801/86/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533505(364801/86/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533506(364801/86/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533507(364801/86/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533508(364801/86/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533509(364801/86/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533510(364801/86/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533511(364801/86/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533512(364801/86/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533513(364801/86/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533514(364801/86/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533515(364801/86/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533516(364801/86/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533517(364801/86/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533518(364801/86/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533519(364801/86/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533520(364801/86/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533521(364801/86/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533522(364801/86/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533523(364801/86/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533524(364801/86/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533525(364801/86/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533526(364801/86/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533527(364801/86/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533528(364801/86/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533529(364801/86/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533530(364801/86/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533531(364801/86/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533532(364801/86/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533533(364801/86/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533534(364801/86/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533535(364801/86/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533536(364801/86/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533537(364801/86/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533538(364801/86/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533539(364801/86/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533540(364801/86/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533541(364801/86/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533542(364801/86/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533543(364801/86/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533544(364801/86/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533545(364801/86/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533546(364801/87/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533547(364801/87/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533548(364801/87/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533549(364801/87/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533550(364801/87/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533551(364801/87/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533552(364801/87/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533553(364801/87/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533554(364801/87/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533555(364801/87/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533556(364801/87/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533557(364801/87/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533558(364801/87/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533559(364801/87/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533560(364801/87/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533561(364801/87/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533562(364801/87/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533563(364801/87/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533564(364801/87/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533565(364801/87/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533566(364801/87/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533567(364801/87/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533568(364801/87/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533569(364801/87/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533570(364801/87/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533571(364801/87/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533572(364801/87/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533573(364801/87/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533574(364801/87/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533575(364801/87/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533576(364801/87/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533577(364801/87/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533578(364801/87/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533579(364801/87/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533580(364801/87/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533581(364801/87/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533582(364801/87/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533583(364801/87/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533584(364801/87/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533585(364801/87/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533586(364801/87/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533587(364801/87/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533588(364801/87/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533589(364801/87/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533590(364801/87/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533591(364801/87/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533592(364801/87/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533593(364801/87/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533594(364801/87/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533595(364801/87/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533596(364801/87/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533597(364801/87/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533598(364801/87/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533599(364801/87/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533600(364801/87/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533601(364801/87/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533602(364801/87/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533603(364801/87/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533604(364801/87/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533605(364801/87/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533606(364801/87/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533607(364801/87/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533608(364801/87/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533609(364801/88/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533610(364801/88/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533611(364801/88/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533612(364801/88/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533613(364801/88/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533614(364801/88/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533615(364801/88/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533616(364801/88/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533617(364801/88/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533618(364801/88/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533619(364801/88/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533620(364801/88/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533621(364801/88/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533622(364801/88/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533623(364801/88/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533624(364801/88/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533625(364801/88/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533626(364801/88/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533627(364801/88/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533628(364801/88/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533629(364801/88/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533630(364801/88/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533631(364801/88/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533632(364801/88/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533633(364801/88/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533634(364801/88/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533635(364801/88/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533636(364801/88/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533637(364801/88/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533638(364801/88/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533639(364801/88/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533640(364801/88/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533641(364801/88/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533642(364801/88/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533643(364801/88/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533644(364801/88/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533645(364801/88/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533646(364801/88/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533647(364801/88/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533648(364801/88/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533649(364801/88/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533650(364801/88/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533651(364801/88/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533652(364801/88/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533653(364801/88/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533654(364801/88/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533655(364801/88/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533656(364801/88/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533657(364801/88/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533658(364801/88/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533659(364801/88/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533660(364801/88/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533661(364801/88/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533662(364801/88/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533663(364801/88/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533664(364801/88/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533665(364801/88/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533666(364801/88/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533667(364801/88/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533668(364801/88/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533669(364801/88/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533670(364801/88/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533671(364801/88/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533672(364801/89/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533673(364801/89/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533674(364801/89/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533675(364801/89/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533676(364801/89/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533677(364801/89/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533678(364801/89/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533679(364801/89/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533680(364801/89/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533681(364801/89/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533682(364801/89/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533683(364801/89/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533684(364801/89/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533685(364801/89/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533686(364801/89/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533687(364801/89/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533688(364801/89/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533689(364801/89/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533690(364801/89/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533691(364801/89/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533692(364801/89/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533693(364801/89/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533694(364801/89/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533695(364801/89/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533696(364801/89/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533697(364801/89/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533698(364801/89/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533699(364801/89/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533700(364801/89/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533701(364801/89/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533702(364801/89/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533703(364801/89/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533704(364801/89/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533705(364801/89/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533706(364801/89/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533707(364801/89/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533708(364801/89/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533709(364801/89/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533710(364801/89/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533711(364801/89/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533712(364801/89/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533713(364801/89/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533714(364801/89/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533715(364801/89/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533716(364801/89/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533717(364801/89/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533718(364801/89/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533719(364801/89/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533720(364801/89/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533721(364801/89/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533722(364801/89/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533723(364801/89/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533724(364801/89/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533725(364801/89/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533726(364801/89/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533727(364801/89/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533728(364801/89/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533729(364801/89/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533730(364801/89/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533731(364801/89/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533732(364801/89/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533733(364801/89/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533734(364801/89/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533735(364801/90/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533736(364801/90/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533737(364801/90/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533738(364801/90/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533739(364801/90/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533740(364801/90/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533741(364801/90/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533742(364801/90/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533743(364801/90/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533744(364801/90/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533745(364801/90/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533746(364801/90/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533747(364801/90/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533748(364801/90/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533749(364801/90/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533750(364801/90/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533751(364801/90/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533752(364801/90/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533753(364801/90/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533754(364801/90/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533755(364801/90/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533756(364801/90/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533757(364801/90/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533758(364801/90/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533759(364801/90/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533760(364801/90/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533761(364801/90/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533762(364801/90/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533763(364801/90/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533764(364801/90/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533765(364801/90/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533766(364801/90/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533767(364801/90/33)) lseek err Invalid argument
grumbleskin
Re: Have 3TB drive go RAW
#2 Post by grumbleskin »
continued:
file_pread(8,1,buffer,5860533768(364801/90/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533769(364801/90/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533770(364801/90/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533771(364801/90/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533772(364801/90/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533773(364801/90/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533774(364801/90/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533775(364801/90/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533776(364801/90/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533777(364801/90/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533778(364801/90/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533779(364801/90/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533780(364801/90/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533781(364801/90/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533782(364801/90/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533783(364801/90/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533784(364801/90/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533785(364801/90/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533786(364801/90/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533787(364801/90/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533788(364801/90/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533789(364801/90/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533790(364801/90/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533791(364801/90/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533792(364801/90/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533793(364801/90/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533794(364801/90/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533795(364801/90/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533796(364801/90/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533797(364801/90/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533798(364801/91/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533799(364801/91/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533800(364801/91/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533801(364801/91/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533802(364801/91/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533803(364801/91/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533804(364801/91/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533805(364801/91/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533806(364801/91/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533807(364801/91/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533808(364801/91/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533809(364801/91/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533810(364801/91/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533811(364801/91/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533812(364801/91/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533813(364801/91/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533814(364801/91/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533815(364801/91/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533816(364801/91/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533817(364801/91/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533818(364801/91/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533819(364801/91/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533820(364801/91/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533821(364801/91/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533822(364801/91/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533823(364801/91/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533824(364801/91/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533825(364801/91/