I use an Asus Maximus VIII Hero motherboard. It has an Intel RAID 5 controller. When I upgraded the bios, it dropped two of my four disks, making them non-members. This made it unrecoverable. I deleted the RAID 5 array and recreated it using the same settings. I then went into windows and have used TestDisk to try and recover the partitions. The drives were about 3Tb each and there are four of them, making 9Tb for the RAID 5.
I originally had three partitions:
Storage1 (a primary partition about 3.5Tb)
Storage2 (a primary partition about 3.5Tb)
Secure (a primary partition protected with BitLocker - about 1.5Tb)
When I do the analysis, it runs for ages and picks up a few odd things. On the plus side, it gets Storage1 and Storage2 fine. However it recognises the Secure partition in the Analysis but when we get to the next screen where we can flag it primary or delete, that partition is not available to select as primary (or delete). That is weird. So we have found a partition but there is no way to add it to the set we are about to write.
Any guidance on how to recover all three partitions would be appreciated greatly! I am really stressed that I will lose my data!
The first two partitions should be restorable IMHO. It is the Secure (BitLocker) one that is difficult as it doesn't seem to allow it to be an entry written to the partition table.
Here is my log.
Sun Dec 1 12:02:54 2019
TestDisk 7.2-WIP, Data Recovery Utility, November 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=9001771204608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=9001771204608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=254707893760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=256256245760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=3000574672896
Disk /dev/sda - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - Samsung SSD 850 PRO 512GB, S/N:S2BENCAHB24983E, FW:EXM04B6Q
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - TOSHIBA HDWD130, S/N:68GU32DAS, FW:MX6OACF0
Disk /dev/sdc - 9001 GB / 8383 GiB - CHS 1094403 255 63, sector size=512 - Intel Raid 5 Volume, S/N:StewartRAID5, FW:1.0.
Disk /dev/sdc - 9001 GB / 8383 GiB - Intel Raid 5 Volume
Partition table type: EFI GPT
Analyse Disk /dev/sdc - 9001 GB / 8383 GiB - CHS 1094403 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=17581584383 (expected 17581584383)
hdr_lba_start=34
hdr_lba_end=17581584350
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Reserved 34 32767 32734 [Microsoft reserved partition]
4 P MS Data 14336032768 17581580287 3245547520 [Basic data partition]
2 P MS Data 32768 8192032767 8192000000 [Basic data partition] [Storage1]
3 P MS Data 8192032768 14336032767 6144000000 [Basic data partition] [Storage2]
NTFS at 2/10/9
filesystem size 8192000000
mftmirr_lcn 2
NTFS part_offset=16777216, part_size=4194304000000, sector_size=512
NTFS at 2/10/9
mftmirr_lcn 2
MS Data 32768 8192032767 8192000000 [Storage1]
NTFS, blocksize=4096, 4194 GB / 3906 GiB
NTFS at 509930/116/11
filesystem size 6144000000
mftmirr_lcn 2
MS Data 2048032769 8192032768 6144000000
NTFS found using backup sector, blocksize=4096, 3145 GB / 2929 GiB
mftmirr_lcn 2
MS Data 8192032768 14336032767 6144000000 [Storage2]
NTFS, blocksize=4096, 3145 GB / 2929 GiB
Unknown 14880918939 15822903279 941984341
FATX, 482 GB / 449 GiB
Partition not added.
