Boot Sector And Backup Are Bad, Solutions?
Durian
#1 Post by Durian »
Hi everyone, I have tried to format my RAW SD Card but have not found any way that works, so I am looking for other ways.
1. I opened TestDisk and tried Analyse and also Deeper Search = Nothing found
2. Advanced > Boot > Rebuild BS > List = Files could be seen and recovered > Write > Y = This was shown (Refer to the picture)
TestDisk Result.png (52.55 KiB) Viewed 1993 times
So what do I do now to fix this so I can format it? Or is there a direct way to just format this thing
*CHKDSK DOES NOT WORK
*DISKPART DOES NOT WORK
*DISK MANAGEMENT DOES NOT WORK
*Default Windows 7 Format does not work
*SD Card Formatter does not work
*AOMEI Partition Assistant does not work
Re: Boot Sector And Backup Are Bad, Solutions?
If formating the card doesn't work, it means there is an hardware problem. You should use another card instead.