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533826(364801/91/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533827(364801/91/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533828(364801/91/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533829(364801/91/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533830(364801/91/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533831(364801/91/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533832(364801/91/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533833(364801/91/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533834(364801/91/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533835(364801/91/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533836(364801/91/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533837(364801/91/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533838(364801/91/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533839(364801/91/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533840(364801/91/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533841(364801/91/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533842(364801/91/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533843(364801/91/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533844(364801/91/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533845(364801/91/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533846(364801/91/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533847(364801/91/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533848(364801/91/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533849(364801/91/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533850(364801/91/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533851(364801/91/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533852(364801/91/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533853(364801/91/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533854(364801/91/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533855(364801/91/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533856(364801/91/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533857(364801/91/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533858(364801/91/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533859(364801/91/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533860(364801/91/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533861(364801/92/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533862(364801/92/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533863(364801/92/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533864(364801/92/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533865(364801/92/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533866(364801/92/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533867(364801/92/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533868(364801/92/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533869(364801/92/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533870(364801/92/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533871(364801/92/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533872(364801/92/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533873(364801/92/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533874(364801/92/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533875(364801/92/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533876(364801/92/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533877(364801/92/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533878(364801/92/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533879(364801/92/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533880(364801/92/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533881(364801/92/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533882(364801/92/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533883(364801/92/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533884(364801/92/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533885(364801/92/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533886(364801/92/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533887(364801/92/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533888(364801/92/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533889(364801/92/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533890(364801/92/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533891(364801/92/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533892(364801/92/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533893(364801/92/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533894(364801/92/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533895(364801/92/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533896(364801/92/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533897(364801/92/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533898(364801/92/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533899(364801/92/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533900(364801/92/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533901(364801/92/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533902(364801/92/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533903(364801/92/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533904(364801/92/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533905(364801/92/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533906(364801/92/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533907(364801/92/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533908(364801/92/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533909(364801/92/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533910(364801/92/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533911(364801/92/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533912(364801/92/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533913(364801/92/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533914(364801/92/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533915(364801/92/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533916(364801/92/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533917(364801/92/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533918(364801/92/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533919(364801/92/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533920(364801/92/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533921(364801/92/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533922(364801/92/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533923(364801/92/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533924(364801/93/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533925(364801/93/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533926(364801/93/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533927(364801/93/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533928(364801/93/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533929(364801/93/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533930(364801/93/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533931(364801/93/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533932(364801/93/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533933(364801/93/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533934(364801/93/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533935(364801/93/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533936(364801/93/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533937(364801/93/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533938(364801/93/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533939(364801/93/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533940(364801/93/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533941(364801/93/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533942(364801/93/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860533943(364801/93/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860533944(364801/93/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533945(364801/93/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533946(364801/93/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533947(364801/93/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533948(364801/93/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533949(364801/93/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533950(364801/93/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860533951(364801/93/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533952(364801/93/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533953(364801/93/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533954(364801/93/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533955(364801/93/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533956(364801/93/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533957(364801/93/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533958(364801/93/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533959(364801/93/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533960(364801/93/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533961(364801/93/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533962(364801/93/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533963(364801/93/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533964(364801/93/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533965(364801/93/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533966(364801/93/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860533967(364801/93/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533968(364801/93/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533969(364801/93/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533970(364801/93/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533971(364801/93/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533972(364801/93/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533973(364801/93/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533974(364801/93/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533975(364801/93/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533976(364801/93/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533977(364801/93/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533978(364801/93/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533979(364801/93/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533980(364801/93/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533981(364801/93/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533982(364801/93/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533983(364801/93/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533984(364801/93/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533985(364801/93/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533986(364801/93/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533987(364801/94/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533988(364801/94/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533989(364801/94/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533990(364801/94/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533991(364801/94/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533992(364801/94/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533993(364801/94/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533994(364801/94/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533995(364801/94/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533996(364801/94/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533997(364801/94/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533998(364801/94/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533999(364801/94/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534000(364801/94/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534001(364801/94/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534002(364801/94/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534003(364801/94/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534004(364801/94/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534005(364801/94/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534006(364801/94/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534007(364801/94/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534008(364801/94/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534009(364801/94/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534010(364801/94/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534011(364801/94/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534012(364801/94/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534013(364801/94/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534014(364801/94/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534015(364801/94/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534016(364801/94/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534017(364801/94/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534018(364801/94/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534019(364801/94/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534020(364801/94/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534021(364801/94/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534022(364801/94/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534023(364801/94/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534024(364801/94/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534025(364801/94/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534026(364801/94/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534027(364801/94/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534028(364801/94/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534029(364801/94/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534030(364801/94/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534031(364801/94/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534032(364801/94/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534033(364801/94/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534034(364801/94/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534035(364801/94/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534036(364801/94/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534037(364801/94/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534038(364801/94/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534039(364801/94/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534040(364801/94/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534041(364801/94/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534042(364801/94/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534043(364801/94/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534044(364801/94/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534045(364801/94/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534046(364801/94/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534047(364801/94/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534048(364801/94/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534049(364801/94/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534050(364801/95/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534051(364801/95/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534052(364801/95/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534053(364801/95/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534054(364801/95/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534055(364801/95/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534056(364801/95/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534057(364801/95/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534058(364801/95/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534059(364801/95/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534060(364801/95/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534061(364801/95/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534062(364801/95/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534063(364801/95/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534064(364801/95/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534065(364801/95/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534066(364801/95/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534067(364801/95/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534068(364801/95/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534069(364801/95/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534070(364801/95/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534071(364801/95/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534072(364801/95/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534073(364801/95/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534074(364801/95/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534075(364801/95/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534076(364801/95/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534077(364801/95/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534078(364801/95/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534079(364801/95/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534080(364801/95/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534081(364801/95/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534082(364801/95/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534083(364801/95/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534084(364801/95/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534085(364801/95/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534086(364801/95/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534087(364801/95/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534088(364801/95/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534089(364801/95/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534090(364801/95/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534091(364801/95/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534092(364801/95/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534093(364801/95/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534094(364801/95/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534095(364801/95/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534096(364801/95/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534097(364801/95/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534098(364801/95/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534099(364801/95/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534100(364801/95/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534101(364801/95/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534102(364801/95/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534103(364801/95/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534104(364801/95/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534105(364801/95/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534106(364801/95/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534107(364801/95/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534108(364801/95/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534109(364801/95/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534110(364801/95/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534111(364801/95/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534112(364801/95/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534113(364801/96/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534114(364801/96/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534115(364801/96/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534116(364801/96/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534117(364801/96/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534118(364801/96/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534119(364801/96/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534120(364801/96/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534121(364801/96/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534122(364801/96/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534123(364801/96/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534124(364801/96/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534125(364801/96/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534126(364801/96/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534127(364801/96/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534128(364801/96/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534129(364801/96/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534130(364801/96/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534131(364801/96/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534132(364801/96/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534133(364801/96/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534134(364801/96/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534135(364801/96/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534136(364801/96/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534137(364801/96/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534138(364801/96/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534139(364801/96/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534140(364801/96/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534141(364801/96/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534142(364801/96/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534143(364801/96/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534144(364801/96/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534145(364801/96/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534146(364801/96/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534147(364801/96/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