cramfs Marker at 926722/211/28
recover_cramfs
Linux filesys. data 14887802250 14894026457 6224207 [@¶8OÝÅ÷ºž|
ÑNûJ]
cramfs, 3186 MB / 3039 MiB
LVM magic value at 969402/61/28
cramfs Marker at 980546/56/57
recover_cramfs
Linux filesys. data 15752475074 15760308773 7833699 [2ÖJýÖ™Å:N£ÙÎJä]
cramfs, 4010 MB / 3825 MiB
SYSV4 Marker at 989154/221/42
recover_sysv4
Unknown 15890772974 121190523859949 121174633086976 [bñ.•Iº]
SysV4, 62041 TB / 56426 TiB
SYSV4 Marker at 995820/141/5
recover_sysv4
Unknown 15997857187 1670544244130 1654546386944 [ž5Üa½]
SysV4, 847 TB / 770 TiB
file_pread(6,1,buffer,401715200(1094403/3/1)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,401715201(1094403/3/2)) lseek err Invalid argument
file_pread(6,1,buffer,401715202(1094403/3/3)) lseek err Invalid argument
file_pread(6,1,buffer,401715203(1094403/3/4)) lseek err Invalid argument
file_pread(6,1,buffer,401715204(1094403/3/5)) lseek err Invalid argument
file_pread(6,1,buffer,401715205(1094403/3/6)) lseek err Invalid argument
file_pread(6,1,buffer,401715206(1094403/3/7)) lseek err Invalid argument
file_pread(6,1,buffer,401717112(1094403/33/23)) lseek err Invalid argument
file_pread(6,11,buffer,401715190(1094403/2/54)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,401715286(1094403/4/24)) lseek err Invalid argument
file_pread(6,1,buffer,401715336(1094403/5/11)) lseek err Invalid argument
file_pread(6,1,buffer,401717249(1094403/35/34)) lseek err Invalid argument
P Linux filesys. data 14887802250 14894026457 6224208 [@¶8OÝÅ÷ºž|
ÑNûJ]
P Linux filesys. data 15752475074 15760308773 7833700 [2ÖJýÖ™Å:N£ÙÎJä]
$MFT has invalid magic.
ntfs_mft_load(): Failed.
1 P MS Data 32768 8192032767 8192000000 [Storage1]
2 P MS Data 8192032768 14336032767 6144000000 [Storage2]
3 P Linux filesys. data 14887802250 14894026457 6224208 [@¶8OÝÅ÷ºž|
ÑNûJ]
4 P Linux filesys. data 15752475074 15760308773 7833700 [2ÖJýÖ™Å:N£ÙÎJä]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 2/10/9
mftmirr_lcn 2
NTFS at 2/10/9
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
file_pread(6,2,buffer,401715199(1094403/2/63)) ReadFile The drive cannot find the sector requested.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 2/10/9
mftmirr_lcn 2
NTFS at 2/10/9
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 2/10/9
mftmirr_lcn 2
NTFS at 2/10/9
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 2/10/9
mftmirr_lcn 2
NTFS at 2/10/9
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
Bios Upgrade Killed My Raid
Re: Bios Upgrade Killed My Raid
The current partition table looks OK as it listed Storage1, Storage2 and another partition (probably your BitLocker).
Using Windows Disk Manager, you should assign a drive letter to each partition and try "chkdsk /f d:" (replace d: by the correct drive letter).
windsurfingstew
Thank you. In Disk Manager, it shows ONLY two partitions (both unallocated), one 2048GB and the other 6335.55 Gb. This doesn't seem right (as we need 3.5+3.5+1TB approx).
Any further thought would be appreciated. Thank you!
windsurfingstew
So, I'm back having reanalysed:
D MS Data 32768 8192032767 8192000000 [Storage1]
D MS Data 2048032769 8192032768 6144000000
D MS Data 8192032768 14336032767 6144000000 [Storage2]
M-J]nux filesys. data 14887802250 14894026457 6224208 [@M-68OM-EM-wM-:~^|
P Linux filesys. data 15752475074 15760308773 7833700 [2^SJM-}^G֙ NM-#M-NJ
Structure: Ok. Use Up/Down Arrow keys to select partition. Use Left/Right Arrow keys to CHANGE partition characteristics: P=Primary D=Deleted
Keys A: add partition, L: load backup, T: change type, P: list files, Enter: to continue
Should I delete all except the first and third, then write? Or should I try and add the Bitlocker partition manually (how)? Or try and persevere with what you suggested, even though the size of the partitions is all wrong?
windsurfingstew
Just a quick update. I got it working.
I found the two partitions Storage1 and Storage2 by searching. All other partitions I marked for deletion. I then used the 'A' Add to add in the partition for the Bitlocker drive manually. I copied the details from the 'Advanced' screen. I then wrote the partition table, and somewhat nervously rebooted. Everything worked perfectly. It even kept the correct drive letters!
Thank you for fantastic software. You have saved my life!
