Undelete .img from Synology NAS
TungstenE2
#1 Post by TungstenE2 »
Hi all,
I deleted several .img image files from my Synology by using rm from Linux on mounted Synology drive.
Each file is about 32GB.
According to this overview .img should be supported: https://www.cgsecurity.org/wiki/File_Fo ... y_PhotoRec
In the scan options I do not find img file type, so just to restore this file type.
How best just to restore img type files?
thx
Re: Undelete .img from Synology NAS
Is the deleted file still used by another process ?
Try TestDisk, Advanced, List. Try to locate the files. If the size is other than 0, copy it to another disk.
PhotoRec will not work for this kind of files, they are too large and usually fragmented.
TungstenE2
#3 Post by TungstenE2 »
thx, will give it a try. but how to select single file to be restored?
'TestDisk, Advanced, List.'
I only have option 'TestDisk, Advanced, ImageCreation' no List option.
Superblock and Undelete are missing from the options....
https://www.cgsecurity.org/wiki/TestDis ... e_for_ext2
thx
You should select the device /dev/md0 (or md1, md2). Linux Raid devices are only available under Linux.