534148(364801/96/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534149(364801/96/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534150(364801/96/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534151(364801/96/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534152(364801/96/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534153(364801/96/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534154(364801/96/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534155(364801/96/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534156(364801/96/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534157(364801/96/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534158(364801/96/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534159(364801/96/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534160(364801/96/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534161(364801/96/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534162(364801/96/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534163(364801/96/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534164(364801/96/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534165(364801/96/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534166(364801/96/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534167(364801/96/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534168(364801/96/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534169(364801/96/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534170(364801/96/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534171(364801/96/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534172(364801/96/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534173(364801/96/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534174(364801/96/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534175(364801/96/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534176(364801/97/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534177(364801/97/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534178(364801/97/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534179(364801/97/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534180(364801/97/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534181(364801/97/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534182(364801/97/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534183(364801/97/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534184(364801/97/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534185(364801/97/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534186(364801/97/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534187(364801/97/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534188(364801/97/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534189(364801/97/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534190(364801/97/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534191(364801/97/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534192(364801/97/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534193(364801/97/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534194(364801/97/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534195(364801/97/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534196(364801/97/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534197(364801/97/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534198(364801/97/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534199(364801/97/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534200(364801/97/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534201(364801/97/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534202(364801/97/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534203(364801/97/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534204(364801/97/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534205(364801/97/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534206(364801/97/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534207(364801/97/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534208(364801/97/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534209(364801/97/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534210(364801/97/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534211(364801/97/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534212(364801/97/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534213(364801/97/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534214(364801/97/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534215(364801/97/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534216(364801/97/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534217(364801/97/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534218(364801/97/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534219(364801/97/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534220(364801/97/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534221(364801/97/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534222(364801/97/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534223(364801/97/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534224(364801/97/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534225(364801/97/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534226(364801/97/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534227(364801/97/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534228(364801/97/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534229(364801/97/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534230(364801/97/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534231(364801/97/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534232(364801/97/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534233(364801/97/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534234(364801/97/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534235(364801/97/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534236(364801/97/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534237(364801/97/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534238(364801/97/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534239(364801/98/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534240(364801/98/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534241(364801/98/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534242(364801/98/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534243(364801/98/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534244(364801/98/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534245(364801/98/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534246(364801/98/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534247(364801/98/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534248(364801/98/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534249(364801/98/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534250(364801/98/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534251(364801/98/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534252(364801/98/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534253(364801/98/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534254(364801/98/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534255(364801/98/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534256(364801/98/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534257(364801/98/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534258(364801/98/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534259(364801/98/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534260(364801/98/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534261(364801/98/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534262(364801/98/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534263(364801/98/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534264(364801/98/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534265(364801/98/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534266(364801/98/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534267(364801/98/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534268(364801/98/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534269(364801/98/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534270(364801/98/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534271(364801/98/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534272(364801/98/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534273(364801/98/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534274(364801/98/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534275(364801/98/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534276(364801/98/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534277(364801/98/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534278(364801/98/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534279(364801/98/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534280(364801/98/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534281(364801/98/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534282(364801/98/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534283(364801/98/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534284(364801/98/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534285(364801/98/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534286(364801/98/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534287(364801/98/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534288(364801/98/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534289(364801/98/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534290(364801/98/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534291(364801/98/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534292(364801/98/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534293(364801/98/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534294(364801/98/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534295(364801/98/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534296(364801/98/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534297(364801/98/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534298(364801/98/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534299(364801/98/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534300(364801/98/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534301(364801/98/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534302(364801/99/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534303(364801/99/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534304(364801/99/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534305(364801/99/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534306(364801/99/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534307(364801/99/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534308(364801/99/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534309(364801/99/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534310(364801/99/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534311(364801/99/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534312(364801/99/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534313(364801/99/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534314(364801/99/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534315(364801/99/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534316(364801/99/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534317(364801/99/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534318(364801/99/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534319(364801/99/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534320(364801/99/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534321(364801/99/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534322(364801/99/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534323(364801/99/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534324(364801/99/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534325(364801/99/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534326(364801/99/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534327(364801/99/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534328(364801/99/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534329(364801/99/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534330(364801/99/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534331(364801/99/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534332(364801/99/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534333(364801/99/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534334(364801/99/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534335(364801/99/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534336(364801/99/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534337(364801/99/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534338(364801/99/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534339(364801/99/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534340(364801/99/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534341(364801/99/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534342(364801/99/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534343(364801/99/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534344(364801/99/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534345(364801/99/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534346(364801/99/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534347(364801/99/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534348(364801/99/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534349(364801/99/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534350(364801/99/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534351(364801/99/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534352(364801/99/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534353(364801/99/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534354(364801/99/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534355(364801/99/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534356(364801/99/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534357(364801/99/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534358(364801/99/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534359(364801/99/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534360(364801/99/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534361(364801/99/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534362(364801/99/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534363(364801/99/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534364(364801/99/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534365(364801/100/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534366(364801/100/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534367(364801/100/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534368(364801/100/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534369(364801/100/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534370(364801/100/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534371(364801/100/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534372(364801/100/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534373(364801/100/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534374(364801/100/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534375(364801/100/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534376(364801/100/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534377(364801/100/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534378(364801/100/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534379(364801/100/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534380(364801/100/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534381(364801/100/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534382(364801/100/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534383(364801/100/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534384(364801/100/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534385(364801/100/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534386(364801/100/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534387(364801/100/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534388(364801/100/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534389(364801/100/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534390(364801/100/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534391(364801/100/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534392(364801/100/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534393(364801/100/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534394(364801/100/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534395(364801/100/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534396(364801/100/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534397(364801/100/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534398(364801/100/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534399(364801/100/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534400(364801/100/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534401(364801/100/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534402(364801/100/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534403(364801/100/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534404(364801/100/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534405(364801/100/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534406(364801/100/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534407(364801/100/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534408(364801/100/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534409(364801/100/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534410(364801/100/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534411(364801/100/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534412(364801/100/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534413(364801/100/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534414(364801/100/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534415(364801/100/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534416(364801/100/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534417(364801/100/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534418(364801/100/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534419(364801/100/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534420(364801/100/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534421(364801/100/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534422(364801/100/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534423(364801/100/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534424(364801/100/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534425(364801/100/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534426(364801/100/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534427(364801/100/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534428(364801/101/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534429(364801/101/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534430(364801/101/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534431(364801/101/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534432(364801/101/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534433(364801/101/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534434(364801/101/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534435(364801/101/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534436(364801/101/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534437(364801/101/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534438(364801/101/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534439(364801/101/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534440(364801/101/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534441(364801/101/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534442(364801/101/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534443(364801/101/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534444(364801/101/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534445(364801/101/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534446(364801/101/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534447(364801/101/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534448(364801/101/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534449(364801/101/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534450(364801/101/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534451(364801/101/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534452(364801/101/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534453(364801/101/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534454(364801/101/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534455(364801/101/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534456(364801/101/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534457(364801/101/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534458(364801/101/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534459(364801/101/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534460(364801/101/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534461(364801/101/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534462(364801/101/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534463(364801/101/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534464(364801/101/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534465(364801/101/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534466(364801/101/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534467(364801/101/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534468(364801/101/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534469(364801/101/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534470(364801/101/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534471(364801/101/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534472(364801/101/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534473(364801/101/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534474(364801/101/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534475(364801/101/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534476(364801/101/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534477(364801/101/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534478(364801/101/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534479(364801/101/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534480(364801/101/53)) lseek err Invalid argument
