Is there a way to carve out a specific file type ? .SQL files which are uncorrupted
mindsc4pe
#1 Post by mindsc4pe »
Thank you for reading my post.
I have a Windows 10 laptop here with the partitions properly intact but someone deleted their SQL work before exiting the company.
I am trying to find the SQL files that were deleted. Photorec was able to find a few sql files which don't have any data in them. Is there a way to use TestDisk or PhotoRec or Scalpel to specifically find .SQL files with a deepscan ?
Would appreciate any help.
Re: Is there a way to carve out a specific file type ? .SQL files which are uncorrupted
If photoRec has failed, you can try TestDisk, Advanced, Undelete.
