long story short! i keep encrypted .dmg of my boot disk. i thought i had saved the password, but apparently. ow.
if i can recover the keychain from unencrypted apfs volume, i hope my password is inside. i know my keychain password of course
the ssd has already been overwritten with debian and several gigabytes.
i am dd’ing the disk now... any advice? will testdisk help with apfs?
or is it up to photorec? will it find mac keychain files?
need to recover keychain from apfs
Re: need to recover keychain from apfs
TestDisk will probably not work as too much data has been overwritten.
I don't know which format is used by mac keychain.
You can try with a known keychain file using fidentify or online via https://www.cgsecurity.org/photorec/
thanks for getting back to me.
fidentify says 'login.keychain-db: unknown'. Is it necessary to upload a keychain file? I would prefer not to.
from a little cursory searching, it looks like an encrypted sqlite database. i can read some of the schema in a hex editor, such as "CSSM_DL_DB_SCHEMA_INFO".
one fact that might help, when reading with hex editor, the two files i tested both start with '6B 79 63 68' which is 'kych'
can i use this information with photorec somehow?
thanks
thanks
I've tried recovery with a couple of other tools and they both have the same behaviour. The login.keychain file is all 0000. I am wondering if this is a security element at play here?