grumbleskin
#3 Post by grumbleskin »
continued again:
file_pread(8,1,buffer,5860534481(364801/101/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534482(364801/101/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534483(364801/101/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534484(364801/101/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534485(364801/101/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534486(364801/101/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534487(364801/101/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534488(364801/101/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534489(364801/101/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534490(364801/101/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534491(364801/102/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534492(364801/102/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534493(364801/102/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534494(364801/102/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534495(364801/102/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534496(364801/102/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534497(364801/102/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534498(364801/102/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534499(364801/102/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534500(364801/102/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534501(364801/102/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534502(364801/102/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534503(364801/102/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534504(364801/102/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534505(364801/102/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534506(364801/102/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534507(364801/102/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534508(364801/102/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534509(364801/102/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534510(364801/102/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534511(364801/102/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534512(364801/102/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534513(364801/102/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534514(364801/102/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534515(364801/102/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534516(364801/102/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534517(364801/102/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534518(364801/102/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534519(364801/102/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534520(364801/102/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534521(364801/102/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534522(364801/102/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534523(364801/102/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534524(364801/102/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534525(364801/102/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534526(364801/102/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534527(364801/102/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534528(364801/102/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534529(364801/102/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534530(364801/102/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534531(364801/102/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534532(364801/102/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534533(364801/102/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534534(364801/102/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534535(364801/102/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534536(364801/102/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534537(364801/102/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534538(364801/102/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534539(364801/102/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534540(364801/102/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534541(364801/102/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534542(364801/102/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534543(364801/102/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534544(364801/102/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534545(364801/102/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534546(364801/102/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534547(364801/102/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534548(364801/102/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534549(364801/102/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534550(364801/102/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534551(364801/102/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534552(364801/102/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534553(364801/102/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534554(364801/103/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534555(364801/103/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534556(364801/103/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534557(364801/103/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534558(364801/103/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534559(364801/103/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534560(364801/103/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534561(364801/103/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534562(364801/103/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534563(364801/103/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534564(364801/103/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534565(364801/103/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534566(364801/103/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534567(364801/103/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534568(364801/103/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534569(364801/103/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534570(364801/103/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534571(364801/103/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534572(364801/103/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534573(364801/103/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534574(364801/103/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534575(364801/103/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534576(364801/103/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534577(364801/103/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534578(364801/103/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534579(364801/103/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534580(364801/103/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534581(364801/103/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534582(364801/103/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534583(364801/103/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534584(364801/103/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534585(364801/103/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534586(364801/103/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534587(364801/103/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534588(364801/103/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534589(364801/103/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534590(364801/103/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534591(364801/103/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534592(364801/103/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534593(364801/103/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534594(364801/103/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534595(364801/103/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534596(364801/103/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534597(364801/103/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534598(364801/103/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534599(364801/103/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534600(364801/103/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534601(364801/103/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534602(364801/103/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534603(364801/103/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534604(364801/103/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534605(364801/103/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534606(364801/103/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534607(364801/103/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534608(364801/103/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534609(364801/103/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534610(364801/103/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534611(364801/103/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534612(364801/103/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534613(364801/103/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534614(364801/103/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534615(364801/103/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534616(364801/103/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534617(364801/104/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534618(364801/104/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534619(364801/104/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534620(364801/104/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534621(364801/104/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534622(364801/104/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534623(364801/104/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534624(364801/104/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534625(364801/104/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534626(364801/104/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534627(364801/104/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534628(364801/104/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534629(364801/104/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534630(364801/104/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534631(364801/104/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534632(364801/104/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534633(364801/104/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534634(364801/104/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534635(364801/104/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534636(364801/104/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534637(364801/104/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534638(364801/104/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534639(364801/104/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534640(364801/104/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534641(364801/104/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534642(364801/104/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534643(364801/104/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534644(364801/104/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534645(364801/104/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534646(364801/104/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534647(364801/104/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534648(364801/104/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534649(364801/104/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534650(364801/104/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534651(364801/104/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534652(364801/104/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534653(364801/104/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534654(364801/104/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534655(364801/104/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534656(364801/104/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534657(364801/104/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534658(364801/104/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534659(364801/104/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534660(364801/104/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534661(364801/104/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534662(364801/104/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534663(364801/104/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534664(364801/104/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534665(364801/104/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534666(364801/104/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534667(364801/104/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534668(364801/104/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534669(364801/104/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534670(364801/104/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534671(364801/104/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534672(364801/104/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534673(364801/104/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534674(364801/104/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534675(364801/104/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534676(364801/104/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534677(364801/104/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534678(364801/104/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534679(364801/104/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534680(364801/105/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534681(364801/105/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534682(364801/105/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534683(364801/105/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534684(364801/105/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534685(364801/105/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534686(364801/105/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534687(364801/105/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534688(364801/105/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534689(364801/105/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534690(364801/105/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534691(364801/105/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534692(364801/105/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534693(364801/105/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534694(364801/105/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534695(364801/105/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534696(364801/105/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534697(364801/105/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534698(364801/105/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534699(364801/105/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534700(364801/105/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534701(364801/105/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534702(364801/105/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534703(364801/105/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534704(364801/105/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534705(364801/105/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534706(364801/105/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534707(364801/105/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534708(364801/105/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534709(364801/105/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534710(364801/105/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534711(364801/105/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534712(364801/105/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534713(364801/105/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534714(364801/105/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534715(364801/105/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534716(364801/105/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534717(364801/105/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534718(364801/105/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534719(364801/105/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534720(364801/105/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534721(364801/105/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534722(364801/105/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534723(364801/105/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534724(364801/105/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534725(364801/105/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534726(364801/105/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534727(364801/105/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534728(364801/105/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534729(364801/105/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534730(364801/105/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534731(364801/105/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534732(364801/105/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534733(364801/105/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534734(364801/105/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534735(364801/105/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534736(364801/105/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534737(364801/105/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534738(364801/105/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534739(364801/105/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534740(364801/105/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534741(364801/105/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534742(364801/105/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534743(364801/106/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534744(364801/106/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534745(364801/106/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534746(364801/106/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534747(364801/106/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534748(364801/106/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534749(364801/106/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534750(364801/106/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534751(364801/106/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534752(364801/106/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534753(364801/106/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534754(364801/106/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534755(364801/106/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534756(364801/106/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534757(364801/106/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534758(364801/106/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534759(364801/106/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534760(364801/106/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534761(364801/106/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534762(364801/106/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534763(364801/106/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534764(364801/106/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534765(364801/106/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534766(364801/106/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534767(364801/106/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534768(364801/106/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534769(364801/106/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534770(364801/106/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534771(364801/106/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534772(364801/106/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534773(364801/106/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534774(364801/106/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534775(364801/106/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534776(364801/106/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534777(364801/106/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534778(364801/106/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534779(364801/106/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534780(364801/106/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534781(364801/106/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534782(364801/106/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534783(364801/106/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534784(364801/106/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534785(364801/106/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