All fine but finally: Partition: Write error
lucanorillo
#1 Post by lucanorillo »
Hello and happy new year!!!
I have a 3Tb disk that in windows disk management says Partition protected GPT and I cannt acces it.
I use TestDisk, i make a deep scan, but when i want to write it says (see photos). Any help? Thanks in advance.
Log:
Thu Jan 2 22:11:07 2020
TestDisk 7.2-WIP, Data Recovery Utility, December 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=2000397852160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=2000397852160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249495540224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500104691712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000200994816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000395698176
filewin32_getfilesize(\\.\I:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Función incorrecta.
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00MMMB0, S/N:WD-WCAWZ2053745, FW:80.00A80
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO 250GB, S/N:S2R6NX0H717868P, FW:EMT02B6Q
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:9QM28RB2, FW:SD1A
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000528AS, S/N:9VP1CPVD, FW:CC46
Disk /dev/sde - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000528AS, S/N:5VP0GSKA, FW:CC46
Disk /dev/sdf - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST32000542AS, S/N:6XW1GC39, FW:CC34
Disk /dev/sda - 3000 GB / 2794 GiB - WDC WD30EZRX-00MMMB0
Analyse Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63
Bad sector count.
NTFS at 0/32/33
filesystem size 3907024896
mftmirr_lcn 2
HPFS - NTFS 0 32 33 243201 45 44 3907024896
file_pread(4,2,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(4,2,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(4,14,buffer,1565566978(364801/98/36)) lseek err Invalid argument
file_pread(4,3,buffer,1565566992(364801/98/50)) lseek err Invalid argument
file_pread(4,3,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(4,8,buffer,1565567055(364801/99/50)) lseek err Invalid argument
file_pread(4,11,buffer,1565567102(364801/100/34)) lseek err Invalid argument
file_pread(4,2,buffer,1565569024(364801/131/3)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 243201 45 44 3907024896
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
P HPFS - NTFS 0 32 33 243201 45 44 3907024896
L HPFS - NTFS 0 32 33 243201 45 44 3907024896
1 P HPFS - NTFS 0 32 33 243201 45 44 3907024896
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 16/113/34
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
filesystem size 732533504
sectors_per_cluster 1
mftmirr_lcn 2
HPFS - NTFS 16 113 34 364801 66 1 5860268032 [ARCHIVO_RAID1]
NTFS at 243201/45/44
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
file_pread(4,2,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(4,2,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(4,2,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(4,8,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(4,8,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(4,8,buffer,1565566464(364801/90/26)) lseek err Invalid argument
file_pread(4,8,buffer,1565566592(364801/92/28)) lseek err Invalid argument
file_pread(4,8,buffer,1565566720(364801/94/30)) lseek err Invalid argument
file_pread(4,8,buffer,1565566848(364801/96/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
NTFS Volume is dirty.
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
5 dr-xr-xr-x 0 0 0 24-Jul-2018 12:19 .
5 dr-xr-xr-x 0 0 0 24-Jul-2018 12:19 ..
interface_load
P HPFS - NTFS 16 113 34 364801 66 1 5860268032 [ARCHIVO_RAID1]
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 16 81 2 364801 66 1 5860270080
5 L HPFS - NTFS 16 113 34 364801 66 1 5860268032 [ARCHIVO_RAID1]
write!
file_pwrite(4,1,buffer,0(0/0/1)) write err Permission denied
write_all_log_i386: CHS: 16/81/2,lba=262144
file_pwrite(4,1,buffer,262144(16/81/2)) write err Permission denied
Re: All fine but finally: Partition: Write error
Your antivirus may prevent TestDisk to rewrite the partition table, disable it while TestDisk is running.
Use the arrow keys to switch the partition from L(ogical) to P(rimary) before trying to recover it.
lucanorillo
#3 Post by lucanorillo »
Thanks for your answer.
I try stoping my Windows Defender Anti Virus in Windows 10, and I change L(logical) to P(primary)
but it cant write
In disk management appears like this
May be the gpt partition is protected?
lucanorillo
#4 Post by lucanorillo »
Any help or do you think that´s imposible? Thanks
#5 Post by recuperation »
There is lots of missing information in your post.
What is your operating system?
Under which operating system have you partitioned the drive?
What is the status ante that you want to recover?
With an external 512 Byte emulation regardless of its internal 4096 Bytes an old school intel style partition table cannot exceed a partition size of 2TB.
Use GPT if you are running an operating system that supports it.
GPT allows for a partition size that is larger than 2TB.
lucanorillo
#6 Post by lucanorillo »
There is lots of missing information in your post. Sorry for my inexperience I will try to explain it better.
The operating system in my pc is windows 10, and the hdd that i want to recover, was mounted in a external box with two slots, Icy Box model, that makes the process of RAID1.
Prior to disaster, it was working well five years, connected to my pc with usb 3 cable.
Suddenly the pc stopped recognizing the box. I connect the hdd of the box to an internal bay on the pc. And in the administrator system it says Partition Protected GPT.
After that, i try with your system wth TestDisk.
I dont know if i can apport more information to help
#7 Post by recuperation »
I did not find any technical definition of the "protective GPT partition" - I only was aware of protective MBRs.
You can try to access your data using a computer running linux or running linux from a DVD or USB stick.
Otherwise replace your external box.
