Can't open filesystem
ozstar
#1 Post by ozstar »
On win 10 x64.
was using 2TB USB for data when video editing and suddenly got the message it can't be found.
Using TD 7.1
Saw the Partition in green
2000GB 1863 GB
CHS 243201 255 63
>* HPFS - NTFS 0 32 33 243201 45 44 3907024896
Chose Write.
Can't open filesystem Seems damaged.
Tried P for files but same.
What is suggested now please ?
Thanks
oz
ozstar
Re: Can't open filesystem
#2 Post by ozstar »
This is the log file.
Sat Nov 23 08:53:48 2019
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999626375168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000395698176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000397883392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=499529023488
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=314572800000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=338651250688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=314572800000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=423485243392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=576715751424
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ATA WDC WD10EZEX-00W, S/N:WD-WMC6Y0L4D168, FW:1A01
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ATA ST2000DM008-2FR1, S/N:WFL1JR1M, FW:0001
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Expansion Desk, S/N:NA4K0NY4, FW:0711
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Expansion Desk, S/N:NA4LFZBV, FW:070B
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM0 02-1BC142, S/N:ST500DM002 Z2AE2DAA
Disk /dev/sdf - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ATA WDC WD10EZEX-08W, S/N:WD-WCC6Y7DCVVEP, FW:1A01
Disk /dev/sdg - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - USB3.0 , S/N:00A12345AFD0, FW:8105
Disk /dev/sdg - 2000 GB / 1863 GiB - USB3.0
Analyse Disk /dev/sdg - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 243201 45 44 3907024896
NTFS at 0/32/33
filesystem size 3907024896
mftmirr_lcn 2
file_pread(10,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(10,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(10,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(10,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(10,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(10,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(10,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(10,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(10,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(10,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(10,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(10,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(10,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(10,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(10,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(10,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(10,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(10,6,buffer,3907031042(243201/110/48)) lseek err Invalid argument
file_pread(10,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(10,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(10,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(10,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(10,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(10,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 243201/45/44
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
Failed to open $MFT/$BITMAP: No such file or directory.
ntfs_mft_load(): Failed.
Failed to load $MFT: No such file or directory.
Failed to startup volume: No such file or directory.
Not an exFAT boot sector.
ozstar
#3 Post by ozstar »
Looking at that log, what should I do now?
Can I save the filesystem and data?
Any suggestions please?
ozstar
#4 Post by ozstar »
I'm still hoping for help here.