534786(364801/106/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534787(364801/106/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534788(364801/106/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534789(364801/106/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534790(364801/106/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534791(364801/106/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534792(364801/106/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534793(364801/106/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534794(364801/106/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534795(364801/106/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534796(364801/106/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534797(364801/106/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534798(364801/106/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534799(364801/106/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534800(364801/106/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534801(364801/106/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534802(364801/106/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534803(364801/106/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534804(364801/106/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534805(364801/106/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534806(364801/107/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534807(364801/107/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534808(364801/107/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534809(364801/107/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534810(364801/107/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534811(364801/107/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534812(364801/107/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534813(364801/107/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534814(364801/107/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534815(364801/107/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534816(364801/107/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534817(364801/107/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534818(364801/107/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534819(364801/107/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534820(364801/107/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534821(364801/107/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534822(364801/107/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534823(364801/107/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534824(364801/107/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534825(364801/107/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534826(364801/107/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534827(364801/107/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534828(364801/107/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534829(364801/107/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534830(364801/107/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534831(364801/107/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534832(364801/107/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534833(364801/107/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534834(364801/107/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534835(364801/107/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534836(364801/107/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534837(364801/107/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534838(364801/107/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534839(364801/107/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534840(364801/107/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534841(364801/107/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534842(364801/107/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534843(364801/107/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534844(364801/107/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534845(364801/107/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534846(364801/107/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534847(364801/107/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534848(364801/107/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534849(364801/107/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534850(364801/107/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534851(364801/107/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534852(364801/107/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534853(364801/107/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534854(364801/107/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534855(364801/107/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534856(364801/107/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534857(364801/107/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534858(364801/107/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534859(364801/107/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534860(364801/107/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534861(364801/107/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534862(364801/107/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534863(364801/107/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534864(364801/107/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534865(364801/107/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534866(364801/107/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534867(364801/107/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534868(364801/107/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534869(364801/108/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534870(364801/108/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534871(364801/108/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534872(364801/108/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534873(364801/108/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534874(364801/108/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534875(364801/108/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534876(364801/108/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534877(364801/108/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534878(364801/108/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534879(364801/108/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534880(364801/108/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534881(364801/108/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534882(364801/108/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534883(364801/108/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534884(364801/108/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534885(364801/108/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534886(364801/108/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534887(364801/108/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534888(364801/108/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534889(364801/108/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534890(364801/108/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534891(364801/108/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534892(364801/108/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534893(364801/108/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534894(364801/108/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534895(364801/108/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534896(364801/108/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534897(364801/108/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534898(364801/108/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534899(364801/108/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534900(364801/108/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534901(364801/108/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534902(364801/108/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534903(364801/108/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534904(364801/108/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534905(364801/108/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534906(364801/108/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534907(364801/108/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534908(364801/108/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534909(364801/108/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534910(364801/108/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534911(364801/108/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534912(364801/108/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534913(364801/108/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534914(364801/108/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534915(364801/108/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534916(364801/108/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534917(364801/108/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534918(364801/108/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534919(364801/108/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534920(364801/108/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534921(364801/108/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534922(364801/108/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534923(364801/108/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534924(364801/108/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534925(364801/108/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534926(364801/108/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534927(364801/108/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534928(364801/108/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534929(364801/108/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534930(364801/108/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534931(364801/108/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534932(364801/109/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534933(364801/109/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534934(364801/109/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534935(364801/109/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534936(364801/109/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860534937(364801/109/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860534938(364801/109/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860534939(364801/109/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860534940(364801/109/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860534941(364801/109/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860534942(364801/109/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860534943(364801/109/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860534944(364801/109/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860534945(364801/109/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860534946(364801/109/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860534947(364801/109/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860534948(364801/109/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860534949(364801/109/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860534950(364801/109/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860534951(364801/109/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860534952(364801/109/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860534953(364801/109/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860534954(364801/109/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860534955(364801/109/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860534956(364801/109/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860534957(364801/109/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860534958(364801/109/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860534959(364801/109/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860534960(364801/109/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860534961(364801/109/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860534962(364801/109/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860534963(364801/109/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860534964(364801/109/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860534965(364801/109/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860534966(364801/109/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860534967(364801/109/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860534968(364801/109/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860534969(364801/109/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860534970(364801/109/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860534971(364801/109/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860534972(364801/109/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860534973(364801/109/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860534974(364801/109/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860534975(364801/109/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860534976(364801/109/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860534977(364801/109/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860534978(364801/109/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860534979(364801/109/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860534980(364801/109/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860534981(364801/109/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860534982(364801/109/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860534983(364801/109/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860534984(364801/109/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860534985(364801/109/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860534986(364801/109/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860534987(364801/109/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860534988(364801/109/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860534989(364801/109/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860534990(364801/109/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860534991(364801/109/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860534992(364801/109/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860534993(364801/109/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860534994(364801/109/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860534995(364801/110/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860534996(364801/110/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860534997(364801/110/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860534998(364801/110/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860534999(364801/110/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860535000(364801/110/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860535001(364801/110/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860535002(364801/110/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860535003(364801/110/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860535004(364801/110/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860535005(364801/110/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535006(364801/110/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860535007(364801/110/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860535008(364801/110/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860535009(364801/110/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860535010(364801/110/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860535011(364801/110/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860535012(364801/110/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860535013(364801/110/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860535014(364801/110/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860535015(364801/110/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860535016(364801/110/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860535017(364801/110/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860535018(364801/110/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860535019(364801/110/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860535020(364801/110/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860535021(364801/110/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860535022(364801/110/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860535023(364801/110/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860535024(364801/110/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860535025(364801/110/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860535026(364801/110/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860535027(364801/110/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860535028(364801/110/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860535029(364801/110/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860535030(364801/110/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860535031(364801/110/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860535032(364801/110/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860535033(364801/110/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860535034(364801/110/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860535035(364801/110/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860535036(364801/110/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860535037(364801/110/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860535038(364801/110/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860535039(364801/110/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860535040(364801/110/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860535041(364801/110/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860535042(364801/110/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860535043(364801/110/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860535044(364801/110/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860535045(364801/110/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860535046(364801/110/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860535047(364801/110/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860535048(364801/110/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860535049(364801/110/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860535050(364801/110/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860535051(364801/110/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860535052(364801/110/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860535053(364801/110/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860535054(364801/110/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860535055(364801/110/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860535056(364801/110/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860535057(364801/110/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860535058(364801/111/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860535059(364801/111/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860535060(364801/111/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860535061(364801/111/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860535062(364801/111/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860535063(364801/111/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860535064(364801/111/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860535065(364801/111/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860535066(364801/111/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860535067(364801/111/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860535068(364801/111/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535069(364801/111/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860535070(364801/111/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860535071(364801/111/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860535072(364801/111/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860535073(364801/111/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860535074(364801/111/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860535075(364801/111/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860535076(364801/111/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860535077(364801/111/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860535078(364801/111/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860535079(364801/111/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860535080(364801/111/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533168(364801/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(8,1,buffer,5860535081(364801/111/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860535082(364801/111/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860533170(364801/81/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860535083(364801/111/26)) lseek err Invalid argument
file_pread(8,11,buffer,5860533161(364801/80/57)) ReadFile The drive cannot find the sector requested.
file_pread(8,1,buffer,5860535084(364801/111/27)) lseek err Invalid argument
file_pread(8,4,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860535085(364801/111/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533173(364801/81/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860535086(364801/111/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860533174(364801/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860535087(364801/111/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860533175(364801/81/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860535088(364801/111/31)) lseek err Invalid argument
file_pread(8,11,buffer,5860533166(364801/80/62)) ReadFile The drive cannot find the sector requested.
