Can't write
fatturi
Can't write
#1 Post by fatturi »
hi,
i'm not an expert, not mothertongue.
I have a problem, 2 warning about incorrect number of heads and sectors
I go to the "geometry" and I put the correct numbers, then I go to the "write" and confirm with Y. the program says to reboot the machine.
after that reboot, nothing happens, like I can't write the new numbers.
this is the log:
Tue Dec 17 13:36:38 2019
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=268419072
Disk /dev/sda - 1000 GB / 931 GiB - CHS 459004 224 19, sector size=512 - ST1000DM010-2EP102, S/N:2020202020202020202020204e5a373144543453, FW:CC43
Drive D: - 268 MB / 255 MiB - CHS 63 64 32, sector size=2048 - HL-DT-ST DVDRAM GH22NS40, FW:NL01
Disk /dev/sda - 1000 GB / 931 GiB - ST1000DM010-2EP102
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 459004 224 19
BAD_RS LBA=2048 640
NTFS at 0/107/16
heads/cylinder 255 (NTFS) != 224 (HD)
sect/track 63 (NTFS) != 19 (HD)
BAD_RS LBA=206848 55328
NTFS at 48/134/15
Warning: number of heads/cylinder mismatches 255 (NTFS) != 224 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 19 (HD)
1 * HPFS - NTFS 0 107 16 48 134 14 204800 [Riservato per il sistema]
2 P HPFS - NTFS 48 134 15 459004 33 13 1953314816
NTFS at 0/107/16
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
NTFS at 48/134/15
filesystem size 1953314816
mftmirr_lcn 2
file_pread(4,2,buffer,1953525759(459005/25/5)) lseek err Invalid argument
file_pread(4,1,buffer,1953525759(459005/25/5)) lseek err Invalid argument
file_pread(4,2,buffer,1953525760(459005/25/6)) lseek err Invalid argument
file_pread(4,8,buffer,1953525248(459004/222/7)) lseek err Invalid argument
file_pread(4,1,buffer,1953525248(459004/222/7)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 224 but the correct value may be 255.
New geometry
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121602 255 63 sector_size=512
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121602 255 63
NTFS at 0/32/33
NTFS at 12/223/20
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [Riservato per il sistema]
2 P HPFS - NTFS 12 223 20 121601 25 24 1953314816
NTFS at 0/32/33
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
mftmirr_lcn 2
file_pread(4,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(4,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(4,7,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(4,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(4,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(4,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(4,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(4,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(4,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
Re: Can't write
You can ignore the warnings, they are only warnings, not error messages.
Otherwise the partition table looks OK, two partitions are listed.
