Hello pdisk command with the hfs + partition to recover deleted disk information should not map again. It gives me this message " “the map is not big enough”" that I want to process. How do I find the volume size of my disk?
My Storage ;
https://www.bhphotovideo.com/c/product/ ... tudio.html
My Disk Properties
WD30EZRX HFS+ Formatted.
test disk analysis gave a result, but I could not understand anything.
https://ibb.co/hHM6K3x
this message : hfs+ blocksize=2048+backup, 4136kb/4040 kib
I changed the geometry of the disk with the test disk mediated but I don't know if I did it right. I changed it to 512 4096 and now I'm analyzing it again. What do you think is true blocksiz or volume you?
thankyou for support.
						HFS+ blocksize and volume size ?