file_pread(8,1,buffer,5860535089(364801/111/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533177(364801/81/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860535090(364801/111/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533178(364801/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535091(364801/111/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533179(364801/81/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860535092(364801/111/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533180(364801/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860535093(364801/111/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533181(364801/81/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860535094(364801/111/37)) lseek err Invalid argument
file_pread(8,11,buffer,5860533172(364801/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860535095(364801/111/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533183(364801/81/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860535096(364801/111/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860533184(364801/81/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860535097(364801/111/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533185(364801/81/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860535098(364801/111/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533186(364801/81/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860535099(364801/111/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533187(364801/81/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860535100(364801/111/43)) lseek err Invalid argument
file_pread(8,11,buffer,5860533178(364801/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535101(364801/111/44)) lseek err Invalid argument
file_pread(8,11,buffer,5860533179(364801/81/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860535102(364801/111/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533190(364801/81/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860535103(364801/111/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533191(364801/81/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860535104(364801/111/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533192(364801/81/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860535105(364801/111/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533193(364801/81/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860535106(364801/111/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533194(364801/81/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860535107(364801/111/50)) lseek err Invalid argument
file_pread(8,11,buffer,5860533185(364801/81/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860535108(364801/111/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533196(364801/81/29)) lseek err Invalid argument
file_pread(8,1,buffer,5860535109(364801/111/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533197(364801/81/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860535110(364801/111/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533198(364801/81/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860535111(364801/111/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533199(364801/81/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860535112(364801/111/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860533200(364801/81/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860535113(364801/111/56)) lseek err Invalid argument
file_pread(8,11,buffer,5860533191(364801/81/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860535114(364801/111/57)) lseek err Invalid argument
file_pread(8,11,buffer,5860533192(364801/81/25)) lseek err Invalid argument
file_pread(8,1,buffer,5860535115(364801/111/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533203(364801/81/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860535116(364801/111/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860533204(364801/81/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860535117(364801/111/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533205(364801/81/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860535118(364801/111/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533206(364801/81/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860535119(364801/111/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533207(364801/81/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860535120(364801/111/63)) lseek err Invalid argument
file_pread(8,11,buffer,5860533198(364801/81/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860535121(364801/112/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533209(364801/81/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860535122(364801/112/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533210(364801/81/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860535123(364801/112/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533211(364801/81/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860535124(364801/112/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533212(364801/81/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860535125(364801/112/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533213(364801/81/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860535126(364801/112/6)) lseek err Invalid argument
file_pread(8,11,buffer,5860533204(364801/81/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860535127(364801/112/7)) lseek err Invalid argument
file_pread(8,11,buffer,5860533205(364801/81/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860535128(364801/112/8)) lseek err Invalid argument
file_pread(8,11,buffer,5860533206(364801/81/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860535129(364801/112/9)) lseek err Invalid argument
file_pread(8,11,buffer,5860533207(364801/81/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860535130(364801/112/10)) lseek err Invalid argument
file_pread(8,8,buffer,5860533161(364801/80/57)) ReadFile The drive cannot find the sector requested.
file_pread(8,11,buffer,5860533208(364801/81/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860535131(364801/112/11)) lseek err Invalid argument
file_pread(8,3,buffer,5860533167(364801/80/63)) ReadFile The drive cannot find the sector requested.
file_pread(8,1,buffer,5860533219(364801/81/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860535132(364801/112/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533220(364801/81/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860535133(364801/112/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533171(364801/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533221(364801/81/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860535134(364801/112/14)) lseek err Invalid argument
file_pread(8,8,buffer,5860533165(364801/80/61)) ReadFile The drive cannot find the sector requested.
file_pread(8,1,buffer,5860533222(364801/81/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860535135(364801/112/15)) lseek err Invalid argument
file_pread(8,11,buffer,5860533213(364801/81/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860535136(364801/112/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860533224(364801/81/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860535137(364801/112/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533225(364801/81/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860535138(364801/112/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533176(364801/81/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533226(364801/81/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860535139(364801/112/19)) lseek err Invalid argument
file_pread(8,8,buffer,5860533170(364801/81/3)) lseek err Invalid argument
file_pread(8,11,buffer,5860533217(364801/81/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860535140(364801/112/20)) lseek err Invalid argument
file_pread(8,8,buffer,5860533171(364801/81/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860533228(364801/81/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860535141(364801/112/21)) lseek err Invalid argument
file_pread(8,8,buffer,5860533172(364801/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533172(364801/81/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533229(364801/81/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860535142(364801/112/22)) lseek err Invalid argument
file_pread(8,8,buffer,5860533173(364801/81/6)) lseek err Invalid argument
file_pread(8,11,buffer,5860533220(364801/81/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860535143(364801/112/23)) lseek err Invalid argument
file_pread(8,8,buffer,5860533174(364801/81/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860533231(364801/82/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860535144(364801/112/24)) lseek err Invalid argument
file_pread(8,8,buffer,5860533175(364801/81/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533232(364801/82/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860535145(364801/112/25)) lseek err Invalid argument
file_pread(8,8,buffer,5860533176(364801/81/9)) lseek err Invalid argument
file_pread(8,11,buffer,5860533223(364801/81/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860535146(364801/112/26)) lseek err Invalid argument
file_pread(8,8,buffer,5860533177(364801/81/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860533234(364801/82/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860535147(364801/112/27)) lseek err Invalid argument
file_pread(8,8,buffer,5860533178(364801/81/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533235(364801/82/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860535148(364801/112/28)) lseek err Invalid argument
file_pread(8,8,buffer,5860533179(364801/81/12)) lseek err Invalid argument
file_pread(8,11,buffer,5860533226(364801/81/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860535149(364801/112/29)) lseek err Invalid argument
file_pread(8,8,buffer,5860533180(364801/81/13)) lseek err Invalid argument
file_pread(8,1,buffer,5860533237(364801/82/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860535150(364801/112/30)) lseek err Invalid argument
file_pread(8,8,buffer,5860533181(364801/81/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533238(364801/82/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860535151(364801/112/31)) lseek err Invalid argument
grumbleskin
Re: Have 3TB drive go RAW
