Do these specs show a Rebuild is possible?
ozstar
#1 Post by ozstar »
The orig 1.81 TB drive went down and was not sable to get an answer in the forum of a suggestion to fix it.
I used a trial of Get Data Back and these are the two log files it produced after i created an multi file image to a new drive.
Does this show whether anything can be done with the drive to repair it?
Thanks
oz
File System Properties
CAPTURE 15/12/2019 8:20:55 PM
File system: NTFS
Cluster0: Sector 2,048
Cluster size: 8 sectors
Phys. sector size: 512 bytes
Total sectors: 3,907,024,895
Total clusters: 488,378,111
Data matches/rel:10/0
Source details:B@2048BB@3907026943
Source: B2
Recovery tree:Tree NTFS, 13043 entries
Total files: 12,605
Total directories: 435
Total file size: 1.49 TB
# dirhash entries: 13,043
MFT cluster: 786,432
MFTMirr cluster: 2
MFT size: 1024 bytes
INDX size: 4096 bytes
# Mft:0
Explicit Mft no:True
Area: Ambiguous
Recovery Details
CAPTURE 15/12/2019 8:19:20 PM
Recovery Details
Drive:Physical hard drive 1.82 TB (DISK3:)
# MFT:13,053
# $Mft:2
# $MftMirr:1
# Index:11
# NT boot sectors:2
# FAT32 boot sectors:0
# FAT16 boot sectors:0
# exFAT boot sectors:0
# HFS+ volume headers:0
# Unused HFS volume headers:0
# HFS node ends:364
# HFS header nodes:0
# APFS NXSBs:0
# APFS APSBs:0
# APFS Blocks:0
# EXT Superblocks:0
# XFS Superblocks:0
# 12-bit FATs:0
# 16-bit FATs:0
# 32-bit FATs:0
# EXFAT FATs:0
# Directory starts:0
# Directory conts:12
# exFAT Directory roots:0
# exFAT Directory starts:0
# exFAT Directory conts:0
Dir tracker list:0 entries
FAT analyse list:0 entries
FAT cache:0 entries
CrissCross:Level 3, 6,155,472 sectors in 39,016 chunks
CrossCrossMemo:L3/Br1000000/Dry1030/Thv100000
Sectors starts:111
Cluster starts:11,218
All clusters:11,197
Cl sizes:10,945
File system list:1 items
Selected file system:NTFS at sector 2,048, cluster size 8 (1.82 TB) more...
ID:1163561532 created 14/12/2019 9:51:42 AM
Re: Do these specs show a Rebuild is possible?