#4 Post by grumbleskin »
one more time:
file_pread(8,8,buffer,5860533182(364801/81/15)) lseek err Invalid argument
file_pread(8,11,buffer,5860533229(364801/81/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860535152(364801/112/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860533240(364801/82/10)) lseek err Invalid argument
file_pread(8,1,buffer,5860535153(364801/112/33)) lseek err Invalid argument
file_pread(8,1,buffer,5860533241(364801/82/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535154(364801/112/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533242(364801/82/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860535155(364801/112/35)) lseek err Invalid argument
file_pread(8,8,buffer,5860533186(364801/81/19)) lseek err Invalid argument
file_pread(8,11,buffer,5860533233(364801/82/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860535156(364801/112/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860533244(364801/82/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860535157(364801/112/37)) lseek err Invalid argument
file_pread(8,1,buffer,5860533195(364801/81/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860533245(364801/82/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860535158(364801/112/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860533246(364801/82/16)) lseek err Invalid argument
file_pread(8,1,buffer,5860535159(364801/112/39)) lseek err Invalid argument
file_pread(8,8,buffer,5860533190(364801/81/23)) lseek err Invalid argument
file_pread(8,11,buffer,5860533237(364801/82/7)) lseek err Invalid argument
file_pread(8,1,buffer,5860535160(364801/112/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860533248(364801/82/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860535161(364801/112/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533249(364801/82/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860535162(364801/112/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860533250(364801/82/20)) lseek err Invalid argument
file_pread(8,1,buffer,5860535163(364801/112/43)) lseek err Invalid argument
file_pread(8,8,buffer,5860533194(364801/81/27)) lseek err Invalid argument
file_pread(8,11,buffer,5860533241(364801/82/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535164(364801/112/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860533202(364801/81/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860533252(364801/82/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860535165(364801/112/45)) lseek err Invalid argument
file_pread(8,1,buffer,5860533182(364801/81/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533253(364801/82/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860535166(364801/112/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860533254(364801/82/24)) lseek err Invalid argument
file_pread(8,1,buffer,5860535167(364801/112/47)) lseek err Invalid argument
file_pread(8,8,buffer,5860533198(364801/81/31)) lseek err Invalid argument
file_pread(8,11,buffer,5860533245(364801/82/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860535168(364801/112/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533256(364801/82/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860535169(364801/112/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533257(364801/82/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860535170(364801/112/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533208(364801/81/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860533258(364801/82/28)) lseek err Invalid argument
file_pread(8,1,buffer,5860535171(364801/112/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533188(364801/81/21)) lseek err Invalid argument
file_pread(8,8,buffer,5860533202(364801/81/35)) lseek err Invalid argument
file_pread(8,11,buffer,5860533249(364801/82/19)) lseek err Invalid argument
file_pread(8,1,buffer,5860535172(364801/112/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860533189(364801/81/22)) lseek err Invalid argument
file_pread(8,1,buffer,5860533260(364801/82/30)) lseek err Invalid argument
file_pread(8,1,buffer,5860535173(364801/112/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860533261(364801/82/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860535174(364801/112/54)) lseek err Invalid argument
file_pread(8,1,buffer,5860533262(364801/82/32)) lseek err Invalid argument
file_pread(8,1,buffer,5860535175(364801/112/55)) lseek err Invalid argument
file_pread(8,8,buffer,5860533206(364801/81/39)) lseek err Invalid argument
file_pread(8,11,buffer,5860533253(364801/82/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860535176(364801/112/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533214(364801/81/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860533264(364801/82/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860535177(364801/112/57)) lseek err Invalid argument
file_pread(8,1,buffer,5860533215(364801/81/48)) lseek err Invalid argument
file_pread(8,1,buffer,5860533265(364801/82/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860535178(364801/112/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860533216(364801/81/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860533266(364801/82/36)) lseek err Invalid argument
file_pread(8,1,buffer,5860535179(364801/112/59)) lseek err Invalid argument
file_pread(8,8,buffer,5860533210(364801/81/43)) lseek err Invalid argument
file_pread(8,11,buffer,5860533257(364801/82/27)) lseek err Invalid argument
file_pread(8,1,buffer,5860535180(364801/112/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533218(364801/81/51)) lseek err Invalid argument
file_pread(8,1,buffer,5860533268(364801/82/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860535181(364801/112/61)) lseek err Invalid argument
file_pread(8,1,buffer,5860533269(364801/82/39)) lseek err Invalid argument
file_pread(8,1,buffer,5860535182(364801/112/62)) lseek err Invalid argument
file_pread(8,1,buffer,5860533270(364801/82/40)) lseek err Invalid argument
file_pread(8,1,buffer,5860535183(364801/112/63)) lseek err Invalid argument
file_pread(8,8,buffer,5860533214(364801/81/47)) lseek err Invalid argument
file_pread(8,11,buffer,5860533261(364801/82/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860535184(364801/113/1)) lseek err Invalid argument
file_pread(8,1,buffer,5860533201(364801/81/34)) lseek err Invalid argument
file_pread(8,1,buffer,5860533272(364801/82/42)) lseek err Invalid argument
file_pread(8,1,buffer,5860535185(364801/113/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533223(364801/81/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860533273(364801/82/43)) lseek err Invalid argument
file_pread(8,1,buffer,5860535186(364801/113/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533274(364801/82/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860535187(364801/113/4)) lseek err Invalid argument
file_pread(8,8,buffer,5860533218(364801/81/51)) lseek err Invalid argument
file_pread(8,11,buffer,5860533265(364801/82/35)) lseek err Invalid argument
file_pread(8,1,buffer,5860535188(364801/113/5)) lseek err Invalid argument
file_pread(8,1,buffer,5860533276(364801/82/46)) lseek err Invalid argument
file_pread(8,1,buffer,5860535189(364801/113/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533227(364801/81/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860533277(364801/82/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860535190(364801/113/7)) lseek err Invalid argument
file_pread(8,8,buffer,5860533221(364801/81/54)) lseek err Invalid argument
file_pread(8,11,buffer,5860533268(364801/82/38)) lseek err Invalid argument
file_pread(8,1,buffer,5860535191(364801/113/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860533279(364801/82/49)) lseek err Invalid argument
file_pread(8,1,buffer,5860535192(364801/113/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533230(364801/81/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860533280(364801/82/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860535193(364801/113/10)) lseek err Invalid argument
file_pread(8,8,buffer,5860533224(364801/81/57)) lseek err Invalid argument
file_pread(8,11,buffer,5860533271(364801/82/41)) lseek err Invalid argument
file_pread(8,1,buffer,5860535194(364801/113/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860533282(364801/82/52)) lseek err Invalid argument
file_pread(8,1,buffer,5860535195(364801/113/12)) lseek err Invalid argument
file_pread(8,1,buffer,5860533233(364801/82/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533283(364801/82/53)) lseek err Invalid argument
file_pread(8,1,buffer,5860535196(364801/113/13)) lseek err Invalid argument
file_pread(8,8,buffer,5860533227(364801/81/60)) lseek err Invalid argument
file_pread(8,11,buffer,5860533274(364801/82/44)) lseek err Invalid argument
file_pread(8,1,buffer,5860535197(364801/113/14)) lseek err Invalid argument
file_pread(8,1,buffer,5860533285(364801/82/55)) lseek err Invalid argument
file_pread(8,1,buffer,5860535198(364801/113/15)) lseek err Invalid argument
file_pread(8,1,buffer,5860533236(364801/82/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860533286(364801/82/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860535199(364801/113/16)) lseek err Invalid argument
file_pread(8,8,buffer,5860533230(364801/81/63)) lseek err Invalid argument
file_pread(8,11,buffer,5860533277(364801/82/47)) lseek err Invalid argument
file_pread(8,1,buffer,5860535200(364801/113/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533217(364801/81/50)) lseek err Invalid argument
file_pread(8,1,buffer,5860533288(364801/82/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860535201(364801/113/18)) lseek err Invalid argument
file_pread(8,1,buffer,5860533239(364801/82/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860533289(364801/82/59)) lseek err Invalid argument
file_pread(8,1,buffer,5860535202(364801/113/19)) lseek err Invalid argument
file_pread(8,14,buffer,5860533156(364801/80/52)) ReadFile The drive cannot find the sector requested.
file_pread(8,3,buffer,5860533170(364801/81/3)) lseek err Invalid argument
file_pread(8,3,buffer,5860533217(364801/81/50)) lseek err Invalid argument
file_pread(8,8,buffer,5860533233(364801/82/3)) lseek err Invalid argument
file_pread(8,11,buffer,5860533280(364801/82/50)) lseek err Invalid argument
file_pread(8,2,buffer,5860535202(364801/113/19)) lseek err Invalid argument
file_pread(8,14,buffer,5860533157(364801/80/53)) ReadFile The drive cannot find the sector requested.
file_pread(8,2,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,3,buffer,5860533171(364801/81/4)) lseek err Invalid argument
file_pread(8,3,buffer,5860533218(364801/81/51)) lseek err Invalid argument
file_pread(8,8,buffer,5860533234(364801/82/4)) lseek err Invalid argument
file_pread(8,11,buffer,5860533281(364801/82/51)) lseek err Invalid argument
file_pread(8,2,buffer,5860535203(364801/113/20)) lseek err Invalid argument
file_pread(8,14,buffer,5860533158(364801/80/54)) ReadFile The drive cannot find the sector requested.
file_pread(8,3,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,3,buffer,5860533172(364801/81/5)) lseek err Invalid argument
file_pread(8,3,buffer,5860533219(364801/81/52)) lseek err Invalid argument
file_pread(8,8,buffer,5860533235(364801/82/5)) lseek err Invalid argument
file_pread(8,11,buffer,5860533282(364801/82/52)) lseek err Invalid argument
file_pread(8,2,buffer,5860535204(364801/113/21)) lseek err Invalid argument
file_pread(8,14,buffer,5860533159(364801/80/55)) ReadFile The drive cannot find the sector requested.
file_pread(8,3,buffer,5860533173(364801/81/6)) lseek err Invalid argument
file_pread(8,3,buffer,5860533220(364801/81/53)) lseek err Invalid argument
file_pread(8,8,buffer,5860533236(364801/82/6)) lseek err Invalid argument
file_pread(8,11,buffer,5860533283(364801/82/53)) lseek err Invalid argument
file_pread(8,2,buffer,5860535205(364801/113/22)) lseek err Invalid argument
file_pread(8,14,buffer,5860533160(364801/80/56)) ReadFile The drive cannot find the sector requested.
file_pread(8,5,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,3,buffer,5860533174(364801/81/7)) lseek err Invalid argument
file_pread(8,3,buffer,5860533221(364801/81/54)) lseek err Invalid argument
file_pread(8,8,buffer,5860533237(364801/82/7)) lseek err Invalid argument
file_pread(8,11,buffer,5860533284(364801/82/54)) lseek err Invalid argument
file_pread(8,2,buffer,5860535206(364801/113/23)) lseek err Invalid argument
file_pread(8,1,buffer,5860533295(364801/83/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860535208(364801/113/25)) lseek err Invalid argument
file_pread(8,14,buffer,5860533162(364801/80/58)) ReadFile The drive cannot find the sector requested.
file_pread(8,7,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,3,buffer,5860533176(364801/81/9)) lseek err Invalid argument
file_pread(8,3,buffer,5860533223(364801/81/56)) lseek err Invalid argument
file_pread(8,8,buffer,5860533239(364801/82/9)) lseek err Invalid argument
file_pread(8,11,buffer,5860533286(364801/82/56)) lseek err Invalid argument
file_pread(8,1,buffer,5860535209(364801/113/26)) lseek err Invalid argument
file_pread(8,1,buffer,5860533247(364801/82/17)) lseek err Invalid argument
file_pread(8,1,buffer,5860533297(364801/83/4)) lseek err Invalid argument
file_pread(8,1,buffer,5860535210(364801/113/27)) lseek err Invalid argument
file_pread(8,14,buffer,5860533164(364801/80/60)) ReadFile The drive cannot find the sector requested.
file_pread(8,3,buffer,5860533178(364801/81/11)) lseek err Invalid argument
file_pread(8,3,buffer,5860533225(364801/81/58)) lseek err Invalid argument
file_pread(8,8,buffer,5860533241(364801/82/11)) lseek err Invalid argument
file_pread(8,11,buffer,5860533288(364801/82/58)) lseek err Invalid argument
file_pread(8,1,buffer,5860535211(364801/113/28)) lseek err Invalid argument
file_pread(8,10,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533299(364801/83/6)) lseek err Invalid argument
file_pread(8,1,buffer,5860535212(364801/113/29)) lseek err Invalid argument
file_pread(8,14,buffer,5860533166(364801/80/62)) ReadFile The drive cannot find the sector requested.
file_pread(8,3,buffer,5860533180(364801/81/13)) lseek err Invalid argument
file_pread(8,3,buffer,5860533227(364801/81/60)) lseek err Invalid argument
file_pread(8,8,buffer,5860533243(364801/82/13)) lseek err Invalid argument
file_pread(8,11,buffer,5860533290(364801/82/60)) lseek err Invalid argument
file_pread(8,1,buffer,5860535213(364801/113/30)) lseek err Invalid argument
file_pread(8,12,buffer,5860533169(364801/81/2)) lseek err Invalid argument
file_pread(8,1,buffer,5860533251(364801/82/21)) lseek err Invalid argument
file_pread(8,1,buffer,5860533301(364801/83/8)) lseek err Invalid argument
file_pread(8,1,buffer,5860535214(364801/113/31)) lseek err Invalid argument
file_pread(8,1,buffer,5860533302(364801/83/9)) lseek err Invalid argument
file_pread(8,1,buffer,5860535215(364801/113/32)) lseek err Invalid argument
file_pread(8,2,buffer,5860533181(364801/81/14)) lseek err Invalid argument
file_pread(8,8,buffer,5860533246(364801/82/16)) lseek err Invalid argument
file_pread(8,11,buffer,5860533293(364801/82/63)) lseek err Invalid argument
file_pread(8,1,buffer,5860535216(364801/113/33)) lseek err Invalid argument
file_pread(8,14,buffer,5860533170(364801/81/3)) lseek err Invalid argument
file_pread(8,1,buffer,5860533304(364801/83/11)) lseek err Invalid argument
file_pread(8,1,buffer,5860535217(364801/113/34)) lseek err Invalid argument
Disk /dev/sde - 3000 GB / 2794 GiB - CHS 364801 255 63
The harddisk (3000 GB / 2794 GiB) seems too small! (< 6001 GB / 5588 GiB)
MS Data 5860358143 11720714231 5860356089
MS Data 2048 5860358136 5860356089
MS Data 2055 5860358143 5860356089
NTFS found using backup sector, blocksize=4096, 3000 GB / 2794 GiB
$MFT has invalid magic.
ntfs_mft_load(): Failed.
grumbleskin
#5 Post by grumbleskin »
I have the following after searching for partitions.
D MS Data 2048 5860358136 5860356089
D MS Data 2055 5860358143 5860356089
D Mac HFS 1201308945 1203275023 1966079 [Q^O~]0pM-+M-|],M-C~AH˒8M-3]
D Mac HFS 1203275020 1205241098 1966079 [Q^O~]0pM-+M-|],M-C~AH˒8M-3]
D Mac HFS 4794373633 4796339711 1966079 [Q^O~]0pM-+M-|],M-C~AH˒8M-3]
D Mac HFS 4796339708 4798305786 1966079 [Q^O~]0pM-+M-|],M-C~AH˒8M-3]
I am not sure how I have Mac partitions. The drive was bought new and only ever used with Windows 10.
Could anyone help me with what my next step should be?
Thank you.
#6 Post by recuperation »
grumbleskin wrote: 18 Nov 2019, 02:32 Could anyone help me with what my next step should be?
Thank you.
Use the p-key to see if Testdisk shows the content that you expect inside for each partition.
If that fails, use Photorec.
There is documentation out there:
